Old May 30, 2011, 05:41 AM
Berkie is online now
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
Originally Posted by Helitime View Post
Hi Kev, you might want to "test" regular CA and kicker. Gives a very strong bond and no melting foam. Best method for CA is Kicker one side CA the other and don't miss when you stick them together. CA together and kicker on the seam works also.
Some thing to try What ever works fer u.
Kerry
Yes thanks Kerry, have used that but I like the way hot melt gives you a chance to wriggle it around a bit to get the both sides perfectly aligned.
Aha. Gotcha on the pics.
Kev
Berkie is online now Find More Posts by Berkie
Old May 30, 2011, 07:58 AM
biggy boy is offline
Find More Posts by biggy boy
prop wash
biggy boy's Avatar
North of Toronto in Ontario
Joined Dec 2002
Originally Posted by Berkie View Post
This is what I have done to provide some sorely needed downthrust.
The right side black line is the original position of the plastic motor mount. The left side black line is where I have carved out the foam so that now the mount will face downwards more.
Rather than work with a lot of difficulty I sliced off the left side of the nose to make it easy to remove the motor. Why not? It is a quick, easy & strong repair with hot glue.
Kev
Another method to change the motor angle is to put some small washers behind the motor mount on two of the screws.
This is what I usually do. That way you can test it out and make adjustments if needed.
Glen
biggy boy is offline Find More Posts by biggy boy
Old May 30, 2011, 02:59 PM
rhawk1967 is offline
Find More Posts by rhawk1967
Joined Apr 2007
My Fox is very gentle on stall at 50mm, nothing odd happens,just drops nose and continues to fly after that.. I am surprised at how slow the airframe can actually fly. Landings are almost hands off....just keeps the wings level. I took the time to balance it laterally as well.
rhawk1967 is offline Find More Posts by rhawk1967
Old May 30, 2011, 05:31 PM
Helitime is offline
Find More Posts by Helitime
Pickering Ontario CANADA
Joined May 2010
Thanks rhawk, good to know on the stall. I have balanced also so should be the same. I was too busy enjoying the flat glide you gave me , slows right down and just floats past. Looks nice about 6' up, sliding by.
Did you find the ailerons more sensitive as the C/G is moved back?
Kerry
Helitime is offline Find More Posts by Helitime
Old May 30, 2011, 08:33 PM
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
Glen
OK, thanks Glen. I'll take a look at that before I glue her back together
Kev
Old May 30, 2011, 08:41 PM
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
Visibilty
Here is what I am going for to give max. visibility
http://www.jcrc.com/News/Articles/Co...Suggestion.jpg
I know it is a bit like pattern style but I hope to be getting this girl up to quite some altitude when we can get our summer back from you guys.
The full article is here
http://www.jcrc.com/News/Articles/Ar...olorTheory.htm
Kev
Old May 30, 2011, 09:14 PM
prop wash
biggy boy's Avatar
Joined Dec 2002
Kev
Hey Kev I can't get the link to work.
is it this scheme? This is the one I suggested a whack of pages back, I use it on my Super cub.
Glen
Old May 31, 2011, 11:00 AM
Joined Apr 2007
Kerry
Good to hear it worked for you!
Well, I maxed out my aileron throw at the same time I moved the CG back, so I cant really say if it was the CG affecting it or not, but they did get way more responsive with the added CF on the TE. Im only able to get big barrel type rolls out of the Fox.....is this your experience?
I had a blast last nite catching thermals as the Sun went down at the end of a breezy 90 degree day. I swear I was trurning flat 8 foot circles with full rudder, some aileron, and up elevator. Lots of fun!
Rob.
Old May 31, 2011, 11:01 AM
Ant is offline
Ant
Find More Posts by Ant
Ant
Old Noob.
Ant's Avatar
Joined Nov 2003
Anyone got a picture of how their motor/spinner looks after adding some down thrust? I am about to glue mine back together and want to make sure I have enough angle on it.
Ant is offline Find More Posts by Ant
Old May 31, 2011, 11:39 AM
Helitime is offline
Joined May 2010
Hey Rob
Big slow rolls is all I can get even with the flat C/F on the ailerons, max throws rearward C/G and rudder. I added the C/F and moved C/G at the same time.
Quote "I had a blast last nite catching thermals as the Sun went down at the end of a breezy 90 degree day. I swear I was trurning flat 8 foot circles with full rudder, some aileron, and up elevator. Lots of fun!"
When doing this, do you use rudder to turn and opposite aileron to keep it flat ?? I have heard this but have not seen a thermal as yet.
Kerry
Old May 31, 2011, 12:03 PM
prop wash
biggy boy's Avatar
Joined Dec 2002
Kerry
I try to do that as much as possible when slope soring.
Glen
Old May 31, 2011, 02:08 PM
Helitime is offline
Joined May 2010
Thanks Glen, so it does work.
I haven't tried it yet but I have tons of rudder so it should be able to do it.
Kerry
Old May 31, 2011, 02:26 PM
Joined Apr 2007
Hey Rob
Kerry
Forgive me, as this is my first glider, and I was pretty giddy at the thermal action.....I THINK I used aileron as usual to initiate the turn, and then opposite to keep it flat.
Old May 31, 2011, 03:30 PM
prop wash
biggy boy's Avatar
Joined Dec 2002
Kerry
Lots of rudder makes the nose want to go down, so it needs some up elevator along with opposite aileron.
Glen
Old May 31, 2011, 04:05 PM
Joined Apr 2007
Glen
Hey Glenn, Should we be using some aileron differential on the Fox? (less down than up)
Rob.
Mini-Review FOX ST-Model /Kyosho /Hype /Ripmax 1.8m /71" EPO PnP/RTF BL/ Glider McMoron Electric Sailplanes 428 Dec 03, 2015 02:43 AM
New Product HobbyKing Minimoa 2mtr R/C Glider EPO w/ Motor, ESC, Servos Plug-n-Fly Bowerz Electric Sailplanes 8 Jul 29, 2015 10:28 AM
Discussion HobbyKing 3D 30" EPO Yak 54 Bowerz 3D Foamies 39 May 07, 2011 12:39 AM
Sold WindRider Fox EPP Glider $60 + Shipping ShoGinn Aircraft - Sailplanes (FS/W) 1 Aug 23, 2010 10:21 PM
Discussion St model fox glider Staudacher600 Electric Sailplanes 2 Aug 04, 2010 11:42 PM
