Are you saying the Accucell 6 does not come with the proper input battery jack harness? Whoa.
As for the power supply, you should plug it in and test each of the 4 pins. It should work fine, just need the - and + wires. If you find these as expected, cut the power jack and hardwire the one you need to the wires. As for the power jack, perhaps try Radio Shack? I just did a recall of 75 of a product I build at my 9-5 due to an incorrect power jack. The inside male pin on the unit was smaller than the female pin on the supply and this caused an intermittent power connection. If you have a way to measure the male pin on your charger, do that before looking. If not, take your charger with you on your search. Rick |
Latest blog entry: mean well S-210-12 power supply
yeah, I had to modify the three laptop power supplies I bought to match the power plug on my chargers too. Just cut the connector off, peel back the insulation some, carefully spread the wires apart and power it up and see which two wires you want to use to power the charger with. Then solder on the correct connector as needed.
Latest blog entry: My Low Wing plane
Joined Sep 2009
If it is a 12V 5 amp rated adapter, it will working hard on a 50W charger.
I would not charge at 5-6 amp with it for a long period of time. However I did jast that in the past, but I've taken the top of the adapter off and put a small 80mm PC case fan over it to keep things cooled. Use a digital volt meter to find 12 V leads. |
The largest is 3s 2200. Don't plan to charge at more than 1C. I have enough batteries to do all of my charging at home throughout the week.
Just so happens the company carries the standard 5.5mm tip, so I dropped this one in the mail and they are sending that one to me. Thanks for your help guys. |
Joined Sep 2009
Accucell 6 is likely falls in the category of 70% efficient charger.
meaning it will pull 5 amp from the power supply to put out (charge) high 3 to 4 amps at ~ 12V which is where your 3Slipo is. If you only charge at 2200ms 0r 2.2 amp or at 1C with your current battery, your adapter will be fine , but it will be warm (normal). The thing is when you have 5 amp capable charger such as your accucell 6, the devil in you (or min me) will attempt to charge at 3, 4 or 5 amp when you are in the hurry. Also as you advance you will want larger batteries and larger crafts, planes or helis. SO.... mine as well order a better power supply now. Seriously.like this one: Cheap, shipped fast it is here in the USA ( well....now it shows out of stock) http://www.hobbypartz.com/77p-g350-powersupply.html I have one; I've taken it apart and it is poorly made, but works. |
| Thread Tools | |
| Discussion power supply wattmeter reading. Can I trust it? | maxmekker | Batteries and Chargers | 3 | Aug 08, 2010 03:38 PM |
| Discussion Z-POWER 50 HELI MOTOR ???Can I use for airplane? | jerryantczak | Power Systems | 1 | Aug 03, 2010 10:04 AM |
| Can Use PC Power Supply for Charging | vkmaynard | Power Systems | 8 | May 13, 2002 03:10 AM |
| How can you use a 12V Power Supply from PC | Rocken | Power Systems | 10 | Sep 21, 2001 10:27 AM |
| How can you use a 12V Power Supply from PC | Rocken | Parkflyers | 4 | Sep 09, 2001 02:02 AM |
