Old Jun 28, 2011, 03:29 PM
rhawk1967 is offline
Find More Posts by rhawk1967
Joined Apr 2007
I use these...http://www.valuehobby.com/product_de...60&item_id=151
Value Hobby has good stuff....fast ship.
rhawk1967 is offline Find More Posts by rhawk1967
Old Jun 28, 2011, 08:03 PM
Berkie is offline
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
Looks like it is the same servo. "MG90S"
Kev
Berkie is offline Find More Posts by Berkie
Old Jun 29, 2011, 01:23 AM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Cralis is offline Find More Posts by Cralis
Old Jun 29, 2011, 01:45 AM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Originally Posted by pullup! View Post
I used some piano wire I got at the local hardware store for the pushrod, and some spare tubing left over from other builds.
Im running Mg90s on all control surfaces now, I replaced the elevator and rudder before the first flight. I'm pushing 100 flights now and one aileron servo was making some strange noises so I replaced them.
Thanks Pullup
So can you tell me what is the problem with the existing pushrod?
Too flimsy?
Kev
Old Jun 29, 2011, 03:29 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Thanks chaps. I am getting the MG90s for Rudder/Elevator. At the moment, that's the only upgrade I am applying. I am thinking of adding flaps, but not sure what people thing. It's for landing. Or maybe pre-made speed breaks? Are there such things?
I also think the carbon fiber strips added to the ailerons and maybe the elevator seems like a good idea, but I am scared of cutting CF (Cancer?!), and wondering if the right sizes can be sourced?
This will be an FPV plane, so the pilot will have to make way for a small servo and a camera... and then the video Tx might go in the passenger seat... How hard is it to remove the canopy to get to the pilot? Any tricks there?
And then, the ESC... worth an upgrade? Or is that OK? Maybe get separate 3A UBEC off HK?
And finally, wing strengthening... is that something that should be done? I don't expect to do loops and hard g maneuvers... but... Is there any advice there?
Old Jun 29, 2011, 08:25 AM
JumpySticks is offline
Find More Posts by JumpySticks
Drifting off the reservation..
JumpySticks's Avatar
USA, LA, Broussard
Joined Jan 2011
Originally Posted by Cralis View Post
Wow... you spammed a lot of threads to get that post in...
Just trying to get the word out to those who are interested. There will be no more "spammin" from me.
JumpySticks is offline Find More Posts by JumpySticks
Old Jun 29, 2011, 09:04 AM
Joined Apr 2007
I do not think flaps or speed brakes are needed.....but could be fun. With the cg back at 50-58mm, the Fox glides ALOT slower than stock
.....just dont breathe the CF dust if cutting with a saw...or better yet just "snip" the CF with a sharp set of scissors or snips.
I removed my bug eyed pilot by getting under the edge of the lexan with an exacto knife, and then worked my way around for a bit. The canopy basically fell off once I got started. It wasnt glued very well.
I went with a turnigy plush switching 40A SC, and the 1300 kv turigy motor, running 35c 2200 batts. It climbs VERY fast now. Stock motor and SC were fine...but rather boring.
Wing strength is fine. They do flex a little, but I do loops and rolls all the time with no problems. Upgrade the wing screws to M2X8 to get more bite on the spar.
Old Jun 29, 2011, 09:53 AM
jeanorwin is offline
Find More Posts by jeanorwin
Joined Jan 2011
Getting the actual plastic part of the canopy off the glider wasn't a real problem for me either.. Just make sure NOT to glue it back in with hot glue, otherwise you might melt some of the plastic of the canopy(which happened to me, apart from the complete crashed glider it looks sh***y too).
jeanorwin is offline Find More Posts by jeanorwin
Old Jun 29, 2011, 12:07 PM
pullup! is offline
Find More Posts by pullup!
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
Originally Posted by Berkie View Post
Thanks Pullup
Too flimsy?
Kev
When I split the fuse I noticed the elevator pushrod was in a black guide tube that was brittle and cracked when I flexed it. The pushrod was like a noodle, it worked for many flights but since my Fox isn't stock and I fly a GoPro on it sometimes I beefed it up to be safe.
pullup! is offline Find More Posts by pullup!
Old Jun 29, 2011, 01:04 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Got my blue Fox glider in from Nitroplanes today. reason to smile now
Just can't open the box at work
Melnic is offline Find More Posts by Melnic
Old Jun 30, 2011, 12:32 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Thanks - I may go the same route... Changing the motor ... is that a simple swap out, or do you have to mod the plane, drill new holes, hold prop adaptors etc?
Old Jun 30, 2011, 01:55 PM
turbinefancy is offline
Find More Posts by turbinefancy
wish for Tomcat....granted!
turbinefancy's Avatar
United States, CA, Irvine
Joined Jun 2009
Nitroplanes posted their video review today. Looks great!
New Airfield 2320mm Fox Electric Glider Review (8 min 26 sec)
turbinefancy is offline Find More Posts by turbinefancy
Old Jul 01, 2011, 06:52 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Instead of making your own flaps, to reduce landing speed *and therefore, room*, would anyone recommend these?
And if so, how do they install??
Old Jul 01, 2011, 07:55 AM
Joined Jan 2011
Yes, I got them installed on my fox. They do what they're supposed to do - decrease the glide capabilites of the fox. It works quite well IMO.
Old Jul 01, 2011, 08:26 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Thanks man - can you tell me how they are installed? I assume they both need a servo, somehow?
Mini-Review FOX ST-Model /Kyosho /Hype /Ripmax 1.8m /71" EPO PnP/RTF BL/ Glider McMoron Electric Sailplanes 428 Dec 03, 2015 01:43 AM
New Product HobbyKing Minimoa 2mtr R/C Glider EPO w/ Motor, ESC, Servos Plug-n-Fly Bowerz Electric Sailplanes 8 Jul 29, 2015 09:28 AM
Discussion HobbyKing 3D 30" EPO Yak 54 Bowerz 3D Foamies 39 May 06, 2011 11:39 PM
Sold WindRider Fox EPP Glider $60 + Shipping ShoGinn Aircraft - Sailplanes (FS/W) 1 Aug 23, 2010 09:21 PM
Discussion St model fox glider Staudacher600 Electric Sailplanes 2 Aug 04, 2010 10:42 PM
