This thread is privately moderated by VampeD4, who may elect to delete unwanted replies.
Old Sep 05, 2010, 07:06 PM
VampeD4 is offline
Find More Posts by VampeD4
Trader Rating: 97
Tucker and Daisy
VampeD4's Avatar
United States, WI, Wisconsin Rapids
Joined Mar 2008
Trader Rating: 97
Sold
SUPPO™ Speed Controller/BP Hobbies Outrunner # BL-3520/6 motor/Li-Poly
i have this STUFF (im a Nitro Guy) never used it. the motor will fly a plane thats 6 to 8 pounds. bat is 3 cell 11.1v. would like to sell/trade looking for motors 40 on up. i do have the paper work for it.
Constant current 60A Max 80A <10s
Li-Poly 2-7 cells Ni-MH 6-20 cells
Low resistant 0.0014 ohms;
Dynamic braking
BEC: opto
Auto shut down when lose signal
Slow down at 3.0V per cell Lipo, Cut-off at 2.9V per cell Lipo 0.8V Nimh
Battery Setting
Throttle Range
Brake Setting 4 options:
Direction and Cutoff Type
Timing Mode Setting: 1º /7º /15º/30º
PWM Setting: 8K/16K
Motor
No. of Cells: 3-5 Li-Poly
4 - 6 A123
Kv: 840 RPM/V
Max Efficiency: 82%
Max Efficiency Current: 18 - 40A (>75%)
No Load Current: 2.1A @10V
Resistance: 0.050 ohms
Max Current: 50A for 60S
Max Watts: 840W
Weight: 210 g / 7.5 oz
Size: 42 mm x 47 mm
Shaft Diameter: 5mm
Poles: 14
Model Weight: 1500 - 2800 g / 53 - 99 oz
Propeller: Volts (V): Amps (A): Thrust (oz): Power (W): RPM:
APC 12 x 6 E 11.33 V 24.66 A 42.5 oz 274 W 6965
APC 12 x 8E 11.35 V 27.5 A 43.3 oz 306 W 6763
APC 12 x 8 E 13.51 V 39.8 A 61.2 oz 530 W 8191
APC 12 x 6 E 13.56 V 36.1 A 65.1 oz 483 W 8438
APC 11 x 7 E 18.05 V (A123) 47.52 A 74.1 oz 837 W 10125
The motor features a 5mm hardened steel shaft, dual ball bearings for the shaft and has 4.0mm gold spring male connectors already attached with 3 female connectors included for your speed control. Also includes accessory package with the pictured aluminum radial cross mount set with 8mm prop adapter. Mounting holes are spaced 21mm on center and are tapped for 4mm (M4) screws
BP Hobbies Outrunner # BL-3520/6 motor ( eflite 32 equivalent)
Roughly equivalent to .40 2-stroke glow engines.
if one of you guys could tell me what this is worth. or i should ask for it.
pm me. as im in the Nitro part of this forum 99.9% of the time
VampeD4 is offline Find More Posts by VampeD4
Old Sep 05, 2010, 08:47 PM
bc-slowflyer is offline
Find More Posts by bc-slowflyer
Trader Rating: 294
Lower, Lower
bc-slowflyer's Avatar
Penticton,BC, Canada
Joined Feb 2004
Trader Rating: 294
Good luck on your sale.
bc-slowflyer is offline Find More Posts by bc-slowflyer
Old Sep 05, 2010, 08:58 PM
VampeD4 is offline
Trader Rating: 97
Tucker and Daisy
VampeD4's Avatar
Joined Mar 2008
Trader Rating: 97
thanks
Old Sep 06, 2010, 07:21 AM
Billbor is offline
Find More Posts by Billbor
Trader Rating: 44
Billbor
30080
Joined Jun 2010
Trader Rating: 44
pm sent.
Billbor
Smyrna, GA
Billbor is offline Find More Posts by Billbor
Old Sep 06, 2010, 09:30 AM
danny wilcox is offline
Find More Posts by danny wilcox
Trader Rating: 22
United States, IN, Wabash
Joined Jan 2005
Trader Rating: 22
hi
may i ask what your looking for in a trade ? i got some gas motor cox 149 testers os 20 os 40 os 46 1/2 planes any interest ?
danny wilcox is offline Find More Posts by danny wilcox
Old Sep 06, 2010, 09:36 AM
VampeD4 is offline
Trader Rating: 97
Tucker and Daisy
VampeD4's Avatar
Joined Mar 2008
Trader Rating: 97
yes. ill pm you
For Sale Tons of heli stuff!! Motors, Electronics, Frames,Walkera stuff, NIP parts! ReaLyze Non R/C Items (FS/W) 12 Mar 02, 2010 07:29 AM
For Sale Airsoft Stuff, lots of stuff. nieb15 Non R/C Items (FS/W) 11 Jan 13, 2010 08:11 PM
For Sale bunch of stuff need this stuff gone! baja5bdriver Cars - Cars and Parts (FS/W) 1 Jan 12, 2010 09:06 AM
Sold 4#3B Stuff and Modding Stuff AtTheCross Aircraft - Electric - Helis (FS/W) 8 Dec 24, 2009 11:55 PM
