Old Sep 01, 2010, 04:14 AM
Szymon Bartus is offline
Find More Posts by Szymon Bartus
Cracow, Poland
Joined Nov 2003
Help!
Futaba 10CG - problem with end point adjustment
Hello,
Not too long ago, I got a new Futaba 10CG from eBay. Right now I am setting up my MPX Easy Glider Pro. I noticed a strange behaviour of my radio - when I am adjusting the end points, the neutral points of the servos also change! For example, when I was setting up the elevator deflections to +/-63%, the elevator neutral point moved down when I was decreasing the upper end point (from 100%) and then moved up when I was decreasing the lower end point. All in all, the neutral point remained the same. But in case of ailerons, the neutral point changed, because I set up larger deflection up than down. As a result, using even ALL of my sub-trim can't help me with keeping my ailerons in line with the wing.
I have this plane in "Glider (1A+1F)" mode. Any comments?
Regards,
Szymon
Szymon Bartus is offline Find More Posts by Szymon Bartus
Question DSX9 End Point Adjustment spotterone Radios 3 Apr 24, 2010 07:04 PM
Question End Point Adjustment, Futaba 7C agran1021 Beginner Training Area (Heli-Electric) 9 Jun 10, 2009 07:59 PM
Help! End Point Servo Adjustment problem piotrek Radios 2 Jun 27, 2008 04:31 AM
FUTABA End Point Adjustment DougC Radios 2 Jun 01, 2005 04:50 PM
End point adjustment problem mountain flyer Parkflyers 3 Jun 20, 2003 07:01 PM
