I believe you are referring www.wowplanes.com. The product that they are selling under the name "liquid sheeting" is what I believe to be another product that is usually sold in larger quantities called Styrospray 1000.
Ken
Latest blog entry: MPF M6 Mermaid Scratch and Kit Built
I have used it in the industrial setting, and also tried samples on Dow blue foam. It really depends on what you are after in your model. Whether scale, sport, or some other application. Most of the foam modeling I have done has led me to the conclusion that this is not what I would use. If I needed a hard surface finish and strength I would rather go with 3/4 oz glass cloth and epoxy resin, and that would be for a larger size model. It does lay down a smooth finish, but you do need to have it smooth to start with. Their website does have good tutorials for its use.
Ken
Dave,
If you are building small scale planes as your name suggests, then I would not recommend it. This stuff will kill you in weight. Ken
Joined May 2010
I use water-based clear varnish. I add a good amount of babies talcum powder and acrylic colour if desired. Sand after with 240 grade emery, or other paper.One more coat and final sanding.Light weight and quite smooth.To get a strong surface and a MUCH more rigid wing I use diluted white wood glue to glue on fine smooth Saa paper from Chiangmai in Thailand. Wonderful stuff and very cheap .There!
but what is Saa paper from Chaingmai? |
Joined May 2010
Paper covering
Yes Saa paper is mulberry paper.It took a while to find a fine NON hand made one .I will look for a supplier on the net ,its a long way to Thailand! I also found a fine semi transparent tissue that t thought was plastic ,until I .wetted it.It cockles so it cant be.I have just finished a 1.5m powered glider using it ,glueing it on again using white wood glue.Even wet it was quite strong enough.Cant tell you what its called.I am going back to the same stationery shop in Chiangmai in a month to find it,its fabulous! Just buy some samples and stick them on to sanded foam with white PVA glue,good luck!
Joined May 2010
I have used the thicker handmade saa paper.The added strength is astonishing!I bruised my knee trying to break one wing to get it into the bin bag!The extra weight varies according to the thickness of the paper and thus amount of glue needed,20 or 30 % more than foam, but you dont need any carbon reinforcing.I have 30 or more planes covered in this way ,up to 2m gliders. They will be around a long time.Brown paper ,kraft, works well too Keep the grain the same way top and bottom or the piece will curl!
| Thread Tools | |
| Question Fiberglass Or Liquid Sheeting Over EPS Foam? | Extremeflyer | Foamy EDFs | 7 | Apr 04, 2010 10:29 PM |
| Discussion Gel coat for epoxy lay ups? | Stealth Assassin | Composites Fabrication | 5 | Feb 12, 2009 01:34 AM |
| Discussion gel coat or tooling resin... | dutchydawg1 | Slope | 18 | Jul 09, 2008 11:17 AM |
| epoxy paint for fiberglass gel coat | duhaas88 | The Builders Workshop | 9 | Oct 31, 2005 12:32 PM |
| Paint for Warehouse Hobbies Gel Coat Trim Colors | Brucesfly | Racing Boats - Internal Combustion | 4 | Apr 25, 2005 11:52 AM |
