Old Sep 01, 2010, 10:53 PM
Quad_Addict is offline
Find More Posts by Quad_Addict
United States, IL, Chicago
Joined Dec 2006
Official!!!!!! Parrot A.RDrone USA owners thread
OFFICIAL!!!!!! PARROT A.RDRONE USA OWNERS THREAD
ships on September 3rd from Brookstone,
who else has else one on order from Brookstone?
BROOKSTONE LINK TO PURCHASE PRE ORDER....
http://www.brookstone.com/ar-drone-q...pg|hdr|652479p
download for the linux navigation program
https://projects.ardrone.org/
https://projects.ardrone.org/wiki/ardrone-api/Changelog
Quick start guide with the iPhone interfaceĥ
* Configure your iPod in Airplane mode to have the best Wifi connection quality level. Make sure Wifi is switched off on your iPod.
* Plug a fully charged battery in the AR.Drone and lay it on horizontal, flat area.
* If you fly indoor make sure you attach the large EPP hull.
* If you fly outdoor make sure you attach the small EPP hull.
* Switch on the iPod's Wifi and connect to ardrone_network
* Check you got the following IP address: 192.168.1.2, sub network mask 255.255.255.0 and router 192.168.1.1.
* Start Parrot Demo application and check you see the video stream live from the AR.Drone.
* Go to settings menu (top left button), select "Flat Trim" and check tilt angle is not set to zero.
* If you fly indoor make sure you position "Outdoor shell" and "Outdoor Flight" buttons to OFF.
* If you fly outdoor make sure you position "Outdoor shell" and "Outdoor Flight" buttons to ON.
* Press the center bottom button for taking off. The AR.Drone should take off vertically and hover steadily.
* Use touchpad as described above for the control mode you chose and go up/down, strafe left/right/forward/backward, or turn left/right.
* In case any propeller, engine or gear were blocked, a "Cut out emergency" alert message is shown. Press the top center reset button when the problem is cleared.
* Press the center bottom button for landing.
* Disconnect the LiPo battery.
* To release the ad-hoc network and save iPhone battery go back to iPhone settings and switch off Wifi.
Download & Running the latest SDK
You need to compile the program yourself.
Here is a quick step-by-step guide for Ubuntu 10.04
Download the SDK 1.0.4 and place in your home directory.
Run the following commands in a terminal.
sudo apt-get install libsdl-dev
tar xvjf ARDrone_API-1.0.4.tar.bz2
mv release-1_0_4_ARDrone_Version_20100716_1_0_4_RC ardrone
cd ardrone/ARDroneLib/Soft/Build/
make
cd ~/ardrone/Examples/Linux/Navigation/Build/
make
The executable “ardrone_navigation” will be located in
ardrone/ARDroneLib/Version/Release
You may need to edit “ardrone/Examples/Linux/Navigation/Sources/UI/gamepad.h” and “ardrone/Examples/Linux/Navigation/Sources/UI/gamepad.c” depending on what gamepad you use.
-A.R Drone Drifting information
The primary source of the drifting stability is done by the AR.Done using its bottom camera. If you are flying on a surface which is very repetitive and does not have any visually distinct items for the software to lock onto, you will experience drifting when you let go of your controls. This software is only intended to assist flight. It is possible that something else is causing your results but just to make sure, try placing an object or two below your AR.Drone on the same surface.
Quad_Addict is offline Find More Posts by Quad_Addict
Reply With Quote  (Disabled)
Old Sep 02, 2010, 12:23 AM View Post
Z06 Tony
A moderator felt this post violated the following rule: Trolling (Provocation). It is temporarily hidden while Z06 Tony edits it. Show it to me anyway.
Old Sep 02, 2010, 12:28 AM
Joined Dec 2006
Originally Posted by Z06 Tony View Post
Yea right like what makes your thread the OFFICIAL ONE???? You dont even have one and you already know that there already is a REAL OWNERS THREAD!!! Like another poster mentioned you are a trouble maker and have no class. Here is the REAL OFFICIAL THREAD-> http://www.rcgroups.com/forums/showthread.php?t=1282893
OMG tony jealous much?? wow trolling my thread with your links? mine is for USA buyer who purchased from Brookstone. was it really necessary to come in here with your spamming? nice attitude!
it is ok for other owners to start there own thread you know thats the purpose of a forum and thread.. WOW grow up!
Old Sep 02, 2010, 12:38 AM
Joined Dec 2006
REPAIR VIDEOS....
Repair 1: replace AR.Drone propellers, shafts & gears
Repair 1: replace AR.Drone propellers, shafts & gears (1 min 14 sec)
Repair 2: replace AR.Drone engine
Repair 2: replace AR.Drone motor (1 min 6 sec)
Repair 3: replace AR.Drone mainboard
Repair 3: replace AR.Drone mainboard (1 min 43 sec)
Repair 4: replace AR.Drone navigation board
Repair 4: replace AR.Drone navigation board (0 min 49 sec)
Repair 5: replace AR.Drone central cross
Repair 5: replace AR.Drone central cross (1 min 17 sec)
Repair 6: fix AR.Drone hull with special EPP tape
Repair 6: fix AR.Drone hull with special EPP tape (1 min 30 sec)
Old Sep 02, 2010, 12:39 AM
Joined Dec 2006
AR Drone Piloting from the first person view
http://www.youtube.com/watch?v=qtB0deeO2Tg
AR.Drone Autopilot Stabilization (Fan Test)
AR.Drone Autopilot Stabilization (Fan Test) (0 min 36 sec)
AR.FlyingAce : Dogfight with 2 AR.Drone
AR.FlyingAce : Dogfight with 2 AR.Drone (Work in progress E3 June 2010) (1 min 38 sec)
Old Sep 02, 2010, 01:12 AM
palomo is offline
Find More Posts by palomo
romantist
palomo's Avatar
Chicago
Joined Jul 2004
Really! Another official Parrot AR Owner's thread? Nice! I guess there is enough excitement and enthusiasm going around.
There is NO need to bicker around boys!
Cheers!
palomo is offline Find More Posts by palomo
Old Sep 02, 2010, 01:20 AM
Joined Dec 2006
Cheers!
That's what I'm saying!
Old Sep 02, 2010, 02:11 PM View Post
Z06 Tony
Old Sep 02, 2010, 02:19 PM
Joined Dec 2006
Tony go away and stop trolling, this thread is clearly catered to people who bought from brookstone. Leave and quite being a baby!
Old Sep 02, 2010, 07:39 PM
importon is offline
Find More Posts by importon
USA
Joined Aug 2009
Can someone please post the linux navigation program somewhere. projects.ardrone.org will not let me log in no matter what i do. Ive got a brand new ar.drone just sitting in front of me with no way to play with it. (my iphone got smashed 3 days ago) this is torture!!!!
importon is offline Find More Posts by importon
Old Sep 02, 2010, 07:41 PM
Joined Dec 2006
this?
Old Sep 02, 2010, 08:24 PM
importon is offline
USA
Joined Aug 2009
thanks very much. got it working now
Old Sep 02, 2010, 09:14 PM
Joined Dec 2006
Old Sep 02, 2010, 11:18 PM
Hot_Wheels is offline
Find More Posts by Hot_Wheels
United States, IL, Carol Stream
Joined Nov 2009
has anyone figured how to control it with something other then a apple product? whats the range on the wifi?
Hot_Wheels is offline Find More Posts by Hot_Wheels
Old Sep 03, 2010, 07:47 AM
Joined Dec 2006
from reading there is a droid app but not supported yet, give it time the windows app and many others will be following shortly! patients is a virtue!
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19361 Jul 13, 2016 07:43 AM
Discussion The "ORIGINAL" Parrot AR. Drone owners thread Z06 Tony Multirotor Talk 1949 May 05, 2015 09:38 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
New Product PZ Ultra-Micro Piper Cub [Official Owners Thread] dgbuggy Micro Ready-to-Fly 13 Dec 17, 2009 09:50 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
