Old Mar 26, 2013, 09:47 AM
SJo1 is offline
Find More Posts by SJo1
Joined Oct 2008
Small update for instructions.
I have changed those 4mm bullet bushes with EC5 connectors.
Also drilling through contact for bridging, I have not seen any issues with that as there is through connections already.
I have made several of these during past days, no issues found.
Trickies part is to make second unit to "no DC gnd" as all three screw connections on bottom has to be made non connecting to minus pad.
If there is continuity and you just believe that you scored the build. Just plug mains connection first to power and then to wall, whoopii and You blow your fuse, or even burn Your house.
So be careful with connections you made!
Stay safe.
Regards
Sami
SJo1 is offline Find More Posts by SJo1
Old May 09, 2013, 10:45 AM
darkfa8 is offline
Find More Posts by darkfa8
darkfa8's Avatar
United States, NJ, Brick
Joined Jul 2005
To isolate the DC ground from the case, can't you just disconnect the AC line input ground ring terminal that is near the AC input connector?
darkfa8 is offline Find More Posts by darkfa8
Old Jun 09, 2013, 08:43 PM
Topangler is offline
Find More Posts by Topangler
Joined Sep 2012
Help With DPS800GBA
Does anyone know if the DPS800GBA has a fuse inside, I had two of these connected together (One floating) for a 24V+ charging station, the floating ground unit has stopped outputting power, the fans still spin but the green LED does not light up and there is no power output.
Topangler is offline Find More Posts by Topangler
Old Jun 28, 2013, 03:28 PM
culexus is offline
Find More Posts by culexus
Norway Haugesund
Joined Jun 2010
Yes it has one fuse on the AC power it`s located near the ac power input and covered with a black shrink tube. But if the fan still going this fuse must be in order.
culexus is offline Find More Posts by culexus
Old Jun 29, 2013, 08:17 AM
Joined Sep 2012
Thank you for the info re the fuse, I checked it and its good so now I'm stuck, no idea why the fans spin but no power out put.
Any help or ideas would be appreciated.
Old Aug 14, 2013, 03:24 PM
coolice is offline
Find More Posts by coolice
RobbeUK & Midland Helicopters
United Kingdom, Rushden
Joined Dec 2005
ATSN 7001044 Keeps Shutting Down
Evening guys.
I hope you can help me perhaps.
I've started making these up to order and inadvertently got sent some DPS-800GB's and ATSN 7001044 PSU's, so I thought great as I could have a play.
Well the play meant messing two up and possibly this one ATSN 7001044, should have read further about the multi layer tracks ooops.
Anyway, I half messed up one of the ATSN 7001044's floating the DC earth points, the centre point may have gone too deep into the pcb and severed some copper tracks.
However it is working (sat beside me now working away in fact) but every so often it shuts down. I've since found out that if I leave it, it comes back on again.
I've read about the caps possibly going bad, found one bulging and so have replaced all of them with the same ratings if just a different make, including the large AC caps as well from the previously working DPS-800's I shorted out.
But this has not helped and while I'm confident to poke around being a former engineer by trade, fault finding what could possibly being wrong now is eluding me.
Any ideas will be greatly appreciated.
Ian
coolice is offline Find More Posts by coolice
Old Sep 15, 2013, 08:54 PM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
Just a quick question here.
After isolating the DC on the 2nd PSU i plugged it in to test. I measured 190v over the case and the positive terminal. . The voltage rose over 5 seconds to 190v.
What have i done wrong here or is it because i did not have the first PSU connected?
I am reluctant to continue until sorting this out
lipoflyer is offline Find More Posts by lipoflyer
Old Sep 15, 2013, 09:55 PM
lipoflyer's Avatar
Australia
Joined Nov 2010
After following the rest of the instructions all is good. 25V and all the amps my 3010B can eat
Old Sep 16, 2013, 09:37 AM
Quadrant is offline
Find More Posts by Quadrant
United Kingdom, London
Joined Feb 2013
I have managed to save 4 of these DPS-800's from being scrapped when servers got decommissioned at work.
Anybody interested in buying them?
Can sell them as-is (no mod) or modified for hobby use as per SJ01's method. I've modded 2 for myself using that method previously and they still working like a charm. See my post earlier in this thread.
UK buyers only unless you prepared to pay crazy shipping fees.
Quadrant is offline Find More Posts by Quadrant
Old Nov 22, 2013, 06:20 PM
paedbo is offline
Find More Posts by paedbo
Joined Mar 2005
can someone help me on the isolating the dc on the second supply. I am a bit confused. am I just removing the grounding connection from the case to the pcb where the standoff's are? Then what point do I test from with the multimeter? case to the ground on the pcb?
paedbo is offline Find More Posts by paedbo
Old Nov 25, 2013, 08:50 PM
BossRoss is offline
Find More Posts by BossRoss
Joined Nov 2013
Would having the hot-swap backplane make any of this easier? I have the ML350 from where I pulled the supplies. I believe it's HP part# 413144-001.
BossRoss is offline Find More Posts by BossRoss
Old Nov 25, 2013, 08:53 PM
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Unlikely. The whole point is to disconnect the DC out on the second supply from the metal case of the supply. Adding a back plane connector won't change that problem, I think.
Might make the connection of power and control pins a bit neater and easier though.
To answer the second question, you need to check there is no connection between the -Ve DC output of the supply and its metal case. It is also wise to check there is no connection between the -Ve DC out and the ground pin on the input mains connector.
jj604 is offline Find More Posts by jj604
Old Nov 25, 2013, 09:02 PM
paedbo is offline
Joined Mar 2005
thanks. I will check and disconnect continuity between the ground output of the second supply with the case. and then check continuity between the mains ground and the case and do the same.
Old Nov 29, 2013, 03:32 AM
rchelijc is offline
Find More Posts by rchelijc
Pro beginner
rchelijc's Avatar
Joined Aug 2010
I'm a big fan of these units based on power to for factor, and currently using a pair for 2kW power to supply a PL8 and a icharger.
What I'm curious to know is, has anyone experienced failure of the switching circuits such that mains voltage passes to the terminals? Especially the floated unit..
If you have experienced this for this or any other reputed server power supply, please chime in. Data like this is pretty hard to come by. This topic was debated elsewhere, but the conclusion was more around compliance and safety vs actual data points. I posted this question in the DPS -600 thread as well. Not trolling, just want to hear your experiences.
rchelijc is offline Find More Posts by rchelijc
Old Jan 27, 2014, 11:38 PM
klondike_bar is offline
Find More Posts by klondike_bar
Joined Jan 2014
I have just modified a DPS-800GB A power supply following the instructions;
pins 31 + 34
pins 30 + 12V
and testing without load i see a voltage of 12.8V - without the 30+12V pins shorted, voltage seemed much closer to 12.0V
I do NOT want >12.2V since this is for computer components rather than RC battery charging - Is the pin 30+12V connection designed to achieve a higher (12.8V) output, or will it drop to 12.0V once a load is applied?
klondike_bar is offline Find More Posts by klondike_bar
Discussion Getting a Compaq HP DL580 Proliant Server Power Supply to Work earlwb Batteries and Chargers 544 Feb 22, 2016 04:10 PM
Help! HP Server Power Supply conversion memory Batteries and Chargers 4 Feb 14, 2016 01:47 AM
Discussion HP ESP113 Power supply feathermerchant DIY Electronics 1 Mar 09, 2009 05:40 PM
Question Can I charge packs with an industrial HP power supply ? yshimoni Batteries and Chargers 6 Nov 15, 2003 08:28 PM
hp 6216a power supply!!! wolfance Power Systems 0 May 19, 2003 03:08 PM
