Old Sep 06, 2010, 06:43 PM
squishy654 is offline
Find More Posts by squishy654
squishy654's Avatar
United States, CA, Sacramento
Joined Jun 2010
Beacon Foam-Tac EPP hinges
Beacon Foam-Tac EPP hinges (3 min 29 sec)
squishy654 is offline Find More Posts by squishy654
Old Sep 06, 2010, 08:01 PM
cmelton11 is offline
Find More Posts by cmelton11
CMelton
cmelton11's Avatar
USA, NC, Burlington
Joined Jul 2009
The Welders type glue from Lowes home improvement works very well with the epp type foam also. It is the glue in a red tube and you get 2 tubes(1 oz.each tube) for just about $5.00. It is enough from both tubes to build about 2 planes in full or more if you think it out more. Just wanted to let you know about it so you have choices.
Chris
cmelton11 is offline Find More Posts by cmelton11
Old Sep 06, 2010, 10:19 PM
squishy654's Avatar
Joined Jun 2010
Chris
Thanks dude, someone at the airfield told me something similar but I didn't catch the exact glue, thanks for the info...
Old Sep 07, 2010, 02:09 AM
Smoke7 is offline
Find More Posts by Smoke7
Smoke7's Avatar
Springboro
Joined Sep 2004
Hi cmelton11, I couldn't find Welder glue in the red tube like you state, but I did find Welder glue in the package of two at LOWE'S, for $3.38 1oz each made by Homax 2-Pack 1 Oz. Professional Welder Is this is the one you are talking about?
Smoke7 is offline Find More Posts by Smoke7
Old Sep 07, 2010, 07:23 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
If you want more flexibility out of a glued hinge , you don't have to run a continuous bead of glue . Just a couple dots of glue at close intervals works fine and is much more flexible, something like this ...................... or this --------------------
Tested this with HG hinges...
just FYI , we get better adhesion with Blenderm by wiping the areas to be taped with 91% alcohol first , or Acetone (lightly) to remove the slippery stuff ... The tape (and continuous glue bead ) does seal the hinge gap for better control surface response...
I bought a case of Blenderm ... gotta' use it up ...
gpw is offline Find More Posts by gpw
Old Sep 07, 2010, 11:52 AM
CMelton
cmelton11's Avatar
USA, NC, Burlington
Joined Jul 2009
Posts: 31 Hi cmelton11, I couldn't find Welder glue in the red tube like you state, but I did find Welder glue in the package of two at LOWE'S, for $3.38 1oz each made by Homax 2-Pack 1 Oz. Professional Welder Is this is the one you are talking about?
yeah that is exactly what I am talking about
Old Sep 07, 2010, 02:57 PM
Smoke7 is offline
Smoke7's Avatar
Springboro
Joined Sep 2004
All right!!! Thanks. I will stop by and get couple of them and try it.
Old Oct 19, 2010, 11:52 AM
squishy654's Avatar
Joined Jun 2010
Which section at lowes in this welder glue in? I have looked for it before without much luck...
Old Oct 19, 2010, 12:07 PM
CMelton
cmelton11's Avatar
USA, NC, Burlington
Joined Jul 2009
it is near the paint section at my local store
Old Apr 05, 2011, 08:57 AM
billbo1970 is offline
Find More Posts by billbo1970
Fellow Enthusiast
billbo1970's Avatar
Long Island, NY
Joined Jun 2007
What do you guys use the Welders glue for? Is it safe for ALL foam types? Does it dry hard & clear? Just asking because if it's a good glue I may look into carrying some myself. Do you know what kind of solvent is used in it?
Personally, I use the Foam-Tac for EVERYTHING except field repairs. For a quick field repair I'm still using CA; but, I'm working with the folks at beacon on new products for our industry.
I've received some lab sample test bottles of a new product that you can either paint on, or pump spray when laminating sheets of foam. I've sent samples out to some RC GROUPS members.
I'm waiting to hear back on a quick-cure version of Foam-Tac that could be used for field repairs.
If you guys would like some Foam-Tac at reasonable prices with reasonable shipping; I've worked on my shipping calculations in PayPal and now 1~4 bottles will all ship at the low price of $2.99! FOAM-TAC
Bill
billbo1970 is offline Find More Posts by billbo1970
Old Apr 05, 2011, 01:29 PM
Viper82 is offline
Find More Posts by Viper82
United States, NC
Joined Feb 2011
Foam Tac worked great for me, Only complaint I have is there is a little bit of "stringys". Not bad at all tho. Clean up is easy, no stuck fingers.
I just finished building a foamy and used less than 1\4 of the bottle. Goes a long way...
I tested it on some packing (eps) foam. Glued each side.. waited 10 mins, stuck together and pulled away and stuck back. Almost instant bond, enough time to get it right where you want it tho. Tried to pull it apart the next day and busted foam @ different spot.
Thanks Bill, great product @ a great price
David
Viper82 is offline Find More Posts by Viper82
Old Apr 05, 2011, 01:56 PM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
the beacons foam tac would work good for styrofoam hinges also.
RogueTitan is offline Find More Posts by RogueTitan
Old Apr 06, 2011, 04:37 AM
EZglider is offline
Find More Posts by EZglider
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
Billbo, Welder's is for EPP. It will melt Depron & Dollar tree foam.Not sure about FFF, but I don't think it'll work. For EPP,tho, it's the best I've used.
EZglider is offline Find More Posts by EZglider
Old Apr 06, 2011, 06:10 AM
Foam Av8r
RogueTitan's Avatar
Joined Sep 2008
Ya Welders will eat anything polystyrene that includes blue or pink FFF or any other Dow or Owens Corning foam products as will Amazing Goop but both are excellent for EPP and Coroplast.
Old Apr 06, 2011, 06:11 AM
Foam Av8r
RogueTitan's Avatar
Joined Sep 2008
EZ you are just down the road from me about 90 miles if that far
Question Ultracote / Monokote (film) hinges on EPP flying wings... FrogChief Slope 19 May 15, 2014 11:36 AM
Question Where to buy EPP foam FuzzballOfDoom Foamies (Scratchbuilt) 5 Jul 29, 2010 07:06 AM
Help! Hinges, hinges, hinges… planefun Scale Sailplanes 11 Jan 22, 2010 10:34 AM
