Old Sep 02, 2010, 08:23 AM
learn2turn is offline
Find More Posts by learn2turn
United States, MA, Medfield
Joined Jul 2010
HK 20A 18Amp ESC Programming
I have one of the HK cheapo ESC.
I seem to recall find something the other day that had the programming instructions and beep codes for it. I believe there were only three options like break, battery type, and something else.
Anyone know where the instructions are?
All I want to do is verify that mine is running in Lipo mode. I get one long beep of a few seconds when I power it up.
-l2t
learn2turn is offline Find More Posts by learn2turn
Old Dec 10, 2010, 02:20 AM
FrostytheSM is offline
Find More Posts by FrostytheSM
EEUU, AK, Palmer
Joined Sep 2010
i pulled this off hk's web sight from a post there:
Very good controller, specially for this money.
With 16A it becomes a little bit warm, no problem.
One disadvantage: there is no manual included. (5 Stars with manual!)
So I have searched in web an i found that the controller is programmable.
Possible options:
- LIPO-mode (auto selection 2/3 cells)
- NIMH-mode
- Break on / off
To program this controller you have to move transmitter throttle to full position.
Now connect battery to controller.
Wait some seconds, than you hear:
*peep* - *short pause* - *peep*
*pause*
*peep*peep* - *short pause* -*peep*peep*
*pause*
*peep*peep*peep* - *short pause* -*peep*peep*peep*
*pause*
this sequence will repeat...
When you want to use NIHM cells, you have to move throttle to off position when you hear the first *beep*beep*. Than you have to wait for a longer *beeep* and a short *beep*. That's all. You can disconnect battery now.
When you want to select LIPO mode, start from the beginning (throttle full, connect battery, listen to the beeps)
At the time when you hear the first single *beep* move throttle to off and wait for
*beeep* and *beep*.
When you want to switch Brake On or Off, start from the beginning, then wait for the first *peep*peep*peep* within one sequence and put throttle to off. Wait for *beeep* and *beep*.
Note: When you connect battery and throttle is in off position you will hear a long *beeeep* when LIPO-mode ist selected or a short *beep* when NIMH-mode is active.
good luck
FrostytheSM is offline Find More Posts by FrostytheSM
Old Jan 11, 2011, 07:06 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
I know this goes back a little.. but I got an art-tech 18mamp speed controller witha heat sink.. anybody seems to have is programming chart?
pavcon is offline Find More Posts by pavcon
Old Jan 11, 2011, 07:43 PM
Ghost Plane is offline
Find More Posts by Ghost Plane
United States, NY, Angola
Joined Jul 2010
Can't remember where I found this, but it's the programing instructions for this ESC. It says SUPPO but it also works for the HK simple ESC.
Basicly there's 3 options.
Lipo
NiMH
Brake
Ghost Plane is offline Find More Posts by Ghost Plane
Old Jan 11, 2011, 09:46 PM
pavcon is offline
Joined Jan 2010
thanks Ghosty
Old Mar 18, 2011, 03:41 PM
DavidCYWPilot is offline
Find More Posts by DavidCYWPilot
Joined Mar 2011
thanks for the great info FrostySM! You info was very helpful in resetting my programming.
DavidCYWPilot is offline Find More Posts by DavidCYWPilot
Old Oct 29, 2013, 06:56 AM
Swissflyer is offline
Find More Posts by Swissflyer
Swissflyer's Avatar
Brigerbad, Switzerland
Joined Sep 2004
Needed to set the brake on a HobbyKing HK HW20A very cheap 18-20Amp ESC.
Google sent me here, however, I did notice on the product Web page that Turnigy programing cards work.
I treid mine and it was perfect.
Swissflyer is offline Find More Posts by Swissflyer
Old Oct 29, 2013, 07:35 AM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
If reprograming a powered model ?
Make SURE YOU REMOVE the propellor FIRST.
Never have a WOT plane right in front of you chewing on your hands.
cyclops2 is offline Find More Posts by cyclops2
Found 20A Brushed ESC NewToThis007 Aircraft - Electric - Power Systems (FS/W) 3 Aug 30, 2010 07:26 PM
Discussion BP 18amp ESC Rookiepilot2003 Foamies (Scratchbuilt) 4 Jul 30, 2010 04:44 PM
For Sale 30a ESC and 20A esc for sale! tc3wins Aircraft - Electric - Power Systems (FS/W) 1 May 27, 2010 08:01 AM
Discussion Help with HK ESC programming PaulDaniel Power Systems 2 Jun 19, 2009 10:00 PM
Rant Eflite 20a ESC Programming WTH?? badbill Power Systems 0 Aug 29, 2006 08:46 PM
