Old Sep 06, 2010, 02:59 AM
lamafever is offline
Find More Posts by lamafever
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Jun 2007
What type / name of foam for wing core ?
I'm planning to build a DLG wing but i can't really find a good foam over here i can do the job ..... all we got in the stationary shop is the 5mm depron or the highly compressed beaded foam (aka polystrene)
What is the name of those blue / green foam that u guys using anyway ?
lamafever is offline Find More Posts by lamafever
Old Sep 06, 2010, 04:29 AM
jirvin_4505 is offline
Find More Posts by jirvin_4505
working to the closest cm
jirvin_4505's Avatar
brisbane australia
Joined Nov 2002
Where is over here? maybe some local knowledge could help
jirvin_4505 is offline Find More Posts by jirvin_4505
Old Sep 06, 2010, 11:30 PM
Joined Jun 2007
Hahaha Malaysia .... all art shops are only selling 5mm Depron or those beaded compress foam. Factories are selling them as in boxes instead of pieces.
Old Sep 07, 2010, 02:51 AM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
The extruded foam that we like might be available from refrigeration companies...the kind that might install a walk-in freezer for a resturant. The terms "extruded polystyrene" or "rigid insulation foam" might help. Good luck.
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Sep 07, 2010, 05:19 PM
flyonline is offline
Find More Posts by flyonline
Twisted and Confused
flyonline's Avatar
Joined May 2003
Try a local search for Isoboard (the DOW product name), you could also try insulators, concreters or builders (it's used as insulation underneath concrete slabs as well) or try contacting DOW directly to see if they have local distributors.
flyonline is offline Find More Posts by flyonline
Old Sep 07, 2010, 05:41 PM
noobee is offline
Find More Posts by noobee
Joined Dec 2006
art supply stores are another place to try.
if you are going to hotwire cut the wing, i think you need it about 1" thick (around 25mm).
good luck!
noobee is offline Find More Posts by noobee
Old Sep 08, 2010, 02:51 AM
Joined Jun 2007
Well there's no luck from the local stationary shop, they only have those cheap compress beaded foam .... the only one i can find is beaded but much more denser :P ..... is there any way i can fill the imperfection of the surface after cutting ? What i have is light weight similar to the balsa filler. Should i mix it with epoxy ?
I'm planning fill those rough surfaces, sand it and do wet layup.
Old Sep 13, 2010, 03:04 PM
G_T is offline
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
Beaded foam cores will likely fail early and be rather difficult to repair in a DLG wing. They crumble. I'd recommend to keep searching.
Gerald
G_T is offline Find More Posts by G_T
Old Sep 16, 2010, 12:25 AM
r.p. is offline
Find More Posts by r.p.
Michigan
Joined Jan 2010
As above try Dow first. Then try these local guys http://www.yeehup.com/products/ as they seem to do both expanded and extruded polystyrene foams. Local surfing guys would know where to go for foam as well....
r.p. is offline Find More Posts by r.p.
Discussion Installing Spoilers In A Foam Core Wing wsmorton Scale Sailplanes 3 Sep 02, 2010 05:51 PM
Discussion Glassed Foam Core Wing- Hinging Methods alexhaben Slope 31 Jul 27, 2010 03:23 PM
Discussion What type of glue to use when glueing balsa sheeting to foam core wing jumpinjo Fuel Plane Talk 19 Dec 25, 2009 06:43 PM
Question What type of foam core should I use? jfrazier Composites Fabrication 6 Feb 27, 2008 01:05 PM
Question What covering for a white foam core wing Jim Cantillo Sailplane Talk 4 Feb 22, 2005 09:07 AM
