Joined May 2005
Esky Big Lama or Walkera Lama 400?
Which one would you get? Either one will be getting the extended shaft and will be flown out doors in calm winds or a slight breeze. Everything I've had Esky has worked great, but Walkera...not so much.
Are they approximately the same size and which one will handle more wind with the Extreme upgrades? Edit: This video makes the E-Sky look a little more impressiveL
Walkera, as a rule, puts out some lousy videos of their new heli's. The one for the 400D makes it look like a flying brick. My experience with Esky has been 72Mhz and the electronics is usually very glitchy/ twitchy. Again, they could have given you a brushless version and saved a lot of expense and hassles. ![]() I just realized that the Esky is still 72Mhz (long extended transmitter antenna). It did seem pretty peppy. It doesn't say if it has been upgraded to brushless or not. |
Latest blog entry: UM Stryker
from every other angle (and all the follows is ... as usual ... my very personal 2Cents) my answer would be "NO" The Lama400 is bigger, has more powerful motors (stock), is A LOT heavier and also uses a very different frame concept. While the BigLama stays within the Esky tradition of "Toy" plastic frames the Lama400 uses a fiberglass frame that is following the example of "real" helis (6Ch single rotor like TREX, CopterX ...) Also, the Lama400 comes with a lot more aluminum parts in the stock version than the Big Lama does (however the aluminum parts are - from a material quality point of view - rather cheap ... From a point of view of flight characteristics the Lama400 (in stock form) seems to me yet a little more sluggish (well, sluggish is not really the correct word, but you definitely feel the amount of weight that has to be moved ...) than the BigLama ... ... so to really get to experience their full potential you would need to convert either of them to brushless motors ... and that seems (again - just to me!) to be a little more difficult with the Lama400 than it is with the BigLama! In terms of modding and "beautifying" the BigLama seems to have a larger array of parts to choose from than the Lama400 I would say ... ... and as usual: always just my 2Cents!
Latest blog entry: The WLToys V912
I don't have the option to fly outside, so I cant answer that part of the question ... as far as mounting the camera is concerned, it depends on your camera (mainly) but I would say the Lama400 leaves you a larger amount of choices (of camera to choose from) as it seems to be able to lift more than the BigLama ...
| Thread Tools | |
| For Sale FS/T Walkera 5#6 Micro Heli + Esky Lama V4 both like new! | Blind | Aircraft - Electric - Helis (FS/W) | 1 | Sep 07, 2010 07:23 PM |
| Discussion Esky Big Lama coaxial 2.4 ghz | lake600 | Coaxial Helicopters | 12 | Aug 27, 2010 01:49 PM |
| Sold ESky EK2-0709 3 in 1 Controller F Big Lama | muccy | Aircraft - Electric - Helis (FS/W) | 1 | Aug 05, 2010 10:17 AM |
| Sold Esky Big Outdoor Lama, Boom & Pod $95 | muccy | Aircraft - Electric - Helis (FS/W) | 1 | Jul 29, 2010 09:33 PM |
| Discussion First Heli: Esky Lama V4 vs. Walkera 5#4Q4 vs. Walkera CB-180Q FP | shannon520sx | Beginner Training Area (Heli-Electric) | 8 | Oct 28, 2009 09:32 PM |
