Old Sep 06, 2010, 03:31 AM
scabard is offline
Find More Posts by scabard
Joined May 2009
Question
Jet Legend f-16 (1/8) turbine?
I am building a Jet legend F-16, and the recommended drive is a Jetcat P-60 or P-70. The problem I have is that I live approximately 2000m above sea level so hence have about a 16% drop in efficiency of motors. I am therefor considering a P80-SE for the airframe. Any views or comments about this? Also, the hobbyshops here are consistently recommending only the Kingtech K80's, and I dont know if they are just biassed since they do not stock jetcat?
Any help would be greatly appreciated!!!
scabard is offline Find More Posts by scabard
Old Sep 06, 2010, 07:08 PM
joeflier is offline
Find More Posts by joeflier
joeflier's Avatar
United States, MI, Plymouth
Joined Jan 2005
One problem with the P-80 is that it's big and heavy for its output. You should look into one of the newer 90N class engines. They are smaller and lighter than a P-70, have quick throttle response, and put out 19-22#.
Check out the Jet Central Rabbit, Merlin 90, Evojet 90, or if you can wait a month or more Wren is coming out with a Wren 100. It's the same size and weight as a Wren 54/70/SuperSport but puts out 22#.
Joe
joeflier is offline Find More Posts by joeflier
Old Sep 06, 2010, 07:57 PM
Marty C... is offline
Find More Posts by Marty C...
Burnin Kero & Diesel Downunder
Marty C...'s Avatar
Sydney, Australia
Joined Mar 2006
The K80 should do the trick in this airframe "even at altitude" the 1/8 F-16 would fly well @ sea level with a 14-15 lb thrust turbine, so stands to reason the K80 with 18 lb thrust will work well. The Wren Super Sport also would be another option. I dont think you will need anymore thrust to be honest and lack of internal room for fuel would begin to become a factor when going much larger also, the P-80 is to big and thirsty in my opinion.
The K-80 and P-70 are about on par size and and output wise, although I would say from my personal experiences that the K-80 has the edge between the two with its lower residual thrust and slightly better fuel economy over the P-70. Based on these issues the K-80 would get my thumbs up for this project also
Obviously its also important to keep your F-16 light and I would suggest using "tailerons" for primary in-flight controls (dont need ailerons on the F-16) this should save a little weight and aid flight performance....
Cheers- Marty
Marty C... is offline Find More Posts by Marty C...
Old Sep 07, 2010, 04:49 AM
scabard is offline
Joined May 2009
Wow, thanks guys, your help here was invaluable. After having a look at the recommendations I think that the Jetcentral Rabbit is the way to go.....looks like an awesome turbine. Really appreciate the help
Might post some build pictures soon as soon as it comes back from the paint shop
Old Sep 07, 2010, 07:29 PM
rorrock is offline
Find More Posts by rorrock
Global Hobby Store
rorrock's Avatar
Brisbane
Joined Jan 2007
The rabbit will not let you down, its a fantastic turbine with true lifetime warranty and kero start...
rorrock is offline Find More Posts by rorrock
Discussion Tam Jet 1/8 F-16 with impresive performance Ron101 Electric Ducted Fan Jet Talk 26 Dec 17, 2010 06:55 AM
Sold (Reduced)New In Box Tam Jets 1/8 F-16 with Jet legend scale gear Ron101 Aircraft - Electric - Jets (FS/W) 2 Jul 20, 2010 11:38 PM
Sold New In Box Tam Jets 1/8 F-16 with Jet legend scale gear Ron101 Aircraft - Electric - Jets (FS/W) 5 Jul 17, 2010 12:44 PM
Cool Skymaster 1/6 Scale F-16 Jet Turbine Flight Video By PlaneVideoArt At_your_six Fuel Jet Talk 1 Apr 30, 2009 12:11 AM
Discussion SkyMaster 1/6 Scale F-16 Jet Turbine Video Part 1 By PlaneVideoArt At_your_six Jet Turbines 0 Apr 23, 2009 05:57 PM
