Old Sep 03, 2010, 10:45 PM
aeronca52 is offline
Find More Posts by aeronca52
Culper Junior
eastern pa
Joined Feb 2007
Question
High Alpha/Angle of attack
Just a simple question-are High Alpha and a high Angle of attack one and the same? Could a particular kind of flight attitude be described by both definitions and be correct? Or are they different flight modes?
aeronca52 is offline Find More Posts by aeronca52
Old Sep 03, 2010, 11:06 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Alpha is just the Greek name for the letter A. So high alpha just means high angle (of attack).
The terms AOA, Alpha and Angle of Attack and Pitch attitude are r synonymous. Although in different airframe communities or different facets of industry one might be more fashionable than another.
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Sep 03, 2010, 11:15 PM
Chophop is online now
Find More Posts by Chophop
Turn that thing around...naaaa
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
It is a nose high attitude that puts the airplane in a difficult situation for a beginner. The plane will be near stall attitude or actually under stall, being held up by the propeller thrust acting like a heli rotor.
Chophop is online now Find More Posts by Chophop
Old Sep 03, 2010, 11:33 PM
gmohr is offline
Find More Posts by gmohr
gmohr's Avatar
New Jersey, USA
Joined Mar 2008
Not to be overly picky, but "Pitch attitude" isn't a synonym of the others. Pitch is the angle between the fuselage datum line and the horizon, where as AoA (or alpha) is the angle between the wing and the airflow. Those two values can differ if in climbing or decending flight, or when the airframe encounters lifting/sinking air, or if the wing has a non-zero angle of incidence (angle between the airframe datum on the wing) built in.
Regards,
George
gmohr is offline Find More Posts by gmohr
Old Sep 04, 2010, 12:13 AM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
+1 on gmohr...BTW..what are you? An aerodynamicist
KE Spin is offline Find More Posts by KE Spin
Old Sep 04, 2010, 01:57 AM
Threshold is offline
Find More Posts by Threshold
Threshold's Avatar
London UK
Joined Jul 2004
People also use High Alpha to describe knife edge which refers to the fuz, whereas AOA and Angle of Attack refer more to the state of the wing, perhaps actually pitch angle would be ok to use with KE.
Threshold is offline Find More Posts by Threshold
Old Sep 04, 2010, 02:13 AM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Threshold,
Just to parse you a little. HAKE (high alpha knife edge) is a type of knife edge...not all knife edge flight is high alpha.
High alpha knife edge is with nose high while knife edge can be with fuselage nearly horizontal with the ground. HAKE is flown slower with less throttle and more rudder while KE is higher speed and less rudder.
Gmohr, correct me if I'm wrong here. Pitch angle should actually be zero in linear KE flight. The "high alpha" in high alpha knife edge is actually refering to the yaw angle (or angle of attack of the fuselage rather than the airfoil). I don't think just because the plane in rotated 90 degrees in knife edge flight that the actual axes are relabeled.
Old Sep 04, 2010, 06:46 AM
Columbia SC
Joined Feb 2005
Regards,
George
No worries. Good point.
Old Sep 04, 2010, 08:00 AM
bilboa is offline
Find More Posts by bilboa
Joined Dec 2006
When you're flying KE, the fuselage effectively becomes the wing, in the sense that that's the part of the plane which is now producing lift. So I would say that doesn't really count as a different usage of AoA. I suppose you could generalize the definition of AoA by replacing "wing" with "lift producing part of the plane", as in
Angle of Attack: The angle between the main lift producing part of the plane (wing when upright or inverted, fuselage in knife edge) and the airflow.
bilboa is offline Find More Posts by bilboa
Old Sep 04, 2010, 08:15 AM
Irg is offline
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
don't some people refer to HAKE as "high beta"?
Irg is offline Find More Posts by Irg
Old Sep 04, 2010, 08:49 AM
sukhoi26mx is offline
Find More Posts by sukhoi26mx
Scott Stoops
sukhoi26mx's Avatar
United States, CO, Longmont
Joined Mar 2002
Yes. Alpha is a pitch based term, while beta is a yaw based term.
Scott
sukhoi26mx is offline Find More Posts by sukhoi26mx
Old Sep 04, 2010, 09:15 AM
Chophop's Avatar
Joined Sep 2006
So it's AABBA and your doing the cha cha ?
Old Sep 04, 2010, 10:45 AM
gmohr is offline
gmohr's Avatar
New Jersey, USA
Joined Mar 2008
Originally Posted by KE Spin View Post
Threshold,
This depends on the frame of reference that you chose. Typically though, we're using the earth axis as our frame, so "pitch" is the angle of the fuse datum line measured against the horizon. So in level KE flight, that datum is pitched up to provide lift, using the fuse side as a lifting body. Even though the plane has 90 deg of roll, it is still said to have, say, 15 deg of pitch. The axes "labels" are in reference to earth, not the airframe. A good illustration is a plane in a level climb with 10 deg of pitch. Roll that plane 15 deg left, and we'd still say it has 10 deg of pitch. Roll it the next 75 deg, and it still has 10 deg of pitch, etc..
It is possible to redefine the frame of reference to any arbitrary set of axes, so this isn't a hard rule, just a convention.
One other cool point to think about... in this instance, we've been talking about "pitch" with regard to "attitude", which is earth centric. We can also use the term "pitch" to describe rate of change of the plane's orientation, in which case the frame of reference is airframe centric. So if the pilot of that KE flying plane suddenly pulls a couple of G's, we can say that the plane has a "pitch rate" of 30 deg/second, while at the same time having a constant "pitch attitude".
Nope, but I've been told I have a slight obsession with details
Regards,
G
Old Sep 04, 2010, 07:04 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Looks like Scott and Gmohr have out shined the rest of us mere mortals so I declare a tie between them :-)
So, Scott and Gmohr, here is the tie breaker:
I'm driving along in my car at the speed of light. It starts getting dark so I turn on my headlights....What happens?
Old Sep 04, 2010, 08:53 PM
gmohr is offline
gmohr's Avatar
New Jersey, USA
Joined Mar 2008
I yield
Angle of Attack > Use Ideal or Best L/D? green66 Power Systems 14 Jun 18, 2002 06:59 PM
Wing angle of attack on Trike gear? Help pls! randallp Electric Plane Talk 3 May 02, 2002 07:57 AM
Angle of Attack for Best L/D >>> How to Decide? green66 Power Systems 1 Apr 10, 2002 02:09 AM
Angle of attack....puzzled.. Franck Foamies (Kits) 12 Nov 29, 2001 10:23 PM
Wing attack angle and other stuff tumad Power Systems 8 May 02, 2001 04:44 AM
