Old May 24, 2012, 10:27 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Originally Posted by hoppy View Post
Left wing down, attempt to roll right with right aileron command yielded no response from plane. As this happened once with the plane gliding at a high altitude with no elevator input, I wrote off stall at the time. I can't remember flying it any differently than the previous 8 flights which had no problems. Like Kerry mentioned, the first thing I tried upon reaching the plane was seeing if I had ailerons as the plane had reacted as if the aileron servos had stopped working.
Thanks for the thoughts, I'll havve to ponder on them and see if they might explain what happened.
This happened again on the last flight. A close examination showed the wings to be non-symmetrical. This probably (certainly) happened on my collision with the Lacrosse goal which caught the plane midway on each wing splitting one wing open as this problem started at this time. My repair job must have skewed the airfoil. It probably is a stall that is occurring well above the normal stall speed on the left wing. The problem is the stall is occurring at what I would call normal gliding air speeds. Under power it's OK.
Solution - new wings on the way.
hoppy is offline Find More Posts by hoppy
Old May 24, 2012, 02:38 PM
GrahamWilson is offline
Find More Posts by GrahamWilson
Beating air into submission!
GrahamWilson's Avatar
Australia, NSW, Vaucluse
Joined Aug 2011
Hoppy the new wings are the best solution. Just check the take off weight of the model to make sure it has not put on too much mass from previous repairs. Weight will also increase the stall speeds.
GrahamWilson is offline Find More Posts by GrahamWilson
Old May 25, 2012, 03:29 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
FWIW,
NitroPlanes has spare wings/fuselage/elevator/etc on sale. I hope they are not closing out the model.
Old May 27, 2012, 12:49 PM
stevespana is offline
Find More Posts by stevespana
Huesca, Spain
Joined Aug 2009
I did a couple more flights with the Fox this weekend and I think the CofG needs moving back further than 51mm, which is the current setting. I think I may go for 55mm and see what that does.
With power off the nose is still dropping noticably and I'm having to use lots of up trim to maintain level flight.
Steve.
PS. Had a great weekend of flying though...............
Fox 2 flights, ASW17 2 flights, Graupner Terry S 4 flights, Graupner UHU 4 flights, Telink Tetra 3 flights. And finally, maidened a Multiplex Fun Cub.
Very satisfying !
stevespana is offline Find More Posts by stevespana
Old Jun 02, 2012, 12:21 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Spare parts wing fuselage elevator
Info for those wondering what parts come with a replacement part.
The Wings come with control horns and screws for them. Add your servo and you're ready to go.
The elevator also comes with the control horn parts and fuselage attachment screws
The fuselage has the motor mount installed, the rudder is hooked up, the control rods are in place waiting for your servos and motor to go in.
Old Jun 04, 2012, 04:41 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
HELP - Anyone using the Collet Type Spinner.
I'm to the step of attaching the motor to the motor mount and noticed the collet type folding prop spinner sits about 1/4-3/8" from the fuselage even with the motor shaft cut off some.
I assume this is par for the course but was wondering if anyone had a slick fix for this.
Old Jun 04, 2012, 05:18 PM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
perhaps filling some of the space and still leaving some clearance for cooling, and using a smaller diameter spinner like 40mm?
i think helitime has talked about filling-in the space.
phil alvirez is offline Find More Posts by phil alvirez
Old Jun 04, 2012, 05:41 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
plus 1
Bombay is offline Find More Posts by Bombay
Old Jun 05, 2012, 06:56 AM
Helitime is offline
Find More Posts by Helitime
Pickering Ontario CANADA
Joined May 2010
Hey Hoppy
See page 15 post #223
Kerry
Helitime is offline Find More Posts by Helitime
Old Jun 05, 2012, 08:40 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Originally Posted by Helitime View Post
Hey Hoppy
Kerry
Now that's slick!
Excuse me while I go look through the waste cans.
Old Jun 05, 2012, 10:29 AM
Joined Jul 2007
diameter?
Hey Hoppy
Kerry
that looks great! thank you for bringing it.
and what diameter is that spinner on post 223? ideally the p/n?
thanks
Old Jun 05, 2012, 12:06 PM
Helitime is offline
Joined May 2010
thanks
Spinner:http://www.hobbyking.com/hobbyking/s...idProduct=5565
Old Jun 05, 2012, 12:31 PM
Joined Jul 2007
right on
thanks again, sir. that's the 1 i ordered following your advice before.
just to make sure.
Old Jun 05, 2012, 08:45 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Remember the old story, when you asked the guy if you should replace or fix the car he says "fix it". Keep the radiator cap and replace everything else.
That's the way it is with my Fox - new body, new wings, new elevator, new cockpit cover, new spinner - kept the electronics/motor and scraped the rest.
Found a cardboard tube and used my 60/40 glue-water mix to waterproof it and now letting it dry. In the mean time, I installed the motor and after putting it all together that gap doesn't look too bad. I'll have to look at it again tomorrow. My spinner is 42mm and just a bit narrow so the 45mm should be perfect.
Old Jun 06, 2012, 11:29 AM
Joined Jul 2007
delivery time on lipos
ok, guys. i know this could be posted somewhere else but i have got a great raport here:
what is the maximum capacity that is allowed to send lipos (from hk-or any1 else) by air?
recently ordered some 1000 and 1300's from hk and it is taking way longer than usual.
thanks
Mini-Review FOX ST-Model /Kyosho /Hype /Ripmax 1.8m /71" EPO PnP/RTF BL/ Glider McMoron Electric Sailplanes 428 Dec 03, 2015 01:43 AM
New Product HobbyKing Minimoa 2mtr R/C Glider EPO w/ Motor, ESC, Servos Plug-n-Fly Bowerz Electric Sailplanes 8 Jul 29, 2015 09:28 AM
Discussion HobbyKing 3D 30" EPO Yak 54 Bowerz 3D Foamies 39 May 06, 2011 11:39 PM
Sold WindRider Fox EPP Glider $60 + Shipping ShoGinn Aircraft - Sailplanes (FS/W) 1 Aug 23, 2010 09:21 PM
Discussion St model fox glider Staudacher600 Electric Sailplanes 2 Aug 04, 2010 10:42 PM
