Old May 20, 2012, 10:01 AM
Helitime is offline
Find More Posts by Helitime
Pickering Ontario CANADA
Joined May 2010
For a pic of the hole location xviper is refering to see page 32 post 470.
Kerry
Helitime is offline Find More Posts by Helitime
Old May 20, 2012, 11:01 AM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
clamping to the rod
thank you gentlemen. the 2 mt asw 28 from hk uses same idea.
regards
phil alvirez is offline Find More Posts by phil alvirez
Old May 21, 2012, 02:48 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Originally Posted by Helitime View Post
She may not be pretty but she's ready to fly.
Repairs were made mostly with Gorilla glue, clamped with stretch wrap]
EDIT:
On further investigation, the motor which spun free and true without blades was a little noisy when the blades were added. I put an in line meter in and throttled it up slow to max and back off. This read 50 AMPS, previously this test yielded about 38 AMPS so I guess the motor needs repair or replacement. The pack seems to have survived also so I think I came out lucky considering she went in "with authority".
Kerry
Hi Kerry, great tip on the stretch wrap!
About the 38A, was that with the stock motor/prop?
hoppy is offline Find More Posts by hoppy
Old May 21, 2012, 03:52 PM
Helitime is offline
Joined May 2010
The 38 AMPS was with an HK 2836, 1000KV with 11X8 Graupner Cam blades on a 2200mah 40C pack.
Wow, 17,000 posts, thats about 15 years of typing at my speed
Kerry
Old May 21, 2012, 05:16 PM
Joined Jul 2007
screws holding the stab
what are the screws that hold the stab?
diameter, thread, lenght. like m3x40, something...
thanks
Old May 21, 2012, 05:31 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Mine are M3 x 30mm
Bombay is offline Find More Posts by Bombay
Old May 21, 2012, 06:18 PM
Joined Jul 2007
m3x30
Originally Posted by Bombay View Post
Mine are M3 x 30mm
great! hk has them:
http://www.hobbyking.com/hobbyking/s...pcs_pack_.html
thanks
Old May 21, 2012, 07:27 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Those should work. Keep in mind that alignment of the holes all the way up thru the fuselage and into the nut is crucial. Mine were not aligned and I was convinced that the screws were too short. I purchased 35mm and found that they still wouldn't thread. It wasn't until I drilled out the holes a little that I was able to align and sync.
Old May 21, 2012, 07:36 PM
doug.wagner is online now
Find More Posts by doug.wagner
I can fix that!
doug.wagner's Avatar
United States, ME, Bangor
Joined Jul 2011
Screws too short!
My stab screws were a hair too short to grab the threads in the nuts.
I got 3x35 mm screws, and they screwed right in. I did have to trim off a mm or two, though.
doug.wagner is online now Find More Posts by doug.wagner
Old May 22, 2012, 01:40 AM
Joined Jul 2007
30 and 35
thank you guys. you are great! as am buying screws, i will order both 30 and 35 just in case. you never know. and am getting some nuts in case i need to shorten the 35 so i can drive 1 before i shorten it to help clean the thread. thanks again.
Old May 22, 2012, 08:45 AM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
I think if you slightly compress the stabilizer and fuselage as you reach the nut with the 30mm screw, you will find that it meets. Obviously, you want to screws to tightly secure the stab to the fuselage. I finally abandoned the 35mm screws once I realized this...and that i would have had to cut the 35mm screws (creating a potential problem of it's own).
Old May 22, 2012, 09:10 AM
Joined Jul 2007
sound advice
agree. i will try as you do.
thanks
Old May 24, 2012, 01:35 AM
Joined Jul 2007
amps/watts
could you please bring data (or link) on the amps/watts you get with your motors/props?
am trying to find the right esc and connectors for my outfit and don't want to go too low.
thanks
Old May 24, 2012, 08:22 AM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
thanks
The ESC that comes with the nitroplanes setup is 40amp. As stated above in previous posts, stock setups are pulling 30-38 amps as the norm.
Of course, it will really depend on the motor and prop combo. In any case, standard connectors dean's "t", EC3, bullets, powerpoles, would be fine.
Very soon, i will be putting an amp meter on mine. I'll post the results.
Old May 24, 2012, 09:58 AM
Joined Jul 2007
motor in
for what i see, 2 of the best motors are the 3010 and the 2836. for those in particular i would like to learn amps/watts and connectors size. ideally golden bullets if anybody is using them.
thanks
Mini-Review FOX ST-Model /Kyosho /Hype /Ripmax 1.8m /71" EPO PnP/RTF BL/ Glider McMoron Electric Sailplanes 428 Dec 03, 2015 01:43 AM
New Product HobbyKing Minimoa 2mtr R/C Glider EPO w/ Motor, ESC, Servos Plug-n-Fly Bowerz Electric Sailplanes 8 Jul 29, 2015 09:28 AM
Discussion HobbyKing 3D 30" EPO Yak 54 Bowerz 3D Foamies 39 May 06, 2011 11:39 PM
Sold WindRider Fox EPP Glider $60 + Shipping ShoGinn Aircraft - Sailplanes (FS/W) 1 Aug 23, 2010 09:21 PM
Discussion St model fox glider Staudacher600 Electric Sailplanes 2 Aug 04, 2010 10:42 PM
