Old Dec 01, 2010, 08:24 PM
Pickering Ontario CANADA
Joined May 2010
Hey Robbie: Open up that flycam, the batt. has a plug. You can use reg. charger, meter etc. I have the wire outside the case with an elastic band to keep them together. :-)
I have a keychain cam also that I opened. I soldered tiny hair sized wires on the batt. and stuck the other end in the screw holes. I can put a meter to the screws and check the pack or aligator clips to charge.
They are all 1 cell lipo's :-)
Helitime is offline Find More Posts by Helitime
Old Dec 01, 2010, 08:49 PM
American since 1947
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Mine is the Turnigy CAm, the white one form our pals at HK for ~ $18
or whatever price it's going for now !
I had a Key Fob cam and it worked great for a couple months then quite for no reason.
I hadnt used it it had just been sitting there and Pffffft ! ???
Yeah yeah I took it apart
The T CAM seems to be working fine just now !!!
AND
The ESC works too !
I cut off the Heat shrink and gave it a blower treatment.
Seems OK !
birdofplay is offline Find More Posts by birdofplay
Old Dec 01, 2010, 10:08 PM
Joined May 2010
Bob, 4 cells? I thought it was only good for 3 cells. I bet the climb was GOOD.
I assume you know about the reset on the key cam. :-)
Old Dec 01, 2010, 11:34 PM
American since 1947
birdofplay's Avatar
Joined Dec 2005
yep !
the printing on MY ESC "says" 2-4 cells 30Amps.
4 cells definitely put some pep in the climb out :-)
Nothing F3 like but Nice enough to stop any complaints.
They were some 2s1p 2000ma Nano Tech Paks
I just made up a Y connector to adapt them into a 4s1p.
Old Dec 02, 2010, 12:41 AM
Joined May 2010
More volts = less amps I think. Maybe I could use this esc on 4 cells, I pull 40 amps peak on 3 cells. I like to have an esc rated 10 amps higher than I peak.
No matter, the motor is only rated for 3 cells. :-( HK, NOW says my motor only makes 300 watts (was 400>?). I have an e-logger reading at 421 watts.??
I just tested "high vis. fluorescent orange" paint on some scrap foam and it works. I'm thinking complete underside of the main wing and horz. stab. I should have done the rudder alone while it was off, now it's a lot of tapeing. The red air brakes are now white on top.
Old Dec 02, 2010, 07:11 AM
Joined Mar 2009
I wound up giving the FlyCamOne2 to a co-worker explaining that he'd need to do what you just said to get it back to life. He did and it's working great for him, so you're 100% correct! I went with the keychain cam that I think is like the one Bird has. It's given me no trouble at all to date. It's been far more reliable than the FlyCamOne2 ever was but it doesn't do sound with video. I've included a picture of it. It only weighs 18g!
Robbie
robbiehatfield is offline Find More Posts by robbiehatfield
Old Dec 02, 2010, 07:19 AM
Joined Mar 2009
Originally Posted by birdofplay View Post
AND
The ESC works too !
Seems OK !
Good news bird! Sounds like it was just the moisture. Cool that it will work with 4 cells. The current should go down somewhat depending on how efficient the motor is at the higher voltage with a net increase in power like Kerry has suggested. I think that most of the guys flying the similar sized Diamond 2500 are using 4 cells and that motorglider really performs well from the videos I've seen. What drew me to this Fox motorglider though were the cockpit possibilities for scale looks. I never cared for a foam cockpit like the Diamond or the Radian. You could say I'm a scale type of guy, but I'm also a lazy scale guy who looks for most of the work to be done already. LOL
Robbie
Old Dec 02, 2010, 07:52 AM
Joined May 2010
Hey Robbie, thats the "gum" cam (pic), I have one also aswell as the lighter cam and several key fob. cams. The key cams (look like a remote for your car locks etc.) work best from my experience (sound also). I got one delivered to work for $10 with a memory card, off ebay. The other was $14, ebay can be cheap if your carefull. Search "spy cam" on ebay, you can get many dif. ones. Watch the delivery charges! I paid under $20 for another type but saw them listed near $100
Old Dec 02, 2010, 11:03 AM
Joined Dec 2010
Hello,
First, thank you for all the information.
I have a question: what kind of servo you use for change?
the HTX 900:http://www.hobbycity.com/hobbyking/s...?idProduct=662
or the HTX 500:http://www.hobbycity.com/hobbyking/s...?idProduct=663
Papaye is offline Find More Posts by Papaye
Old Dec 02, 2010, 11:33 AM
Joined Mar 2009
Originally Posted by Papaye View Post
Hello,
I'd go with the HTX 900. More torque is better and the slightly slower speed of 20 mSEC won't be noticeable with this motorglider.
Robbie
Old Dec 02, 2010, 12:01 PM
Joined May 2010
Papaye: Yup, like Robbie says HXT900's thats what I put in mine. :-)
Hey Papaye, first post, welcome aboard. I am also fairly new, to posting at least. Although I have been reading the threads for a few years. VERY HELPFULL
Cheers: Kerry
Old Dec 02, 2010, 12:52 PM
American since 1947
birdofplay's Avatar
Joined Dec 2005
I have some of the "OTHER" hinges that I found in a drawer.
They WORK the same as the installed versions but they are MUCH LESS SLOPPY !
I think they came from Hobby Lobby.
They have a nicer "Molding" and stiffer Plastic type.
Anyway I am going to attempt to REPLACE the Rudder hinge.
If that works as well as I am hoping
THEN I will "DO" the ailerons too, and avoid all the routing and surgery.
News as it breaks !
Old Dec 02, 2010, 02:12 PM
Joined Mar 2009
Cool Bird! Please let us know. I never even considered replacing the hinges.. It still may be an issue with the rudder though as at least with mine, the wire was binding making the corner at the tail up to the hinge.
Robbie
Old Dec 02, 2010, 11:41 PM
Joined May 2010
If it were warmer around here I could go flying, although I don't have a spinner for it yet. :-)
A couple pics less paint, one to show tail deflection with the elevator dialed back. It takes less than 3 min's to take apart and pack in it's box.(good thinkin Bob)
Old Dec 02, 2010, 11:49 PM
Joined May 2010
HK just added 3 new gliders :-)
Mini-Review FOX ST-Model /Kyosho /Hype /Ripmax 1.8m /71" EPO PnP/RTF BL/ Glider McMoron Electric Sailplanes 407 Nov 13, 2012 05:41 AM
New Product HobbyKing Minimoa 2mtr R/C Glider EPO w/ Motor, ESC, Servos Plug-n-Fly Bowerz Electric Sailplanes 3 Aug 28, 2011 01:28 PM
Discussion HobbyKing 3D 30" EPO Yak 54 Bowerz 3D Foamies 39 May 06, 2011 11:39 PM
Sold WindRider Fox EPP Glider $60 + Shipping ShoGinn Aircraft - Sailplanes (FS/W) 1 Aug 23, 2010 09:21 PM
Discussion St model fox glider Staudacher600 Electric Sailplanes 2 Aug 04, 2010 10:42 PM
