Old Sep 03, 2010, 06:26 AM
slingsbyskylar is offline
Find More Posts by slingsbyskylar
slingsbyskylar's Avatar
Joined Dec 2009
Build Log
80" fournier rf-4d motor glider
hey all
this morning i had a nice big box turn up on the doorstep and of the best kind-filled with aircraft lol
Plan is to power her with a asp .25 turning a 10/4 zinger not sure on servo's and batterys as of yet
For now i'll let the pictures do the talking any questions or sugestions welcome
instructions basic but ok
wing underside
tail feathers
main gear and out-riggers
suplied aileron control rods and horns (horrid soft brass)
firewall and bolts
wore ikky brass horns
bendy wing joiner that will be replaced with solid ply
binned
so on moving the ruder the hinges puled out gunna have to work on replacing the lot
over all it looks ok feels very solid and very light, the cowl on the other hand is rubish ill fitting and made from thin plastic also will probably melt if put near the engine any 1 know where i could find a good cowl making 1 may not realy be an option, the covering is actualy not that bad nice and tight but the red is printed on the covering and looks horid close up i way rip it off and use ultracote or solartex and fuel proof it im going to fuel proof the inside incase of acidents hopefully going to get this bird under 2kg auw
skylark
slingsbyskylar is offline Find More Posts by slingsbyskylar
Old Sep 09, 2010, 07:26 AM
solitairyman is offline
Find More Posts by solitairyman
solitairyman's Avatar
Antwerp, Belgium
Joined Oct 2007
Rf4
Hi,
see to all parts but in the end it will fly great!!!
You could build in a scale landing gear too.
See for aironaut site. I think it would be as big as yours.
see the pictures I took some time ago and it could be servo opperated as well.
The two wheels under the wings don't need more wire then those in the box.
Good luck ,
NoŽl
solitairyman is offline Find More Posts by solitairyman
Old Sep 10, 2010, 04:32 AM
kenl40009 is offline
Find More Posts by kenl40009
Joined Jan 2007
You may find this forum useful for some of the problems encountered with this kit - nothing really bad but some good points to look for
http://www.modelflying.co.uk/forums/...s.asp?th=36595
kenl40009 is offline Find More Posts by kenl40009
Old Sep 23, 2010, 08:32 AM
iamrandy is offline
Find More Posts by iamrandy
Joined Feb 2006
Am trying to locate the landing gear for this plane in the US. I have built the 1/4 scale Mick Reeves Fornier, and wondering if it would fit. Any help would be greatly appreciated.
iamrandy is offline Find More Posts by iamrandy
Old Sep 23, 2010, 10:36 AM
Antwerp, Belgium
Joined Oct 2007
RF4 landing gear
Hi Randy,
This is a Aeronaut kit.
http://www.aero-naut.de/produkte/flu...ier-rf-4d.html
Could not find anything on the retractable gear though.
You can email them and see what happens.
I do have a drawing of a French RF4 1/4 scaled and there is a drawing in. I can try to copy all in PDF if you still need it PM me then.
I whish you good luck,
NoŽl
Sold 1970's Fournier rf 4d motor glider kit punkrockd Aircraft - Sailplanes (FS/W) 6 Feb 28, 2010 09:35 PM
Discussion Fournier RF-10 powered glider east6008 Scale Kit/Scratch Built 4 Jul 12, 2007 09:14 AM
Wanted Fournier RF-4 - Motor Glider Lewis Adam Aircraft - Electric - Airplanes (FS/W) 0 Aug 04, 2006 10:06 PM
1:4 Scale Fournier RF-4d Arc kit 110" on- Ebay Joe Pierson Aircraft - Sailplanes (FS/W) 6 Apr 04, 2004 03:34 PM
Fournier RF-4D Thorsten Fuel Plane Talk 0 Dec 27, 2003 12:42 PM
