Old Sep 06, 2010, 12:48 AM
britinoz is online now
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
Idea
Home made UNI Joint
G' Day Folks
Recently during the SPIRO 111 building thread, Rich was saying that his idea was to try to cut cost's on the project and that a Uni joint in the UK cost around 10 pound.As it so happened at the same time I picked up one on Ebay for $ 6.00 AUD {that's cheap}.
When it arrived I thought that it was not out of my reach to make something similar. So I used what I had on hand at the moment which was some 10.mm OD Ali tube /2-56 bolt and some brass tube that is a good fit to the bolts.
I am sure that carbon or plastic tube or Square section would work just as well.The first one I made took about an Hour & the second took half that time.
I simply filed grooves in the end of the tubes,and drilled holes for the bolts.
The swivel was made from 2 pieces of Brass tube lashed together with Carbon Rovings ,then hit with thin CA.[ I am sure that strong thread or Glass rovings would work just as good ],when dry the X was cut off the end of the tubes.and sanded to fit.
A little grease in the tubes and pop in the bolts.and Bob's your Aunty
I am pretty sure this method could be used on larger models .just a matter of adjusting the size of the components to suit the job.
Some of you may think it is a wast of time when UNI joints are available in stores ,It's just that I am old school,and always enjoy being able to make as many parts of my models myself.
Happy Landings
Chris.........
I hope these Pics tell the story
britinoz is online now Find More Posts by britinoz
Old Sep 06, 2010, 04:19 AM
JochenK is offline
Find More Posts by JochenK
JochenK's Avatar
Joined Jan 2005
Chris,
that's a nice solution. Have you tried soldering the brass tube joint? Tht may even be more simple.
Jochen
JochenK is offline Find More Posts by JochenK
Old Sep 06, 2010, 09:48 PM
britinoz's Avatar
Joined Nov 2005
G'Day Jochen
Yes I am sure that soldering would be easy,but to tell you the truth,I never solder.
I use this method of carbon rovings with thin CA on all my U/C jobs,and it has never failed.even on my larger fixed wing models.
I also used this method when I built my two Minimum's The Carbon frame was assembled dry in stages. I know that using wet rovings can be a pain. [The last 24 years of my working life has been hand making carbon model and full size props ,so I am
very comfortable with this material]
Happy Landings
Chris...........
Old Sep 06, 2010, 10:23 PM
jodini is offline
Find More Posts by jodini
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
Thanks for sharing Chris! That's my type of stuff....homemade!
jodini is offline Find More Posts by jodini
Old Sep 11, 2010, 09:33 PM
Chestum is offline
Find More Posts by Chestum
USA, TX, Diboll
Joined Aug 2007
Chris, that was a really cool idea.
Chestum is offline Find More Posts by Chestum
Discussion home made rudder nick30head Racing Boats - Electric 11 Aug 18, 2010 10:55 AM
Question home made indoor, roll vs yaw bradleyK Indoor Pattern/F3P 10 Aug 11, 2010 09:48 AM
Discussion home made indoor, roll vs yaw bradleyK Scratchbuilt Indoor and Micro Models 2 Aug 07, 2010 02:53 PM
Discussion Uni joint Bob Bighinatti Dock Talk 18 Aug 07, 2008 01:07 PM
