Old Sep 04, 2010, 12:43 AM
FlattyFlier is online now
Find More Posts by FlattyFlier
Team LightRC
FlattyFlier's Avatar
Joined Dec 2003
Help!
Need help, i need a switch!!
I need a switch/controller for my three stings of lights from HobbyKing.
I ordered the only Rx/Tx controlled on/off switch but it had two positive out leads on it, for what IDK.
How can I wire up the three strings of lights to run off the 2s lipo for the plane?
Could I just solder the leads all togather and connect them to an extra servo lead and plug them into an empty channel or do I need a switch??
I have a night-fly fly-in on the 25th and need this one going fast so its ready for the event!!
FlattyFlier is online now Find More Posts by FlattyFlier
Old Sep 04, 2010, 04:48 AM
Bilbobaker is offline
Find More Posts by Bilbobaker
Bilbobaker's Avatar
United States, UT, Salina
Joined Apr 2003
Follow the wiring diagram to the letter as those switches just interrupt the positive flow for switching.
The ground is pasted through.
Bilbobaker is offline Find More Posts by Bilbobaker
Old Sep 04, 2010, 09:37 AM
Team LightRC
Joined Dec 2003
I already tried hooking it up and nothing happoned. I dont have BEC either.
I think I fried that one anyway
Old Sep 04, 2010, 01:30 PM
VROOMSTER is offline
Find More Posts by VROOMSTER
AMA #953123
VROOMSTER's Avatar
Eugene, ORYGUN
Joined Mar 2009
Use a brushed ESC.
VROOMSTER is offline Find More Posts by VROOMSTER
Old Sep 04, 2010, 02:18 PM
Team LightRC
Joined Dec 2003
I was thinking about that but I heard that they reduce the brightness of the LEDs, even at full "throttle".
Old Sep 04, 2010, 02:29 PM
Bilbobaker's Avatar
Joined Apr 2003
Those leds strips are hurt your eyes bright at full power with a brushed esc.
Old Sep 04, 2010, 10:52 PM
Team LightRC
Joined Dec 2003
On 2s or 3s lipos, or does it matter?
And whats the smallest amp ESC I can get away with? I want everything as light as possible sense my plane came out a full once and a half heavyer than I wanted.
Old Sep 04, 2010, 10:56 PM
Bilbobaker's Avatar
Joined Apr 2003
They need 3s lipo for full brightness.
They are resistored for 12 volts.
Old Sep 05, 2010, 08:12 AM
Team LightRC
Joined Dec 2003
so a 12 amp esc? or can I use a smaller one?
Old Sep 05, 2010, 12:46 PM
Bilbobaker's Avatar
Joined Apr 2003
You can use a much smaller one they only draw about an amps worth of current at twelve volts.
Old Sep 05, 2010, 09:09 PM
Team LightRC
Joined Dec 2003
ok so as small as I want, thats good.
Old Sep 09, 2010, 09:12 PM
Belem is offline
Find More Posts by Belem
Foam flogger
Roseville, CA
Joined Apr 2009
HK Switch worked fine with my sets of lights. Once I grasped the wiring diagram it was pretty easy.
Belem is offline Find More Posts by Belem
Old Sep 09, 2010, 10:40 PM
Team LightRC
Joined Dec 2003
the two positivse threw me way off and I fried it trying to make it work.
Discussion Help, Fat Fingers, Need Help!! Pull Pull Set-up Tricks..Help thecirque Hand Launch 2 Aug 24, 2010 09:01 PM
Discussion Need some help.. 1st time lipo user paranoid about switch on. dirkyboy098 Batteries and Chargers 4 Jul 07, 2010 02:14 AM
Question hey everone, need some help agian, this time on idle switch. eskyruben Large Electric Helis 13 May 19, 2010 09:27 PM
Question need help on when to turn on idle switch. eskyruben 3D Electric Heli Flying 0 Apr 26, 2010 12:00 AM
Need Fuselage On/Off Switch Help RazorB Electric Plane Talk 2 Nov 10, 2001 09:36 PM
