Build Thread - Pixie 20" Symmetrical Electric Flying EPP Wing
This build thread is intended to be an all inclusive how to for building the Pixie 20" Symmetrical flying electric wing. As my intention is to present this as if this were a person's first scratch or kit build, some of the information may be too basic for some in the beginning. I will attempt to present as many techniques and approaches as necessary to build the plane well, but invite other ideas also. Enjoy!
Pixie The Pixie flying wing has been designed to be a fun aircraft that is inexpensive, exceptionally durable, great flying and easy to transport. The use of inexpensive components embedded within the 20 symmetrical EPP wing makes the Pixie the perfect choice for recreational flying, small course pylon racing, or full on combat. The comprehensive, photograph rich, construction thread covers all aspects of the assembly and setup process so that even inexperienced builders can successfully construct the Pixie with good results. Particular attention was given to durable, low drag construction that places the servos completely inside the wing and shields the push rods and control horns from wind drag and damage. The high lift, low drag airfoil provides predictable flight characteristics over a wide range of speeds and wind conditions, while accepting large control deflection for maximum aerobatics with minimum drag. Specs : Wing : 20 1.3# EPP Airfoil : Symmetrical CG3S Typical AUW : 5.5-6.0oz Wing Area : 110 sq.in Wing Loading : 7.2-7.9oz/sq.ft
Prepping the Wings :
Materials Required : Wing block, scrap foam ( if desired ) Gently separate the wing cores by starting at the leading edge and running your fingers between the wings and husks. Proceed slowly across the span toward the trailing edge with each pass to release any adhesion between the foam pieces. In order to prevent tearing, be particularity careful as you approach the trailing edges of the wings as they become thinner and more fragile. Remove any foam whiskers that remain from the cutting process from the wings and the inner surface of the outer husks by using your fingers and/or a scrap piece of foam. The outer husks need to be clean as they will be used in the building process repeatedly.
Creating the Component Pockets/Recesses :
With the gear locations marked on the top of the wing, lay the plane in the two husks so as to support the wings firmly on a flat surface. Using a rotary tool in a router attachment with a flat stone bit , if available, route a cavity for each component just barely deeper than the item being fit so it will fit below the contour of the airfoil. This is particularly important for the servos as they will be “potted” in a future step, which will consume a minor, but present, amount of height. Begin with the smallest components first so as not to route away the router base support which would make the process more challenging. ( Note : If you do not have access to a rotary tool router, you can mark the item depth on the stone bit with a piece of tape and lay a piece of paper over the wing to serve as a depth guide for freehand routing. If using a razor knife, mark depth on the blade and cut the perimeter first, then carefully remove the foam in the pocket with pliers. For a smoother floor, it can be melted smooth with a hot knife by hand. ) Repeat this pocket routing process for each component except the motor and confirm proper fit making each component just below flush with the upper surface of the airfoil. The placement of the motor should allow approximately 1/4” air gap forward of the motor and the aft end of the motor canister should extend beyond the trailing edge of the foam about 1/4” as well for cooling and clearance purposes. It will be necessary to cut full thickness through the wing in the location of each servo arm, as the servo arm is directed down into the wing and the push rod connections will be made from the bottom side of the wing later.
Cutting the Motor Mount Pocket :
Materials Required : Ruler, marker, squared blocks, masking tape, weights, motor mount cutting tube from previous step, stack of paper, motor ( for test fit ) Place the wing firmly in the beds on a flat surface with the center line of the wing along a straight line marked on the table or paper underneath. Mark the center of the wing and motor location, height-wise, and measure the distance down to the table. Take a tube approximately 1mm smaller in OD than the OD of the motor case, which will be used as a hole cutter for the motor mount, and subtract its radius from the same value of the wing center. This value represents how high the cutting tube needs to be shimmed up off of the table to center the motor pocket into the center of the wing straight and level. ( In practice, the motor doesn't need to be perfectly centered, just straight and level relative to the center line of the wing halves and cord line. ) Lay the cutting tube along the center line behind the plane and shim up the entire length of the tube with a stack of paper equal to the calculated height performed earlier to bring the center of the cutting tube to the same level as the center of the wing at the trailing edge. Secure the tube into position between a couple pair of squares, blocks, or brackets to keep things in place and apply some weight onto the cutting tube as well to keep it down against the paper shim. A couple of weighted bags will keep the tube down yet allow it to turn during the cutting procedure. Slowly rotate the cutting tube while feeding it into the trailing edge of the foam at the center of the wing. The tube will slowly cut a cylinder out of the foam wing as you progress and push a plug into the tube. You should be able to perform the entire cut in one plunge. Cut the tube to the mark of the most forward portion of the motor canister, not up into the air space. We will cut this in later so as to keep the motor from being able to ride up into the extra space. With the #11 razor knife, cut the leading edge of the foam plug core to free it from the wing without ripping. Remove the plug from the cutting tube and discard. Test fit the motor into the mount pocket. It should have a mildly snug friction fit yet be adjustable for centering. Bevel the trailing edge of the motor cutout pocket to the center line from top and bottom.
Fitting the Spars :
Materials Required : Wing, wing bed, weights, ruler, spar stock ( Carbon Fiber Strip .019 x .118 x 24 / .5mm x 3mm x 610mm ), fine tip marker, straight pins, razor knife with old #11 blade, flame ( heat source ) Place the wing, bottom side up, into the beds and weight it down to force the wing straight. Since the Pixie is symmetrical, the beds will properly support and align the wing. Close to the tips, insert two ( 2 ) pins into the foam at the spar mark on either side of the carbon fiber ribbon spar with the narrow edge of the spar facing up to hold the spar in place. Repeat on the other wing. Bend the spar forward along the center until the spar is tangent to a line 1 behind the leading edge and pin in place along the length of the spar. ( Note : If using different radio gear, the bend of the spar may need to be altered to place the center in a location of sufficient foam depth.) Mark along one edge of the spar with a pen onto the wings to record position in case the spar is removed before the spar channel is cut. The spar shouldn't run to the very tip and should stop 3/4 shy at each tip, thus the spar channel will also be a little less than the full wingspan. The remaining flat carbon is to be used as the secondary spar, which is placed centered 1/4 forward o f the motor. Rather than just cutting a slot to push the carbon fiber ribbon spar into the wing, which would deform the airfoil slightly, foam will be removed to allow space to accept the spar material using an old #11 razor blade. By heating the blade momentarily, the application of the blade into the EPP foam will melt a small portion of foam away which will create the spar channel needed. The channel needs to be only deep enough to allow the spar to be fully recessed below the airfoil surface, but no more. With the spar pinned in place upon the wing, momentarily heat the #11 blade in a flame and guide it along the bent carbon fiber spar along either the forward or aft side. Only cut a few inches at a time and turn the blade slightly to widen the path a little. Do not get the blade excessively hot during the cutting and practice on a piece of scrap to get a feel for how fast the foam will melt. Continue along the path of the spar, bypassing the location of the pins, then reposition the pins and complete the path. Press the carbon ribbon into the slot to test the fit, then cut to length. The remaining piece of the carbon fiber ribbon spar material will serve as a secondary spar which is positioned just forward of the cooling vent of the motor ( i.e. 1/4 forward of the motor ), also along the bottom of the wing. The length is relatively arbitrary, so just use what you have left over from the spar stock and center it from side to side. Cut the spar slot the same way as with the main spar to allow full burial. Gluing the Spars in Place : Materials Required : Wing, wing beds, weights, spar material, Goop and applicator ( toothpick ), low temp hot melt glue and gun, light weight spackle and sand paper ( as desired ) With the wings pressed firmly into the wing beds on a flat table, confirm the fit of the spars then press a thin layer of Goop into the spar slot along the entire length. Firmly insert the spars into the slots and secure the spar in place and fill in any gaps with low temp hot melt glue. Wipe away any excess hot melt glue while still warm. This will hold things still so you can keep working while the Goop dries over the next 24 hours, but overnight drying under the pressure of weights is preferred. Repeat this procedure for the shorter aft section spar/doubler as well. Light weight spackle can be applied to fill in any voids in the foam along the spar to smooth things over, sanding as needed.
Cutting the Wiring Paths :
Materials Required : Wing, servos, receiver, battery, ESC, razor knife with old blade, flame Due to the the fact that the Pixie's size makes it a thin wing, most of the wire routing will need to be run just below the surface level. Decision Time : To decrease the final weight of the plane and minimize the difficulty of fitting a lot of gear in a very small space, it can be advantageous to re-size the servo leads, ESC leads, and even solder the motor to the ESC directly. The extra wire and connectors, if left in place, can become challenging to run otherwise, but not impossible. Creating wire paths and pockets may be done by several methods such as routing with a rotary tool or burning with a hot knife. Remove just enough foam to allow each component to reside below the foam surface while providing access to critical areas such as the receiver plugs, battery, and power connection. Once satisfied with the component placement and access, each item ( except battery, which should remain removable ) can be tacked in place with a small drop of low temp hot melt glue. Potting the Servos : Materials Required : Servos, scissors, plastic sandwich bag, 30 minute epoxy, micro balloons, stir stick and applicator, mixing cup, 2 small blocks or nuts slightly smaller than the size of the servo case, a board, weights Potting the servos into the EPP foam allows a more rigid attachment that will stay tight over time and help prevent development of slop in the controls. Place the servos, with servo arms removed, into the pockets routed in the earlier steps to confirm proper fit. Cut two ( 2 ) small, single layered squares out of the sandwich bag about twice the size of the servos and set aside. These bag pieces will serve as a release film in the next step which will allow the removal of the servos after potting. Mix a relatively small quantity of 30 minute epoxy in your mixing cup and add the micro-balloons ( talcum powder can also be used, with varying results ) until it forms a moderately thick paste about the consistency of peanut butter . The epoxy needs to be pretty thick for potting to work well. ( Note : The addition of the micro-balloons to reach this consistency drastically shortens the pot life of the epoxy, making it necessary to work faster. For this reason, 5 minute epoxy is not suggested when potting servos in this manner. ) Apply a generous layer of splooge ( epoxy and micro-balloons ) into main area of each servo pocket where the case of the servo will rest into the foam. Do not place too close to the spline region as it will just need to be removed later. Make sure to apply a good layer of splooge at the servo tabs, but leave a little space dry at the area where the servo lead exits the case for give on the wiring. With each servo pocket layered with the splooge mixture, lay the small squares of sandwich bag over the servo pocket and firmly press the servos down into the pocket, trapping the bag between the foam and the servo. This will keep the servo from being epoxied in place. Position the small wooden blocks or nuts onto the case of each servo and then place the board across both blocks. This will force the weight onto the servos and ensure they seat firmly into the foam without deforming the foam around it. Apply a little weight onto the top of the board to press the servos in to the foam pockets and allow to cure at least an hour. ( Note : While the micro-balloons tend to speed up the exothermic reaction and pot life of the splooge mixture, it also seems to lengthen the final cure rate a bit, so be patient here. Let the epoxy fully cure before proceeding. ) After fully cured, remover the weights, board, nuts and gently remove the servos from the wing. Remove the plastic bag to reveal a form fit hardened pocket in which your servos will pop into place and not shift around. Clean up any excess dried splooge with a razor knife and/or rotary tool with the flat stone bit used for routing the pockets.
| Thread Tools | |
| Cool New Mini FuntanaX from e-flite (official build thread/ flying thread!!) | p51flyer | 3D Flying | 1709 | Apr 22, 2013 05:13 PM |
| New Product ICON flying wing, NEW KIT CONCEPT & BUILD THREAD from Jarel Aircraft Design | jarel design | Flying Wings | 202 | Mar 02, 2012 08:55 AM |
| Sold Flying Wing - Rightway Build | RickAir | Aircraft - Electric - Airplanes (FS/W) | 8 | Mar 25, 2011 04:47 PM |
| Discussion My first scratch build, EP trainer build/advice thread. | WLJayne | The Builders Workshop | 25 | Oct 05, 2010 03:05 PM |
| Discussion Mammoth Flying Wing 2nd Build Thread | Darth_Elevator | Utah Flyers Organization | 7 | Dec 01, 2009 08:01 PM |
