Old Jun 01, 2011, 02:55 PM
Helitime is offline
Find More Posts by Helitime
Pickering Ontario CANADA
Joined May 2010
Originally Posted by rhawk1967 View Post
LOL..... I use Fubaba and never had a problem.
"Lipoflyer is a" Spektrum basher I suspect.
Helitime is offline Find More Posts by Helitime
Old Jun 01, 2011, 03:08 PM
biggy boy is offline
Find More Posts by biggy boy
prop wash
biggy boy's Avatar
North of Toronto in Ontario
Joined Dec 2002
Originally Posted by Helitime View Post
I do, for 4 years now, never had a problem.
Sorry, my mistake, I am not familiar with SPECTURM
I use Spektrum.
Kerry
According to Urban Dictionary
SPECTURM:
"The anatomical area exclusive to males, which encompasses both the grundle and the kunder."
Kerry are you positive your not using your SPECTURM????
Glen
biggy boy is offline Find More Posts by biggy boy
Old Jun 01, 2011, 03:30 PM
rhawk1967 is offline
Find More Posts by rhawk1967
Joined Apr 2007
Spektrum basher I suspect. Got nuthin positive to add??? s.t.f.u.
Dang....
I think you took my post completely the wrong way.... My "lol" was because I laughed (liked) at your previous post about not knowing about "spekturm"...hilarious.
I mispelled fubaba (futaba) on purpose.....just having fun with what was already written.
I do not, and did not bash anyone. I enjoyed our conversations until now... I will stfu as you demand and go somewhere else.
rhawk1967 is offline Find More Posts by rhawk1967
Old Jun 01, 2011, 05:40 PM
prop wash
biggy boy's Avatar
Joined Dec 2002
comments removed
Glen
Old Jun 01, 2011, 05:51 PM
Ant is offline
Ant
Find More Posts by Ant
Ant
Old Noob.
Ant's Avatar
Joined Nov 2003
"And what does STFU stand for anyway?"
Something not very nice.
Ant is offline Find More Posts by Ant
Old Jun 01, 2011, 06:17 PM
pullup! is offline
Find More Posts by pullup!
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
Easy now, back away from the keyboard.......
pullup! is offline Find More Posts by pullup!
Old Jun 01, 2011, 06:43 PM
prop wash
biggy boy's Avatar
Joined Dec 2002
Comment removed
Glen
Old Jun 01, 2011, 07:35 PM
Helitime is offline
Joined May 2010
Comment removed. I was out of line. Apologies to all concerned. Especially "rhawk" it was not directed at you sir and "Lipoflyer" who is entitled to his opinion.
"rhawk" I sent you a PM.
"Glen" PM on the way
"pullup" good advice
Old Jun 01, 2011, 08:39 PM
Helitime is offline
Joined May 2010
Sorry about the suspense I forgot to post the definition.
The gentleman "lipoflyer" only has 1 post in this forum (I thought it was negative) therefor I referred to him as a "Short Time Forum User". Pop in, comment and leave, often never to be heard from again.
However, it is not my place to jump on someone if I do not agree, thus my apologies to "lipoflyer" and to "rhawk" for the misunderstanding, your input has been all positive and helpful.
Kerry
Old Jun 01, 2011, 09:28 PM
pullup! is offline
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
Just got back from flying the fox until sundown in varied wind conditions. Was having issues going downwind and maintaing control authority. It could of been the conditions, but I think the cg at 50mm with a tail wind might not be the best of things. I was looking at the entire elevator and at least on mine it looks like it could use a shim or two on the rear bolt. Could just be me... Anyone else have any issues/thoughts on this. Thanks!
Old Jun 02, 2011, 07:07 AM
prop wash
biggy boy's Avatar
Joined Dec 2002
The rear bolt
Are you referring to the control horn on the elevator?
I have noticed that the base plates of my control horn is digging into my
elevators EPO foam. A pair of thin hobby plywood pads larger then the horn , mounted on both sides would be a good idea.
The rear elevator is starting to worry me.
I have already had to install hinges due to the hing line splitting apart. I'm thinking of relocating and upgrading a servo at the back of the tail to control the elevator.
Glen
Glen
Old Jun 02, 2011, 07:34 AM
jeanorwin is offline
Find More Posts by jeanorwin
Joined Jan 2011
I don't have any probs with the elevator so far, but the steel that goes all the way back through the plane isn't the best/hardest/steadiest so that might be causing a problem, even if it's in one of those plastic holes.
However, I just started to also swap the rudder servo into the back - in order to have a better control of it and a better glide rate.
What is your glide rate by the way? I have the feeling that the one of my fox has decreased quite heavily..
jeanorwin is offline Find More Posts by jeanorwin
Old Jun 02, 2011, 08:13 AM
prop wash
biggy boy's Avatar
Joined Dec 2002
I still need to get my CG set up correctly, I'm having to dial in up elevator to keep it from coming down to fast. It is effecting my glide ratio for sure.
Still need to move the CG back some, maybe to 47-48mm!?!?!?
I'm guessing your Fox is a bit heavier from the glue!
I have extra weight from gluing my wing tips back on after several tip stalls on "mode one" crashes during launching.
Now that I have the new mode two spektrum transmitter may launches are successful.
Glen
Old Jun 02, 2011, 09:14 AM
Joined Apr 2007
Kerry
Thank you Kerry. Apology accepted, and I apologize if my feable attempt at humor appeared to be taunting Futaba over spektrum. Was not my intent in the least. I have appreciated your input on the Fox as well.
Hoping to fly tonite!....beautiful day here in Indiana.
Old Jun 02, 2011, 01:20 PM
Ant is offline
Ant
Ant
Old Noob.
Ant's Avatar
Joined Nov 2003
Do you know why this has started to split? Have you had some fluttering, or is it just from normal wear tear?
Jeanorwin's and tonywayne's experience have made me start to look at moving a servo back there for the elevator, and maybe adding some carbon to it.
I just ordered some metal gear servos from HK, maybe I will wait for those to get in before I seal everything back up.
Mini-Review FOX ST-Model /Kyosho /Hype /Ripmax 1.8m /71" EPO PnP/RTF BL/ Glider McMoron Electric Sailplanes 428 Dec 03, 2015 01:43 AM
New Product HobbyKing Minimoa 2mtr R/C Glider EPO w/ Motor, ESC, Servos Plug-n-Fly Bowerz Electric Sailplanes 8 Jul 29, 2015 09:28 AM
Discussion HobbyKing 3D 30" EPO Yak 54 Bowerz 3D Foamies 39 May 06, 2011 11:39 PM
Sold WindRider Fox EPP Glider $60 + Shipping ShoGinn Aircraft - Sailplanes (FS/W) 1 Aug 23, 2010 09:21 PM
Discussion St model fox glider Staudacher600 Electric Sailplanes 2 Aug 04, 2010 10:42 PM
