Old Jun 06, 2012, 12:10 PM
Helitime is offline
Find More Posts by Helitime
Pickering Ontario CANADA
Joined May 2010
Originally Posted by phil alvirez View Post
ok, guys. i know this could be posted somewhere else but i have got a great raport here:
what is the maximum capacity that is allowed to send lipos (from hk-or any1 else) by air?
recently ordered some 1000 and 1300's from hk and it is taking way longer than usual.
thanks
Non lipo orders ship Hong Kong Post. Lipo orders ship Singapore Post and take on average about a week longer.
Total capacity is not an issue (I don't think). They cannot ship Lipo's through HK Post although they may sneak a small one in if it is part of a kit.
Helitime is offline Find More Posts by Helitime
Old Jun 06, 2012, 12:14 PM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
delivery on lipos
thank you very much.
good to know.
you guys are great.
phil alvirez is offline Find More Posts by phil alvirez
Old Jun 06, 2012, 01:16 PM
Joined Jul 2007
L3010C motor connectors
just got the motor L3010C suggested for the fox. it comes with male golden bullet connectors. but, how do i know what size are they? the specs don't say anything.
where should i measure them to know? i need to know this to order some to match for the pack.
as a comparison, i have tried to measure the 2mm's golden bullets that i use for smaller things, but i can't find where they are 2mm.
thanks
Old Jun 06, 2012, 02:38 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
My method is to plug them into existing connectors and if they fit tight, they are good to go.
I use a Harbor Freight digital caliper to measure most things. http://www.harborfreight.com/6-inch-...per-47257.html
The inside measurement of a 3.5mm connector is 3.5mm. The male with the springy thingies was in the 3.6Xmm range.
hoppy is offline Find More Posts by hoppy
Old Jun 06, 2012, 02:44 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
FWIW.....
1st The elevator hold down screws wereI replaced with longer ones and cut to fit. The ones I got were not a good fit.
2nd - The nuts in the elevator did not match up with the bolt holes . I shaved off some off the front of the elevator (plastic and foam) until the holes lined up. It was also necessary to make the slot in the plastic nut holder a little deeper to make up for the amount I cut off. It was probably about 1/16" that was removed.
On my original Fox I just crammed and jammed and made a mess of it.
Old Jun 06, 2012, 06:21 PM
Joined Jul 2007
buy and try
seems that hk has 3.5 and 4mm. i may have to buy 1 set of each to learn if they match.
Old Jun 18, 2012, 06:36 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Hatch hold down
After having a hatch come off in flight, I decided to secure it better as those fittings that came with the FOX seem flimsy.
Melted a vertical slot in the fuselage with a piece of hot hack saw blade and epoxied in a length of cloth backed Velcro.
Used Velcro with adhesive on it to attach a piece to the canopy.
That's all folks.
Old Jun 21, 2012, 09:03 AM
Mats W is offline
Find More Posts by Mats W
Stockholm
Joined Jan 2010
Hi, would it be hard to put a bigger battery in??
Im thinking of an LiPo 3S/ 4A (145X50X25 mm).
// Mats W
Mats W is offline Find More Posts by Mats W
Old Jun 21, 2012, 09:31 AM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
// Mats W
This thing has a huge battery compartment. It'll take quite a large battery and an even bigger one if you cut out some foam. However, the big problem will be balance. With a 2200, I still need a bit of weight in the tail. If you put in a 4000 as far back as it'll go and put the servos in the tail, you may still need more weight back there.
xviper is online now Find More Posts by xviper
Old Jun 21, 2012, 02:09 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
I needed a 3s1800mah pack moved back 4" (Had to cut out a lot of foam) and still needed 2 1/2oz of lead in the tail. The pack is behind the cg so a bigger pack may be better. I'll check that out tonight.
OOOPs, my mistake, the cg is well behind the battery pack so a larger pack would demand a big chunk of lead in the tail. I wouldn't go that direction.
Old Jun 25, 2012, 05:55 AM
stevo0476 is offline
Find More Posts by stevo0476
Belgi, Vlaams Gewest, Brugge
Joined Sep 2011
Xviper said it, it will be nose heavy with a bigger battery wich leads us to a question, why would you need a bigger battery? On a Turnigy 2200 3S this bird will soar for ages without wanting to come down.
Stevo
stevo0476 is offline Find More Posts by stevo0476
Old Jul 13, 2012, 08:08 PM
rclab1 is offline
Find More Posts by rclab1
USA
Joined May 2010
whats the maximum 3s lipo (mah?) you guys are flying with? (with the elevator and rudder servo mods' in the back of the plane).
Also, planning on putting a Hacker A30 motor (900-1200kv) on 11x6 /12/6 Graupner folders'....
Too heavy?
rclab1 is offline Find More Posts by rclab1
Reply With Quote  (Disabled)
Old Jul 13, 2012, 08:26 PM
Mattacks is offline
Find More Posts by Mattacks
Mattacks's Avatar
Joined Aug 2011
I dunno if that would be too heavy. The graupner folders seem like a good idea.
Mattacks is offline Find More Posts by Mattacks
Old Jul 18, 2012, 04:55 PM
TeeJayBee is offline
Find More Posts by TeeJayBee
United Kingdom, Swansea
Joined Mar 2011
A little help please...
My Fox glider seems to pitch up excessively with throttle
It's worse downwind than upwind, I have no choice but to use down elevator to compensate especially if I'm not full throttle as less than full throttle it will pitch up and almost immediately want to stall, full throttle will drag the plane through without stalling but it will also pitch literally vertically
I have the CG set to 40mm behind the leading edge and check every time before flight
Any ideas on how to fix this without using a throttle/elevator mix ?
TeeJayBee is offline Find More Posts by TeeJayBee
Old Jul 18, 2012, 05:19 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Tee,
Add down thrust to your motor mount is one way to do what you want.
I've found that a cg closer to 52-55mm from the leading edge is a good place to have it. As the plane sits with the servos powered up, is the elevator slightly up? 40 mm is a nose heavy cg which requires up elevator. Moving the cg back may help you.
Mini-Review FOX ST-Model /Kyosho /Hype /Ripmax 1.8m /71" EPO PnP/RTF BL/ Glider McMoron Electric Sailplanes 428 Dec 03, 2015 01:43 AM
New Product HobbyKing Minimoa 2mtr R/C Glider EPO w/ Motor, ESC, Servos Plug-n-Fly Bowerz Electric Sailplanes 8 Jul 29, 2015 09:28 AM
Discussion HobbyKing 3D 30" EPO Yak 54 Bowerz 3D Foamies 39 May 06, 2011 11:39 PM
Sold WindRider Fox EPP Glider $60 + Shipping ShoGinn Aircraft - Sailplanes (FS/W) 1 Aug 23, 2010 09:21 PM
Discussion St model fox glider Staudacher600 Electric Sailplanes 2 Aug 04, 2010 10:42 PM
