Futaba WTR-7 FASST Wireless Trainer System Review
The Futaba FASST Wireless Trainer System not only cuts the cord between the instructor and the student, it can also support instruction using two FASST transmitters or one FASST and one 72MHz TX.
Operation Range:30 feet
Size:.89 x 1.59 x .52"
Weight:.29 oz.
Manufacturer:Futaba
Available From:Tower Hobbies
Price:$99.98
We have all been to the flying field and experienced a student taking his first flights with the assistance of the instructor. We may have even seen the way their radios are tethered via the training cord and the problems that can happen if an instructor and student stray too far apart. Futaba has provided more freedom in that connection with their new Wireless Trainer System.
What's Included
Futaba WTR-7 FASST Wireless Trainer System includes:
  • Wireless Trainer System
  • Connection Cord
  • Mini Screwdriver
  • Hook and Loop Material and Instruction Sheet
So how does it work?
Flying using the Wireless Trainer System
The Futaba Wireless Training System was easy to setup using the included instructions. Being able to maintain the instructor/student connection without the cord was a huge advantage. This way the instructor can stand anywhere he wants within a 33 foot range of the student. Early in the training, the instructor can be right next to the student to provide direction and support. As the student progresses, the instructor can stand a distance behind the student to give him the confidence to fly solo while still being able to take control.
Photo Gallery/Video
The Futaba WTR-7 FASST Wireless Trainer System worked flawlessly through our testing. If you have ever had your transmitter nearly pulled from your hands via the trainer cord, it will only take one flight for you to appreciate wireless freedom. Also as mentioned in the review, the ability to stand anywhere within a 33 foot radius is a benefit to both the instructor and the student. The system plugs into square trainer port on the instructor's TX and supports 72MHz, 50MHz or 2.4GHz transmitters for added flexibility.
Plusses:
  • Wireless freedom
  • Easy to setup
  • Allows 72MHz transmitters to be used as instructor TX
  • Lightweight
Minuses:
  • Wireless freedom costs more than a trainer cord, but it's worth it!
Old Sep 30, 2010, 07:22 PM
Landin' On The Canopy BAD
F-86FLIER4LIFE's Avatar
Lee's Summit, MO
so basically putting the unit into the trainer Tx first teaches the tx the signal for the module? then when its plugged into the instructor tx, it links the student to the instructor, and the instructor can still use his 2.4 to control the plane? i just want to know if im getting this right.
F-86FLIER4LIFE is offline Find More Posts by F-86FLIER4LIFE
Old Sep 30, 2010, 08:14 PM
RC Fanatic
Reco's Avatar
USA, NC, Greensboro
Joined Mar 2002
It sure is wierd to see somebody flying Nitro...
Reco is offline Find More Posts by Reco
Old Sep 30, 2010, 09:14 PM
Timelord
Doctor Who's Avatar
USA, IN, Muncie
Joined Mar 2002
Yes, you are linking the student TX to the Wireless Trainer System that is connected to the instructor TX.
Doctor Who is online now Find More Posts by Doctor Who
Old Sep 30, 2010, 09:23 PM
Lee's Summit, MO
okay cool thanx that is certainly something interesting sounds like it could come in very handy! to bad im on spektrum 2.4 i hope they come out with somethin like that soon
Old Oct 01, 2010, 02:56 AM
UK
Joined Oct 2001
Use with non futaba instructor TX module?
It sounds as if this would work with a Spektrum module in the instructors transmitter, provided that transmitter had a new style futaba buddy socket. This would let you use a trainer aircraft with a Spektrum RX.
N.B. Thinking further, it should be possible to use any brand RX in the Aircraft, provided you use a TX module to fit an instructor's TX, and the buddy/trainer socket is (or has an adaptor to match) futaba new square style.
Is any-one able to check this ?
mitchellj is offline Find More Posts by mitchellj
Old Oct 01, 2010, 02:42 PM
Lee's Summit, MO
i actually am flying with a futaba 10c with a spektrum module. think it could work out?
Old Oct 07, 2010, 07:54 AM
What a blast!
RocketManRC's Avatar
Atlantic Canada
Joined May 2007
I have been using the WTR-7 since last winter and it works extremely well for training. I have probably used it for about 10 students. I would never go back to using a trainer cord!
I have used it on both a 6EX-2.4 and 10c. When connected to the 10c any transmitter module can be used. I have Spektrum and ASSAN modules as well as FASST. I don't think I have actually tried the combination of WTR-7 on the 10c with the Spektrum module yet.
By the way the WTR-7 is great for having someone back you up for learning FPV. In that situation the last thing you want is another cable to trip over.
Rick
RocketManRC is offline Find More Posts by RocketManRC
Old Nov 02, 2010, 03:46 PM
Electric Airplane Junkie
bhchan's Avatar
San Mateo, Ca , USA
Joined Jun 2000
Too bad this system is kind of backward. Wish it can use the student tx as master and instructor tx can over ride the student tx. The logic is the student can have his own tx/ plane. So the instructor can help the student flies his/her own set up.
When someone shows up with plane, just add the module to the student's tx and the instructor can over ride the student without setting the student's plane with the instructor's tx.
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old Nov 21, 2012, 08:02 AM
Iowa
Joined Dec 2002
So I have a plane on one with all the settings with this do I have to make all the settings the same on the buddy box as well? OR does it see the info from the master ?
Thanks.
Cougar is offline Find More Posts by Cougar
Old Jan 18, 2013, 08:24 AM
Iowa
Joined Dec 2002
no response
Article Futaba 7C 7-Channel 2.4GHz FASST System Review pda4you Radios 157 Oct 29, 2012 11:29 AM
Sold Futaba R617FS 7-Channel 2.4 ghz FASST Receiver Tamiya10 Aircraft - General - Radio Equipment (FS/W) 2 Aug 31, 2010 04:25 PM
For Sale Futaba 6 EX 2.4GHz FASST radio system qmulus Aircraft - General - Radio Equipment (FS/W) 0 Jul 31, 2010 04:48 PM
New Product Futaba offers new wireless trainer system RadiMani Radios 6 Nov 18, 2009 06:29 AM
Sold NEW! Futaba 2.4 GHz Fasst System (1)TM-7 RF module and (2) R617FS $149.00 Craic C Aircraft - General - Radio Equipment (FS/W) 5 Dec 11, 2008 07:36 AM
