Old Sep 02, 2010, 12:07 PM
United States, GA
Joined Jun 2006
Hp DPS 800gb a power supply
Anyone know how to get this puppy fired up for hobby use? Its 850w when on a 110-120v system. If plugged up to 200 -240v its 1000w it has the standard =12v, 3.3 vsb, +5 vsb, and -12v. Any advice?
Nocept1 is offline Find More Posts by Nocept1
Old Feb 09, 2011, 01:12 PM
pos
Joined Sep 2009
Did you solve it? Asking as I have one as well...
/P-O
pos is offline Find More Posts by pos
Old May 08, 2011, 04:23 AM
Norway
Joined Jul 2008
I'm also trying to figure this one out, it's very powerfull and very small, so it perfect... If I could only turn it on
Felborn is offline Find More Posts by Felborn
Old Jul 28, 2011, 06:26 AM
Near Kingston, Ontario, Canada
Joined Dec 2004
Did you manage to solve your problem. I have one as well and really would like to get it running.
Dave
376782 is offline Find More Posts by 376782
Old Jul 28, 2011, 08:20 AM
Rugby, UK
Joined Feb 2007
There has been a lot of posts about the Hp DPS600 psu and I have converted several. Chances are that the DPS800 is the same family and may well have the same connector layout as the output voltages are the same. Have a look at http://www.rcgroups.com/forums/showt...ps+600&page=21.
I posted on mine on post 312 and Mark Forsythe posted the connector pin plan on post 316. If the connector looks like the one in his post then almost certainly the same pin connections specified on my post will bring it to life.
Wayne
Wayne Giles is offline Find More Posts by Wayne Giles
Old Oct 03, 2011, 12:43 AM
Australia, NSW, Rydalmere
Joined Feb 2010
Guys, I've started to get my hands on a few of these supplies as we decommission HP DL380G5 servers at work. Anyone managed to get them powered up yet. The ones I have a the 800W version, but the small size and 65A @ 12v is nothing to sneeze at.
Cheers
whitedg
whitedg is offline Find More Posts by whitedg
Old Oct 20, 2011, 01:35 PM
Joined Dec 2004
HP DPS-800GB Power Up Solution
Finally after several attempts to get the supply to hold voltage with load I believe I have the answer. Instead of jumpering pins 30, 31 and 34 together just jumper 34 to 31 and tie pin 30 to +12V. So far I can now load up to 45 amps and the output drops just 100mv (12.9V to 12.8V). I do believe I will have a double gin and tonic to celebrate. I had almost given up and tossed the supply. Now I hope I can get more as I believe this is one nice compact supply capable of delivering 65 amps. I plan to series up a couple for 24V which be a piece of cake seeing as the negative is not tied to chassis ground.
Old Dec 05, 2011, 05:58 PM
Joined Dec 2011
I have the same Power supply. Do you have a picture of the DPS800 connections. I do not want to screw this up and your help is appreciated
StevenFox950 is offline Find More Posts by StevenFox950
Old Dec 05, 2011, 06:32 PM
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
That seems to be quite a PS.
Is this the one you have?
This thing will put out 70AMPS at 12V for 117VAC in!!
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Dec 14, 2011, 07:41 AM
Joined Dec 2011
Works great
running great at 80 amps (220v)
anderst001 is offline Find More Posts by anderst001
Old Jan 03, 2012, 03:42 AM
s.nase's Avatar
Bundesrepublik Deutschland, Berlin, Berlin
Joined Feb 2011
Small, lightweight and quiet
s.nase is offline Find More Posts by s.nase
Old Jan 03, 2012, 10:00 AM
RC Helicopter Pilot
Joined Mar 2010
Does this work wired this way?
This looks like it would short out to me.
Old Jan 03, 2012, 04:15 PM
s.nase's Avatar
Joined Feb 2011
The central connection of the grounding works without problems. You can also disconnect the DC voltage with a capacitor from the grounding.
Old Jan 03, 2012, 04:33 PM
RC Helicopter Pilot
Joined Mar 2010
I see it.
I missed the 2 breaks in the black line.
Old Jan 11, 2012, 12:50 AM
Joined Jan 2012
I have two of those scavenged but i have the feeling none of them is working.
when i plug them i get no voltage on any pin. I connected pin 31 to 34 and 30 to +12v and still the psu doesnt start. Am i doing something wrong? Should there be voltage on at least one pin when i plug the psu to powersocket?
pithiki is offline Find More Posts by pithiki
Discussion Getting a Compaq HP DL580 Proliant Server Power Supply to Work earlwb Batteries and Chargers 509 May 05, 2013 02:34 PM
Help! HP Server Power Supply conversion memory Batteries and Chargers 3 Aug 29, 2010 12:15 AM
Discussion HP ESP113 Power supply feathermerchant DIY Electronics 1 Mar 09, 2009 05:40 PM
Question Can I charge packs with an industrial HP power supply ? yshimoni Batteries and Chargers 6 Nov 15, 2003 08:28 PM
hp 6216a power supply!!! wolfance Power Systems 0 May 19, 2003 03:08 PM
