Old Sep 02, 2010, 09:21 AM
nevio p is offline
Find More Posts by nevio p
Joined Oct 2009
Spektrum AR7000 satelite receiver blinking
I am concerned that my AR7000 may not be functioning correctly.
Sometimes the satelite receiver goes from solid led light to blinking on the ground before takeoff. Sometimes I notice it blinking after a flight.
I have recently had a crash using the same receiver but could not determine whether this was due to radio problems or my running the motor Lipos too low and loosing power altogether. I use seperate UBEC for radio.
Can anyone please shed some light?
nevio p is offline Find More Posts by nevio p
Old Sep 02, 2010, 10:16 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I have hear and read post about the cable used for the sat coming lose and causing the lost of power indactor on the sat only.
Make sure you have a good connection, a little contact cleaner would not hurt also.
freechip is offline Find More Posts by freechip
Old Sep 02, 2010, 11:09 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
It's probably what Freechip says. Use contact cleaner or just remove and reinsert the cable (both ends) several times to clean the contacts.
Note that running the batteries down will not cause the radio to fail as long as you have and ESC with functioning low voltage cutoff. There will still be lots of power to run the radio even after the motor has shutdown.
Daedalus66 is offline Find More Posts by Daedalus66
Old Sep 04, 2010, 09:08 AM
lazy-b is offline
Find More Posts by lazy-b
Manila, Philippines
Joined Jul 2004
Guys, Yes.....I have personally encounter a Loose Connection on my AR7000 and AR9000.....I just Plug and Un-Plug the wire.
here is my actual problem caught on the video camera:
Spektrum Satellite Receiver Problem (3 min 2 sec)
lazy-b is offline Find More Posts by lazy-b
Old Sep 04, 2010, 09:30 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I've had similar experiences with AR6200 and AR7000 several times.
Old Sep 04, 2010, 12:07 PM
nevio p is offline
Joined Oct 2009
Hey thanks a lot guys.
I unplugged then plugged the satelite receiver back and the problem diappeared. Guess that it must have been some oxidation on contacts. As easy as that!
Ciao
Sold Spektrum AR7000 receiver $70.00 Crazy Eight Aircraft - General - Radio Equipment (FS/W) 3 Aug 01, 2010 11:39 PM
Sold Spektrum AR7000 receiver $70.00 Crazy Eight Aircraft - General - Radio Equipment (FS/W) 3 Jul 28, 2010 11:36 AM
Sold Spektrum AR7000 receiver $70.00 Crazy Eight Aircraft - General - Radio Equipment (FS/W) 0 Jul 24, 2010 02:17 PM
Wanted satelite receiver for AR7000 joliecoeur13 Aircraft - General - Radio Equipment (FS/W) 2 Jul 23, 2010 09:03 PM
Question Spektrum AR7000 blinking antenna jet-ster Radios 1 May 17, 2009 05:49 PM
