Old Jan 11, 2012, 11:17 PM
s.nase is offline
Find More Posts by s.nase
s.nase's Avatar
Bundesrepublik Deutschland, Berlin, Berlin
Joined Feb 2011
That sounds like a faulty standby voltage.
Even if you just plug the power cord, the standby voltages must be present. This is a common mistake, since the power supply (old version) in standby mode quickly overheat.
s.nase is offline Find More Posts by s.nase
Old Jan 20, 2012, 02:40 AM
pdnb is offline
Find More Posts by pdnb
Joined Jan 2012
i have the same problem as pithiki . Even i contect 32 to 34 pin and 31 to +12V power supply doesn't work (green LED not on). I check all pins for stby but nothing
Ps. I have old version of power supply
pdnb is offline Find More Posts by pdnb
Old Feb 12, 2012, 01:34 AM
Dan e is offline
Find More Posts by Dan e
Joined Aug 2011
I have the same dps-800gb power supply and the same issues.
If nothing is connected to it at all should the little green light be on? I presume also I should have some kind of voltage on something right?
Dan e is offline Find More Posts by Dan e
Old May 22, 2012, 01:41 PM
Trank is offline
Find More Posts by Trank
Joined May 2012
Try from this link recommendations http://translate.google.com.ua/trans...mment%2F270763
Trank is offline Find More Posts by Trank
Old Aug 24, 2012, 11:16 AM
SJo1 is offline
Find More Posts by SJo1
Joined Oct 2008
I manage to get these working in series and works fine.
Simply
1. Take bonnet away
2. release mains connector from case and unscrew GND.
3. separate internals (open corner screws)
4. put it to table as bottom up, connector strip towards you.
5. locate small 8 pin connector at left side (topside near fans)
6. solder jumper between pin1 (deep purple) and pin4 (tan) (these are pson / pskill so pins 31+34
7. solder jumper from pin5 (light brown) and +12V (left side long connector strip) (pin 30 to +12V)
To make 25V 2000W 82A (240V) system
Prepare another power supply to same stage.
Mark one to 12V and second 24V
Now we should have two 12V power supplies ready.
Take DC ground out from 24V power supply, by removing copper layer from power strip end both sides (from bottom left and right and top left and right)
verify that yo dont have connectivity to mains ground from power strip long middle strip. Be carefully when removing copper as PCB has copper in 3 layers.
If You managed to make 24V PS as DC isolated concratulations, time to put internals back to cases.
Now put 12V case to table as botton up and 24V case to top of 12V case as top up and line cases parallel. (power strips towards You.
Tape power supplies together with glass fiber reinforced tape.
Drill 3.5mm hole to long left top power strip so that it goes through lower long left power strip. (this is going to be the parallel bridge between power supplies)
I used leftover hexagon from HP DPS 600GB that is located in +12V and GND.
Then prepare power connectors from 4mm bullet tube to be soldered in 12V gnd side long power strip on the bottom right (prepare these bullet tubes by dremeling 1.5mm wide in middle of solder end) put these bullet tubes proper place and solder them.
Put heat shrink insulator over bullet tubes and shrink with heat gun.
Cover power strips with pvc heat shrink (120mm wide) 15mm long piece.
Cover whole PS case with pvc heat shrink (200mm wide) length of Power supply is 215mm, so cut 230mm long piece.
Pull cover over and position it so that both ends have same amount over the case.
Start heating from the ends, keep heat gun around 200mm away of pvc covering, as it's easy too screw it up by too high heat and keeping heat gun too close.
Now You have nice and neat 25V 2000w 82A power supply ready for feeding all Your charging needs
Only minor negative thing is that sourcing these power supplies can be pretty expensive in ebay or another places.
Regards
Sami
SJo1 is offline Find More Posts by SJo1
Old Oct 24, 2012, 06:55 AM
davekra is offline
Find More Posts by davekra
Milwaukee G Mitchell, Wisconsin, United States
Joined Mar 2002
I've got a couple of these but have a question...Jumpering the pins like in the pic above, the supply turns on and the fan runs slow. Good so far.
Does the fan speed up as the load/heat increases?
I haven't had an opportunity to do any real tests on it and am bored at work.
davidk
davekra is offline Find More Posts by davekra
Old Oct 24, 2012, 05:22 PM
whitedg is offline
Find More Posts by whitedg
Australia, NSW, Rydalmere
Joined Feb 2010
Yes, the fans on these PSU's are thermal control, so they ramp up as they are needed. No need to "short pin 4 to ground" link on the DPS-600pb supplies.
Cheers
Whitedg
whitedg is offline Find More Posts by whitedg
Old Nov 24, 2012, 07:56 PM
JKing3 is offline
Find More Posts by JKing3
Joined Sep 2012
Sjo1, can you expand on how you remove the DC ground by removing the copper layers? Some pictures would be helpful.
Thanks.
JKing3 is offline Find More Posts by JKing3
Old Nov 27, 2012, 06:51 PM
s.nase is offline
s.nase's Avatar
Joined Feb 2011
insulating washers FET on both sides of the PCB. The threaded post in the case contract by 2mm.
Old Mar 06, 2013, 07:03 AM
DirkJan is offline
Find More Posts by DirkJan
The Netherlands, ZH, Hendrik-Ido-Ambacht
Joined Jan 2012
Can I drill a hole in the GRD and 12V connector to fix the 12V and GRD cable with a cable lug?
DirkJan is offline Find More Posts by DirkJan
Old Mar 07, 2013, 03:02 AM
Felborn is offline
Find More Posts by Felborn
Norway
Joined Jul 2008
I would not recommend it, there is a third layer of copper in the middle of the board, not sure if that would short circuit the whole thing
Felborn is offline Find More Posts by Felborn
Old Mar 07, 2013, 06:21 AM
DirkJan is offline
Joined Jan 2012
Thx Felborn!
somewhere in my mind there rang a bell "multilayer" ..
Hereby a schema for also using the the 3.3V (8A max) and 5V (2A max)
Old Mar 07, 2013, 07:30 AM
still4given is offline
Find More Posts by still4given
Sky Pilot
still4given's Avatar
Victorville, CA
Joined Jun 2006
Simply
1. Take bonnet away
Regards
Sami
Are you actually pulling 2000w from those 4mm bullet connectors? Seems they would fail at that current.
still4given is offline Find More Posts by still4given
Old Mar 11, 2013, 08:36 AM
s.nase is offline
s.nase's Avatar
Joined Feb 2011
No!
Between the upper and lower contact pad to GND and +12 V run further conductor tracks (multilayer wiring board). Definitely not a drill hole through the pads. You have the upper and lower contact connecting from the outside to each other. The easiest way is with a small brass corner (solder). Top solder the sockets. Solder down the brass corner, and with the sockets connect (solder).
A 4mm connector compatible only 40A permanently. With two 4mm sockets 85A are no longer a problem.
Old Mar 14, 2013, 07:55 AM
Quadrant is offline
Find More Posts by Quadrant
United Kingdom, London
Joined Feb 2013
17V output??
Thx Felborn!
Thanks firstly to SJo1 for the steps posted to turn these on.
I have mananged to get a single DPS-800GB unit running by using your method.
Dirkjan, thanks to you for identifying the pins for 3.3V and 5V.
Question:
Could I possibly get 17V out of a single DPS-800GB with a usable Amperage for lipo charging?
As I understand it, you'll firstly need a -12V, which this PSU does not seem to have, and even then you are limited by the 2A on the +5V rail, correct?
Or would my only option be to build 2 of them in series and then somehow dial the Voltage down to get 17V, since 24V in too much for the charger.
It is to feed a Turnigy 400W 20A Lipo Charger at full capacity. Input is 11V to 17V only.
Much thanks for any help in the right direction.
Quadrant is offline Find More Posts by Quadrant
Discussion Getting a Compaq HP DL580 Proliant Server Power Supply to Work earlwb Batteries and Chargers 544 Feb 22, 2016 04:10 PM
Help! HP Server Power Supply conversion memory Batteries and Chargers 4 Feb 14, 2016 01:47 AM
Discussion HP ESP113 Power supply feathermerchant DIY Electronics 1 Mar 09, 2009 05:40 PM
Question Can I charge packs with an industrial HP power supply ? yshimoni Batteries and Chargers 6 Nov 15, 2003 08:28 PM
hp 6216a power supply!!! wolfance Power Systems 0 May 19, 2003 03:08 PM
