Old Feb 17, 2012, 04:01 AM
JUDD-RC.id.au is offline
Find More Posts by JUDD-RC.id.au
JUDD-RC.id.au's Avatar
Australia, NSW, Sydney
Joined Sep 2010
Originally Posted by juanquy View Post
what motor mount do you used?
Ive used the 28X mount that u can get in the motor spare parts tab.
But you were after something that you dont have to reverse the shaft on...
Have a look at some of the 28mm motors from turnigy..
what you need wil depend on your prop size..
4.75 X 4.75 needs 3200~4200KV and needs to be above 500Watts to survive on a 3S battery.
5 X 5 will need to be 2800~3200KV again around the 500W mark on a 3S
6 X 4 2200~2800Kv again around the 500W mark for a 3S
Battery will need to be a 3S 2200mah 20C (short life span) 30C prefered.
reason is just maths.
The 2200mah 20C can take 44amps continiously 2.2 X 20 = 44.
So a 30 C battery will be 2.2 X 30 = 66amps
I know my 2223 motors pull around 55amps(not good but they are tough motors)
so a 30C battery will last a long time...( good for vetran fliers who dont crash very often)
Where the $9 3S 2200 will last a few months which is fine for begining as crashes occur often and often cost batteries.
Clint
JUDD-RC.id.au is offline Find More Posts by JUDD-RC.id.au
Old Feb 17, 2012, 03:08 PM
juanquy is offline
Find More Posts by juanquy
United States, KS, Buhler
Joined Feb 2011
Thanks Clint
I have a 6x4 cant find a motor in Hobbyking 2200~2800kv around the 500W.
Im going to check nitroplanes dot com see if they have a similar.
thanks bro
Clint
juanquy is offline Find More Posts by juanquy
Old Feb 17, 2012, 07:22 PM
Joined Sep 2010
thanks bro
Yeah its tough on their website to find something with good characteristics..
This one needs shaft reversal but includes the X mount and prop adapter
http://www.hobbyking.com/hobbyking/s...er_2350kv.html
Power is a bit low on this one but it will spin a 7X4 prop
http://www.hobbyking.com/hobbyking/s...dProduct=12919
Old Feb 18, 2012, 12:32 PM
juanquy is offline
Joined Feb 2011
what about this setup?
I been doing a little research thru the forums,I was wondering why not use a EDF motor but with a prop
I found 2 guys they did, So maybe I'm missing something about this EDF motors but what about this:
http://www.hobbypartz.com/75m96-ducted-2220-2700.html
its a 2700 kv, 500W, 28mm ,78g (a little heavy) and load weight 80g
with a mount like this one :
http://www.hobbyking.com/hobbyking/s...tor_Mount.html
a prop adapter Colet type 3.17mm
and 60amp ESC (no/BEC) 3s 2200 40c lipo
Old Feb 19, 2012, 04:55 PM
Joined Sep 2010
Just looking at the motor you have suggested.. Yes you wont have to reverse the shaft inside the cage mout that you have spoted.
but try this motor instead on the 6X4
http://www.hobbyking.com/hobbyking/s...dProduct=11179
Its cheaper and will be in the same order when you get the Xmount.
Also why no bec? do you have a standalone?
I just ordered some towerpro 40amp esc's $11 and hard to kill.
http://www.hobbyking.com/hobbyking/s...idProduct=9299
Old Feb 20, 2012, 01:39 PM
juanquy is offline
Joined Feb 2011
you are right man
Agree with you.
hey what about the Turnigy SK3 series, they have this one:
Turnigy Aerodrive SK3 - 2836-2500kv Brushless its 405W
http://www.hobbyking.com/hobbyking/s...dproduct=18117
read what ppl say it about this motor.
I think I'm going to buy 2 Turnigy 2223 4400KV motor and one Turnigy SK3 2836 and see what happen.
Thanks a lot for your help and free plans bro!!!
jc
Old Feb 23, 2012, 08:16 AM
Joined Sep 2010
Agree with you.
jc
No worries Juan, I havent used the sk motors at all.. I had looked but not read many favourable reports so I didnt look at them.
I think you will like the 2223 motor and maybe even look at shaft reversal one day.
Its a great motore.
Enjoy the plans they are there to be enjoyed.
Old Mar 06, 2012, 03:20 AM
HighFlyby2 is offline
Find More Posts by HighFlyby2
5 mistakes high...Invisible!
HighFlyby2's Avatar
Joined Feb 2012
Clint...
I am a newbie and I spent this evening reading your entire thread. I have also downloaded several of the plans from your website. I really appreciate the work you have done in providing great plans and technical help to all who ask.
It seems to me that one of your videos showed you flying the "Trainer" but it did not match the Trainer plans from your site. It had double wing thicknes (KF?) and the shape of the wing was different (swept back and stepped at the fuse). It did not look like the JP1/2 but I could be mistaken. The one in your video had a camera mounted on the nose but I am not ready for FPV at this point. Your final comment at the end of this video was "Well...I think we can consider that a success".
What version of the Trainer was this??....I would like the plans for it.
Again, you do the RC community a great service. Thank You.
HighFlyby2 is offline Find More Posts by HighFlyby2
Old Mar 06, 2012, 07:34 AM
Joined Sep 2010
Originally Posted by HighFlyby2 View Post
Clint...
Hey and welcome to the thread. Yeah it was just a scratchbuilt version of what Id seen of Mike P's plans. I like the F22's V tail so that was inherited onto this model.
Yes I used a KF step on the wing and it was one piece for the top to add more strength to the wing.
Ive been mainly been working a lot recently. I work an 11day on 3 day off roster living away from home so I do play with planes after work but I dont have the resources and time to put up plans and make as many videos as Id like to..
But that will change shortly so you should see more videos and more how to's.
My website renewal is up again so there is another $50 for the year but its a drop in the ocean I suppose for what it gives to the community.
Look fwd to more plans like these soon..
Clint
Old Mar 18, 2012, 10:07 PM
Joined Sep 2010
Clint...
Hello Bert, a little bit late but as you requested. I gave the wings a little bit more sweep and the vertical surfaces can be set to your desired angle but the image on the plans is set at 60deg.
The KF airfoil would be better as one piece over the join in the center to give it strength. Even if its joined to another piece further down the wing.
Recomended performance setoup would be either the 2218 or 2223 turnigy motors starting from 3200~4300KV with the towerpro 40amp ESC using a 2200mah 20C 3S battery on a TGS 4.75 X 4.75 prop.
Ive left out servo placement but its better to take advantage of the skids and to mount them on the underside of the wing but cut into the vertical skid to really lock them into place.
I have not built this yet but it will fly. The ailerons can be lengthened inwards to achieve that locked in place servo setup.
Unfortunately my copy of photoshop is locked out at the moment so plan quality is so so.
Please let me know how your build turns out.
Regards
Clint
JRC
Old Mar 18, 2012, 10:16 PM
Joined Sep 2010
Foamboard Zephyr
Here are some pics of my FB zephyr.
A very very agile beast.
You can check out the videos here
Old Mar 18, 2012, 11:39 PM
CX2Mike is offline
Find More Posts by CX2Mike
Eastern, NC
Joined Apr 2008
Clint!
Great to see you back in action bro!
I'm sorry to hear you've been working away from the family so much.
Are you still doing rail work?
I go to your site often, to check for new work and to keep the traffic up.
Glad to hear you're still building and flying. I haven't been in the sky in months. The weather here is NOT flying-friendly in the winter, and I've been swamped with work and other projects.
I can't wait to try out that new trainer you posted for Bert.
Will you bee doing a single sheet pdf plan for it? I seem to have trouble with the jpg images for some reason. They never seem to print the correct size, even if I manipulate them in photoshop. I think it may be a problem with my plotter.
Cheers!
-Mike
CX2Mike is offline Find More Posts by CX2Mike
Old Mar 19, 2012, 04:18 AM
HighFlyby2's Avatar
Joined Feb 2012
Clint, thank you for the new "Trainer"! The plane looks terrific and I will start the build ASAP. I appreciate the additional configuration guidelines on the build and on the
electronics installation. I will let you know how the build goes and send pictures.
Thanks again for allowing us to enjoy your designs.
Regards, Bert
P.S.: When do you think you can publish the plans in JPG Format so we can scale it in Paint?
Old Mar 19, 2012, 08:36 AM
Joined Sep 2010
Regards, Bert
PNG or portable network graphics ( I think?) will still scale up or down using paint. I started using PNG files over jpg files as I found every time I save a change to my plans using paint the image would start to smudge or pixilate when using jpg as the saved file.
I do hope that it works well for you Bert.
Regards
Clint
Old Mar 19, 2012, 08:42 AM
Joined Sep 2010
Originally Posted by CX2Mike View Post
Clint!
Cheers!
-Mike
Hey Mike, long time my friend.
yeah working away is a bummer but Im finishing that job soon.
I should fix up my registration issues for PS as the image always comes out nicer!!
As for finishing them as a pdf.. One day my friend.. one day haha!!
I hope those other projects free up and give you some time to get some rc time in mate... Without I think Id be a little bit mental....
No wait... I think I am already.
I have to get on soon and pay for my site renewal or otherwise I will just start to post the plans on here.
Clint
Help! ID this airplane gregory.da Electric Plane Talk 3 Sep 13, 2010 02:12 PM
Sold $47.58 APV RC Mini Camera for airplane,heli.. FREE SHIPPING the-cat007 Aircraft - Electric - Airplanes (FS/W) 17 Oct 27, 2009 02:21 PM
Sold Lower Price! Extra 260 ARF 90 RC Airplane FREE SHIPPING IN USA. WOOZ Aircraft - Fuel - Airplanes (FS/W) 0 Sep 05, 2009 06:28 PM
Discussion Who knows of a good site to get Free RC airplane plans off of WANTPLANS Giant Scale Airplanes 1 Jul 10, 2009 03:09 PM
