Old May 26, 2011, 06:33 AM
vissio is offline
Find More Posts by vissio
Joined May 2011
Originally Posted by Wasp09 View Post
I did.
I put 6 of those on my 2 V400D02.
It is the standard mod of swapping the wires inside to make them swing the same way as the stock. Or you can choose to turn the RX 180 degrees and also do some reverval on the TX.
I hot glued them onto the stock brackets. The rear two brackets are lifted up a bit with o-rings as the metal servos are a little bit thicker than the stock. The rear brackets are also turned backwards to allow more room between the front and rear servos as the metal servos are a bit longer than that stock. Now the rear servos are resting against the frame instead of hanging inside the openings
With hot glue, it is easier than I thought to get them fixed in the right place.
I got those cheap with free shipping, but price had gone up since. Shipping now costs more than the servo, so it is close to $6 per piece instead of less than $2.25. I had bought 12 at the good price though.
Thanks for the reply, it seems there is a lot modifications required. I think I go with exi's servo for the moment;-)
vissio is offline Find More Posts by vissio
Old May 27, 2011, 10:18 PM
ricardoscasas is offline
Find More Posts by ricardoscasas
Joined May 2011
i agree regarding the EXI servos. I have 4 of the V400's and i replaced all 12 servos with the EXI's. the mod is very easy- just have to align the brackets with the holes and voila. after that just make sure the servo arms and swash were level to the ground at zero degrees and thats it. the first 2 helis took me about 30 minutes each to replace and the other 2 literally took me 20 minutes each. no biggie. just make sure to hit all the threads with locktight.
ricardoscasas is offline Find More Posts by ricardoscasas
Old May 31, 2011, 10:23 PM
Joined May 2011
Custom V400D02 with Fusuno Canopies
V400d02
Old Jun 01, 2011, 12:00 AM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
Hi, got my replacement motor for my V400D. I tried to set pitch and travel to where the motor only gets warm. Hoping it will make it last longer.
Heres a vid I made at the small park by my house.
Walkera V400d 02 (10 min 36 sec)
barnstorm100 is offline Find More Posts by barnstorm100
Old Jun 01, 2011, 07:29 PM
Joined May 2011
can anyone tell me what size the stock ball linkage balls are that attach to the servo arms? are they 2MM? i need to order some but i no idea what the size is. thanks.
Old Jun 03, 2011, 09:53 PM
Torch8 is offline
Find More Posts by Torch8
Torch8's Avatar
NYC
Joined Aug 2010
How is the 3-axis gryo on this heli?
Torch8 is offline Find More Posts by Torch8
Old Jun 11, 2012, 08:00 PM
Neoneo is offline
Find More Posts by Neoneo
Joined May 2012
Originally Posted by ricardoscasas View Post
V400d02
does anyone have a link to all the v400d02 mods. I'm looking to buying one tomorrow and i am getting mixed reviews. they say its a good bird, but thats with the mods. any help would be great
Neoneo is offline Find More Posts by Neoneo
Old Jun 11, 2012, 08:29 PM
J.Douglas is offline
Find More Posts by J.Douglas
Old Skool
J.Douglas's Avatar
Joined Dec 2003
Are you using the stock motor ?
And what is the bike in your avatar ?
JD
J.Douglas is offline Find More Posts by J.Douglas
Old Jun 12, 2012, 06:12 PM
MX48 is online now
Find More Posts by MX48
United States, GA
Joined Dec 2011
Looks like an early '70's Maico MX bike.
Moto
MX48 is online now Find More Posts by MX48
Old Jun 12, 2012, 07:07 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
I had a 70's Maico 250, boy did I have some good crashes on that one. lol
JD
Old Apr 01, 2013, 09:23 AM
Wasp09 is offline
Find More Posts by Wasp09
Canada, ON, Ottawa
Joined Jun 2009
I cooked the stock motor on my old V400D02 by using the Master CP RX and a 2200mAH Lipo trying to get enough lift to take off.
Then I put a HB2626 on it converting the main motor to brushless using the same pinion. Now the main is working fine, but it appears my stock tail motor is unable to catch up.
Any idea what is a good tail motor to use for brushless?
Wasp09 is offline Find More Posts by Wasp09
Discussion V200D01 Walkera 200 size FBL FP, yep another newy! Ampdraw Micro Helis 143 Apr 23, 2011 01:42 AM
Discussion Another new Walkera! HM 4F200 heli-parkflyer Micro Helis 84 Jan 08, 2011 02:40 PM
Discussion Walkera new 3D flybarless V400D02 Naev 3D Electric Heli Flying 2 Oct 31, 2010 08:50 PM
Discussion Walkera 2612V Rx on another heli - Review dkfuji Micro Helis 9 Aug 15, 2010 09:08 AM
Sold Celectra 4-Port Charger, Adapter, and batteries *ANOTHER NEW PRICE* lol Benf207 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jul 30, 2010 10:22 PM
