Old Jun 04, 2011, 06:31 AM
rhawk1967 is offline
Find More Posts by rhawk1967
Joined Apr 2007
Originally Posted by biggy boy View Post
I've been debating that too.
Glen
Glen,.....you go first! lol.
rhawk1967 is offline Find More Posts by rhawk1967
Old Jun 04, 2011, 11:10 AM
Ant is offline
Ant
Find More Posts by Ant
Ant
Old Noob.
Ant's Avatar
Joined Nov 2003
Originally Posted by WimH View Post
I somehow managed to get the brake on, but I'm not sure i did not change some other setting in the process, so I would really like to find out what esc it is... The range of beeps it produces is impressive, a bit, but not quite like the FM30A mystery esc....
Wim
I thought that I had read somewhere that it was a hobbywing/pentium clone.
Ant
Ant is offline Find More Posts by Ant
Old Jun 04, 2011, 11:21 AM
Helitime is offline
Find More Posts by Helitime
Pickering Ontario CANADA
Joined May 2010
Originally Posted by Berkie View Post
Say Kerry, at 50mm that would mean a long way back to get CG for a 3S right?
Or did you add weight to the tail?
Kev
Hey Kev
page 55 post 821 for pics.
The pack is as far back as it will go (under the canopy).I had to cant it to one side to avoid the ele servo plus my rud servo is in the vert. stab.
Kerry
Helitime is offline Find More Posts by Helitime
Old Jun 04, 2011, 11:37 AM
Helitime is offline
Joined May 2010
anybody have a programming guide for the stock 30A ESC? Mine does not brake....
Wim
I think I have it. Just going out the door and I have to test to confirm it's the right instructions. I will get back to you.
Kerry
Old Jun 04, 2011, 03:41 PM
Helitime is offline
Joined May 2010
Here you go Wim
ESC instructions, let me know if I missed anything.
Description:
Description:
High def. you should be able to zoom and scroll.
Kerry
Note: throt. calibration (do first? I do) is the last paragraph of the second pic then the start of the first pic.
Old Jun 04, 2011, 06:15 PM
Berkie is offline
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
Originally Posted by Helitime View Post
Hey Kev
Kerry
Thanks mate.
Kev
Berkie is offline Find More Posts by Berkie
Old Jun 04, 2011, 06:23 PM
biggy boy is offline
Find More Posts by biggy boy
prop wash
biggy boy's Avatar
North of Toronto in Ontario
Joined Dec 2002
Ant
Hobbywing HUh Cool I have a programming card for that.
It's real handy. I need to have visual proof of programming I don't trust my
listening to beeping sounds skills LOL.
Glen
biggy boy is offline Find More Posts by biggy boy
Old Jun 04, 2011, 06:45 PM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
Here you go Wim
Thanks, that is perfect. Says you can only change one setting at a time, so I'm probably ok....
WimH is offline Find More Posts by WimH
Old Jun 05, 2011, 01:24 AM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Those spar retaining screws
Anyone else had trouble with these?
I found they fail to lock-in after a very short time. You will find you won't be able to screw in or undo the screw. You will have to cut out a small square on top of the wing once you find the right spot. To find the right spot insert a screw driver thru the hole from the underside & push hard while you hold a finger on the top side. Keep pushing until you feel the point of the screw starting to come thru the top of the wing. Now cut out of the top side about a 10mm square hole around the point where the screw was starting to come thru & deep enough so you hear the blade contact something hard. This is the plastic mount for the nut that was supposed to lock the screw in place. You will see that the nut has come loose from its mount. They did not glue the nut in.
Position the nut back into it's mount then rescrew the screw from the underside of the wing.
I then poured in some hot melt covering the nut & screw but before the glue got too firm I screwed the screw in & out & few times to free it for later ins & outs.It all sounds very sexy don't it
Anyone find this of interest?
Kev
Old Jun 05, 2011, 02:03 AM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Further, throw out those fiddle fart philips head screws and get yourself some of these http://www.hobbyking.com/hobbyking/s...dProduct=12307 and one of these
http://www.hobbyking.com/hobbyking/s...dProduct=11062
Kev
Old Jun 05, 2011, 07:02 AM
prop wash
biggy boy's Avatar
Joined Dec 2002
Kev
I have one loose nut
Old Jun 05, 2011, 07:15 AM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Have you checked if your spars are locked in tight?
The philips head screws are bad enough at any time let alone when you are trying to locate the head properly when it is out of sight.
When you get the hexagon screws in there you won't believe the difference when using this http://www.hobbyking.com/hobbyking/s...dProduct=11062
Kev
Old Jun 05, 2011, 08:29 PM
Helitime is offline
Joined May 2010
Who let you loose?
Old Jun 05, 2011, 08:54 PM
prop wash
biggy boy's Avatar
Joined Dec 2002
Who let you loose?
Don't worry it's just a weekend leave, for good behavior.
I took the Fox out the flying field today, one of the guys was going to toss it for me when I noticed an aileron was sagging a bit.
The hinge line is starting to separate.
I've hinged the rudder and elevator due to separation.
Luckily I had two other planes to fly today......
All in all it was a great day of flying, with a bunch of cool guys!!!
Glen
Old Jun 05, 2011, 08:57 PM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Who let you loose?
If he's got one loose, how's the other one
Kev
Mini-Review FOX ST-Model /Kyosho /Hype /Ripmax 1.8m /71" EPO PnP/RTF BL/ Glider McMoron Electric Sailplanes 428 Dec 03, 2015 01:43 AM
New Product HobbyKing Minimoa 2mtr R/C Glider EPO w/ Motor, ESC, Servos Plug-n-Fly Bowerz Electric Sailplanes 8 Jul 29, 2015 09:28 AM
Discussion HobbyKing 3D 30" EPO Yak 54 Bowerz 3D Foamies 39 May 06, 2011 11:39 PM
Sold WindRider Fox EPP Glider $60 + Shipping ShoGinn Aircraft - Sailplanes (FS/W) 1 Aug 23, 2010 09:21 PM
Discussion St model fox glider Staudacher600 Electric Sailplanes 2 Aug 04, 2010 10:42 PM
