Old Jun 02, 2011, 02:45 PM
biggy boy is offline
Find More Posts by biggy boy
prop wash
biggy boy's Avatar
North of Toronto in Ontario
Joined Dec 2002
Originally Posted by Ant View Post
Do you know why this has started to split? Have you had some fluttering, or is it just from normal wear tear?
My guess is a few to many mode one rough landings
Glen
biggy boy is offline Find More Posts by biggy boy
Old Jun 03, 2011, 04:01 AM
Berkie is offline
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
Originally Posted by biggy boy View Post
I still need to get my CG set up correctly, I'm having to dial in up elevator to keep it from coming down to fast. It is effecting my glide ratio for sure.
Still need to move the CG back some, maybe to 47-48mm!?!?!?
I'm guessing your Fox is a bit heavier from the glue!
I have extra weight from gluing my wing tips back on after several tip stalls on "mode one" crashes during launching.
Now that I have the new mode two spektrum transmitter may launches are successful.
Glen
Yeah, she does fly a bit on the fast side.
Are we checking that the tailplane is perfectly parallel to the wing base?
This is what I do. First pic is a cf rod lined up on the wing root base.
This rod extends to the tailplane. There you can see if the tailplane is parallel to the wing. Mine wasn't, it was deflected down relatrive to the wing base, so was forcing the nose down. So I loosened off both screws, lifted the back of the tailplane up a few mm and ran in a bit of hot melt.
Result? Much better but still needs a little more.
Kev
Berkie is offline Find More Posts by Berkie
Old Jun 03, 2011, 04:17 AM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Are we test gliding?
I'm sure most of us are but for our newer members.......
Always do a series of test glides before launching a new or repaired/modded model.
This tells you a lot before you risk the skies. Give the glider a good strong straight ahead throw. A well balanced and trimmed glider should come out of your hand going level then gently start to nose down landing about 10 metres ahead after you have given it a little bit of nose up to flare out. That says she's all OK for trim & balance.
If she's not - then don't fly it. Re-trim/rebalance or do whatever you have to, and this might take as many as a dozen test glides to get it floating nicely.
THEN it's ready for the air!
This is much better & safer than finding out up there that she is flying too fast, too slow or not straight
Kev
Old Jun 03, 2011, 07:01 AM
rhawk1967 is online now
Find More Posts by rhawk1967
Joined Apr 2007
Kev
Kev, I would be leary to measure incidence that way. It should be measured by location of leading and trailing edges of the wing. An easy way to do it is mark the points on the fuse with a pencil (with the wing in). Then a straightedge can be used to determine the tailplane incidence as you have shown (with the wing out).
Mine is fine stock. Shimming the stab for "Up" trim is ok as a last resort, but should not be used to compensate for a to far forward CG. It just creates a lot of drag and inefficiencies that are bad for a sailplane. Just my 2 cents....dont mean to step on anyones toes...
rhawk1967 is online now Find More Posts by rhawk1967
Old Jun 03, 2011, 07:13 AM
Joined Apr 2007
Oops.....I should have been using the term "decalage" when referring to the angle of the Stab in relationship to the wing. I am awake now...need caffeine.
Old Jun 03, 2011, 07:43 AM
Joined Apr 2007
Because of the forward sweep of the Fox's wings the Cg will be farther back than one would normally think. I have flown at 55mm with no problem. The further back CG eliminates up trim and makes for a flat glide.
Old Jun 03, 2011, 12:58 PM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
anybody have a programming guide for the stock 30A ESC? Mine does not brake....
Wim
WimH is offline Find More Posts by WimH
Old Jun 03, 2011, 03:04 PM
Ant is offline
Ant
Find More Posts by Ant
Ant
Old Noob.
Ant's Avatar
Joined Nov 2003
Wim
I would say "Try the first beep" but with my luck today it would set the ESC to self destruct.
Ant is offline Find More Posts by Ant
Old Jun 03, 2011, 03:39 PM
Joined Apr 2007
Hey Guys, looking at my elevator, it suddenly dawned on me that it is counterbalanced. I am new to sailplanes, but looking at most other designs I have found hardly any that are like the Fox's.
Those end pieces are awful bendy out there on the tips....I can picture at speed the tips bending in the wind and giving more elevator than we are actually applying. Plus, drag is a big negative on a sailplane.
So,...what do you think....should I be the first and cut em' off? and see what happens?
Old Jun 03, 2011, 05:31 PM
Ant is offline
Ant
Ant
Old Noob.
Ant's Avatar
Joined Nov 2003
rhawk1967
I'm not going to modify my Fox that much until HK comes out with replacement parts.
Speaking of which, anyone hear anything on HK starting to carry replacement parts for the Fox?
Old Jun 03, 2011, 08:45 PM
prop wash
biggy boy's Avatar
Joined Dec 2002
I've been debating that too.
Glen
Old Jun 03, 2011, 10:32 PM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Thanks rhawk. I have done as you suggest and that does confirm that there was no need to up-shim, so I'll take out the hot melt.
So, since I was flying with CG at factory figure of 40mm, it seems the factory is being conservative. It is starting to look like at least 50mm is the go. So I'll do that now & re-test
Kev
Old Jun 03, 2011, 10:47 PM
Helitime is offline
Find More Posts by Helitime
Pickering Ontario CANADA
Joined May 2010
Thanks rhawk.
Kev
I did 50mm per rhawk and found it waaaaay better.
Before it just screamed around, now it glides and will still scream around if you want. I still don't have enough down thrust so for now I just fly the throttle to altitude and glide
Helitime is offline Find More Posts by Helitime
Old Jun 04, 2011, 02:35 AM
WimH is offline
WimH's Avatar
Joined Dec 2001
I somehow managed to get the brake on, but I'm not sure i did not change some other setting in the process, so I would really like to find out what esc it is... The range of beeps it produces is impressive, a bit, but not quite like the FM30A mystery esc....
Wim
Old Jun 04, 2011, 02:48 AM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Say Kerry, at 50mm that would mean a long way back to get CG for a 3S right?
Or did you add weight to the tail?
Kev
Mini-Review FOX ST-Model /Kyosho /Hype /Ripmax 1.8m /71" EPO PnP/RTF BL/ Glider McMoron Electric Sailplanes 428 Dec 03, 2015 01:43 AM
New Product HobbyKing Minimoa 2mtr R/C Glider EPO w/ Motor, ESC, Servos Plug-n-Fly Bowerz Electric Sailplanes 8 Jul 29, 2015 09:28 AM
Discussion HobbyKing 3D 30" EPO Yak 54 Bowerz 3D Foamies 39 May 06, 2011 11:39 PM
Sold WindRider Fox EPP Glider $60 + Shipping ShoGinn Aircraft - Sailplanes (FS/W) 1 Aug 23, 2010 09:21 PM
Discussion St model fox glider Staudacher600 Electric Sailplanes 2 Aug 04, 2010 10:42 PM
