Old May 21, 2011, 08:44 AM
biggy boy is offline
Find More Posts by biggy boy
prop wash
biggy boy's Avatar
North of Toronto in Ontario
Joined Dec 2002
Originally Posted by Ant View Post
Must be "New Glider" day at the distributors.
Hobby lobby has 2 more, including this nice looking Fox.
That is a nice fox!
Made some setup changes, moved the battery forward by 3/4 of an inch
a little over a centimeter. Added a Dime to the right wing.
Now it is better balanced front to back and side to side.
Had it out for a 20 minute flight this morning and it now flies better.
And it now "turns on a Dime" pun intended
I'm finding I still have to give lots of down elevator when climbing.
Still need to take out the motor mount again and add some down thrust.
After 27 years of NOT flying a sailplane, my thermal hunting skills suck
OH well I had fun anyway today!
New battery location:
Balancing dime located out board of the aileron (tipside)
Glen
biggy boy is offline Find More Posts by biggy boy
Old May 21, 2011, 10:32 AM
Ant is offline
Ant
Find More Posts by Ant
Ant
Old Noob.
Ant's Avatar
Joined Nov 2003
Glen
Did my wing just rock, or was that a .02 mph gust?
Ant is offline Find More Posts by Ant
Old May 21, 2011, 11:47 AM
prop wash
biggy boy's Avatar
Joined Dec 2002
Or was it shaky nervous hands on the radio sticks????
Glen
Old May 21, 2011, 06:08 PM
prop wash
biggy boy's Avatar
Joined Dec 2002
Found out what happens when you leave your fox out in the full sun
The heat under the clear plastic on the canopy got hot enough to heat up and expanded the EPO foam to the point of it separating into beads.
Now I have a black and white interior LOL
Glen
Old May 21, 2011, 09:32 PM
Ant is offline
Ant
Ant
Old Noob.
Ant's Avatar
Joined Nov 2003
Hey Glen, that kinda looks like Naugahyde now.
Old May 21, 2011, 09:39 PM
prop wash
biggy boy's Avatar
Joined Dec 2002
Ya looks very retro 70s
Old May 22, 2011, 03:33 PM
jeanorwin is offline
Find More Posts by jeanorwin
Joined Jan 2011
Atleast the canopy is still in one piece - not like mine I should take a picture of the Jeans Astir from my gliding club - That thing looks like someone stole the seat and put some paper in it to make sure no-one notices it..
Anyways, the air brakes work fine - Even if you have to close them quickly(Like, you have to push the button down quickly) because they won't close completely otherwise.
jeanorwin is offline Find More Posts by jeanorwin
Old May 22, 2011, 04:25 PM
prop wash
biggy boy's Avatar
Joined Dec 2002
What does the rest of the glider look like sounds scary!!
Glen
Old May 22, 2011, 05:41 PM
pullup! is offline
Find More Posts by pullup!
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
rough camera mount
Flew the fox today in some horrible conditions. It was almost like the wind was blowing straight down! My buddy even gave up with his 40 nitro trainer because it was just getting pummeled.
So I made a quick and dirty "canopy" for the Fox/Go Pro. Blue foam shaped and painted white, couple velcro straps and almost done. I need to make the strap system for the camera still and I'm going to countersink the main straps into the foam to give a better shot.
pullup! is offline Find More Posts by pullup!
Old May 22, 2011, 06:06 PM
prop wash
biggy boy's Avatar
Joined Dec 2002
Looks good Pullup! probably better video quality then my HD key-chain video camera!??!??!??
Glen
Old May 22, 2011, 10:07 PM
Ant is offline
Ant
Ant
Old Noob.
Ant's Avatar
Joined Nov 2003
Hey looking good there pullup!
I am thinking about something like this setup.
How much does that GoPro weigh?
Ant
Old May 22, 2011, 11:04 PM
Berkie is online now
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
Hey guys, I've got the standard motor in mine (HK) and if I advance throttle
quickly the motor screams like a wild parrot and cuts out
If I accelerate slowly it's OK
Poorly set magnets?
Kev
Berkie is online now Find More Posts by Berkie
Old May 23, 2011, 12:34 AM
Helitime is offline
Find More Posts by Helitime
Pickering Ontario CANADA
Joined May 2010
Poorly set magnets?
Kev
Hey Kev:
A weak batt. pack (low C rating and or old pack) can give the same result. Also, increasing prop size or pitch can make it worse.
Just some thoughts, testing with a larger pack first might be easier than pulling the motor apart. :-)
Kerry
Helitime is offline Find More Posts by Helitime
Old May 23, 2011, 10:52 AM
pullup! is offline
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
Ant
Without case the Go Pro is 98 grams.
Old May 23, 2011, 12:19 PM
Ant is offline
Ant
Ant
Old Noob.
Ant's Avatar
Joined Nov 2003
Ant
Mini-Review FOX ST-Model /Kyosho /Hype /Ripmax 1.8m /71" EPO PnP/RTF BL/ Glider McMoron Electric Sailplanes 428 Dec 03, 2015 02:43 AM
New Product HobbyKing Minimoa 2mtr R/C Glider EPO w/ Motor, ESC, Servos Plug-n-Fly Bowerz Electric Sailplanes 8 Jul 29, 2015 10:28 AM
Discussion HobbyKing 3D 30" EPO Yak 54 Bowerz 3D Foamies 39 May 07, 2011 12:39 AM
Sold WindRider Fox EPP Glider $60 + Shipping ShoGinn Aircraft - Sailplanes (FS/W) 1 Aug 23, 2010 10:21 PM
Discussion St model fox glider Staudacher600 Electric Sailplanes 2 Aug 04, 2010 11:42 PM
