Old Sep 03, 2010, 04:22 PM
Croatia
Joined Jun 2010
Home made FPV parts..camera pod..antenna tracking..:D
Here is one of few home made projects;
EasyStar pod for video transmitter, batery and camera mount with pan-tilt option. All parts are from 3mm light plywood, cuted with laser, i make 2 diferent camera holders, one is for uncased 40×40 and KX191 and other for KX171/KX131 type, holes are for 9g servos like TG9 or HXT900;
With CA is assembled in 15 mins
p.s.
here are some pictures, some parts missing, probably will tommorow fix all on plane, now is camera fixed direct on servo arm
DavorVZ is offline Find More Posts by DavorVZ
Old Sep 03, 2010, 07:42 PM
Griffo's Avatar
Australia
Joined Oct 2003
Not sure I understand correctly. Are you claiming this design as your own?
Griffo is offline Find More Posts by Griffo
Old Sep 03, 2010, 07:45 PM
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Sure looks like a ReadyMadeRC pod to me... and I don't even own one....
galaxiex is offline Find More Posts by galaxiex
Old Sep 04, 2010, 03:35 AM
Croatia
Joined Jun 2010
no mate, design are combined from some what exist on market, even if you make your own design cant be lot diferent, must be similar;
i just working on mehanical parts to get pan servo travel 240 degrees or more, for tilt is ok 90.
Old Sep 04, 2010, 04:13 AM
Griffo's Avatar
Australia
Joined Oct 2003
p.s.
Ok when you were stating that the parts were all laser cut I assumed you were claiming the whole thing as your design... when it clearly isn't.
I'm all for scratch building but if you're going to copy someone elses design at least make a few changes to the base plate templates.
Old Sep 04, 2010, 04:36 AM
Croatia
Joined Jun 2010
all parts are created in Corel, this is test cuted pieces but is diferent als others in market, maybe you dont see now this, i will upload here plans for CNC in DXF and for laser in CDR then compare all
Old Sep 04, 2010, 06:06 AM
Flying like an Angel.
BlueAngel2000's Avatar
Austria
Joined Sep 2007
Yes, there is a small difference.
but not that much.
http://readymaderc.com/store/index.p...4c0pb4hrnuu5a4
BlueAngel2000 is offline Find More Posts by BlueAngel2000
Build Log My home made FPV system: OSD+diversity+telemetry+tracking antenna+autopilot+IMU+PC Zbig Video Piloting (FPV/RPV) 102 Sep 25, 2011 01:15 AM
For Sale 8GB Vado High Def Video camera with POD crd Aircraft - General - Miscellaneous (FS/W) 2 Sep 23, 2010 09:26 PM
Discussion Camera tracking instead of antenna tracking jphong Video Piloting (FPV/RPV) 2 Nov 15, 2009 03:08 PM
