Yes, she needs downthrust
This is what I have done to provide some sorely needed downthrust.
The right side black line is the original position of the plastic motor mount. The left side black line is where I have carved out the foam so that now the mount will face downwards more. Rather than work with a lot of difficulty I sliced off the left side of the nose to make it easy to remove the motor. Why not? It is a quick, easy & strong repair with hot glue.![]() You would have thought the makers FPS would known to provide downthrust!! ![]() It's time these makers started getting it right from the outset. Especially basics like down thrust Anyhow this is just one way of attacking the problem - might help someone. This plane just wants to loop on 1/4 throttle ![]() Kev |
Pickering Ontario CANADA
Joined May 2010
OK C of G adjusted from 30mm :-( to 50mm :-). Relocated batt. back as far as pos. canted to one side to avoid the ele. servo. Also added carbon strips to the trailing edge of the ailerons, stiffened them up nice.
Went to the club today, preset lower ele. rates per "rhawk" and gave it a toss. Almost lost it in the couple seconds it took to figure out what was wrong. Ailerons where super sensitive, flipped to low rates and got it back on the ground. Cut low rates down and added a load of expo. Now she flies like a dream, flat glides, she should be able to thermal with some decent weather. |
Joined May 2010
Some thing to try What ever works fer u.Kerry |
Joined May 2010
I put 4 packs through the fox today at 50mm C/G with no problems' although I did not test stalls. I would GUESS that it might want to drop a wing at the stall based on the aileron sensitivity. "rhawk has used 55mm" Kerry |
| Thread Tools | |
| Mini-Review FOX ST-Model /Kyosho /Hype /Ripmax 1.8m /71" EPO PnP/RTF BL/ Glider | McMoron | Electric Sailplanes | 407 | Nov 13, 2012 05:41 AM |
| New Product HobbyKing Minimoa 2mtr R/C Glider EPO w/ Motor, ESC, Servos Plug-n-Fly | Bowerz | Electric Sailplanes | 3 | Aug 28, 2011 01:28 PM |
| Discussion HobbyKing 3D 30" EPO Yak 54 | Bowerz | 3D Foamies | 39 | May 06, 2011 11:39 PM |
| Sold WindRider Fox EPP Glider $60 + Shipping | ShoGinn | Aircraft - Sailplanes (FS/W) | 1 | Aug 23, 2010 09:21 PM |
| Discussion St model fox glider | Staudacher600 | Electric Sailplanes | 2 | Aug 04, 2010 10:42 PM |
