Closed Thread
Old Mar 29, 2011, 08:04 PM
SilentHunter's Avatar
United States, Death Valley
Joined Aug 2003
Why Bother drew, get some car ESC's and program the TX so reverse works friendly for its application. Thats what I would do for reversing with nacelles of those type.
SilentHunter is offline Find More Posts by SilentHunter
Old Mar 29, 2011, 09:10 PM
Avoid The Ground!
Flexserve's Avatar
United States, FL, Lutz
Joined Sep 2008
Originally Posted by silenthunter View Post
why bother drew, get some car esc's and program the tx so reverse works friendly for its application. Thats what i would do for reversing with nacelles of those type.
lol ftw.
Flexserve is offline Find More Posts by Flexserve
Old Mar 29, 2011, 09:14 PM
Joined Aug 2003
So are you ordering your reversing esc's now?
http://www.hobbyking.com/hobbyking/s...idProduct=8993
LOL. The problem is that car esc's rarely go above 4 cell voltage, the kong sized one above does 4 cells.
One needs to look around for options on this.
Old Mar 29, 2011, 09:18 PM
Joined Aug 2003
Actually that esc fills the bill nicely, its not THAT big. And 100 amp is perfect.
Remove the fan, and re position the capacitors to suit.
Old Mar 30, 2011, 01:07 AM
Up-Out-&-Gone
demondriver's Avatar
Charelston SC U.S.A.
Joined Mar 2007
Guys I've been thinking ever since K Mr A380 asked about internal thrust reversers & after 4 or 5 large mugs of coffe I think I may have something
"Internal thrust reverser Doors Like clamshells that reverse the EDF's thrust flow.
demondriver is online now Find More Posts by demondriver
Latest blog entry: Joe Nall 2013!
Old Mar 30, 2011, 05:25 PM
drew1231's Avatar
Joined Jan 2009
Yes, of course, I was just pondering how to make a scaled down mechanism.
drew1231 is offline Find More Posts by drew1231
Old Mar 30, 2011, 05:28 PM
drew1231's Avatar
Joined Jan 2009
Yes, that is what I said in my previous post, sliding the cowl also would allow for escaping air.
Would be tough to place the servos, but I digress.
Old Mar 31, 2011, 12:50 AM
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
^^^^I kinda disagree with it. sometimes we've just got to dumb things down a bit and think of the simplest solution. this mechanism would be super simple to make, without putting much (if any) load on the servos. the hardest part would be making the outer shell slide open when the clamshells close. that being said, even that can be dumbed down to get the simplest solution.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Mar 31, 2011, 10:27 AM
Joined Aug 2003
Well if its so easy to make lets see it on your 57!
Everything seems simple in the head, I've built enough stuff to know that it usually does not end up that way. Even the "simpleset" device ends up being a pita! Look at my reversing shells. Quit a bit of screwing around!
Yeah you can make little doors open etc, but if they do nothing then its pointless really. I have never studied thse devices before, not sure whats going on in there on the real ones or the angles etc.
Old Mar 31, 2011, 04:20 PM
drew1231's Avatar
Joined Jan 2009
Definitely true, it always never works.
The real ones are pretty complex. They siphon air off of the turbofan, but not the jet.
Old Mar 31, 2011, 08:40 PM
Up-Out-&-Gone
Joined Mar 2007
I found these Pics Silent, they show real schematics of real thrust reversers, Man these things have gotta be complicated to build!
Boeing 767-400 thrust reverser test. (0 min 23 sec)
Old Mar 31, 2011, 08:44 PM
Joined Jan 2009
isn't an EDF basically a turbofan? just sayin. LOL.
as far as the 57 goes, I'm not going that extreme. I know thrust reversers work, even at model scale, but at what cost? there's always something lost from something gained, so I tend to play percentages. as for the above statement, the real ones aren't all that complicated. I was an aero engine mechanic at Air Canada, so I've got some experience with this stuff and the real designs are fairly dumbed down, all things considered. remember that designers will ALWAYS go for the easiest and most cost effective solution to a problem, mostly cause that's what makes sense.
I guess that means I stick to my original statement, although a will concede that simple often can end up becoming complicated.
Old Apr 02, 2011, 06:41 AM
Depressed, Enraged and DF CEO
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
ill use it just because its cool
Keenan smith is offline Find More Posts by Keenan smith
Old Apr 02, 2011, 12:29 PM
I want to fly everything!
Lance Nordby's Avatar
Hillsboro, OR, USA
Joined Mar 2004
If real aircraft were powered by electric motors the engineers would use reversible ESC's. Nyuk, nyuk.
Lance Nordby is offline Find More Posts by Lance Nordby
Old Apr 02, 2011, 07:55 PM
Avoid The Ground!
Flexserve's Avatar
Joined Sep 2008
wow...just..wow...
Closed Thread
Question CMPro 83" Cessna Skylane Availability WINDSHEAR II Nitro Planes 1 Aug 11, 2010 04:22 PM
Sold Ready to Fly Sukhoi 26M in original box w Tx charger and battery 83.00 shipped or BNF blueindian Aircraft - Electric - Micro & Indoor Airplanes 5 Aug 07, 2010 08:44 PM
EDF-40 MD-83 Airliner Hawker Electric Ducted Fan Jet Talk 22 Mar 21, 2004 06:27 PM
