Old Sep 12, 2010, 11:08 PM
Flexserve is offline
Find More Posts by Flexserve
Avoid The Ground!
Flexserve's Avatar
United States, FL, Tampa
Joined Sep 2008
Interesting approach with the poster board. Whatcha glue it with Elmers????? Ca would bleed through. Epoxy?
Flexserve is offline Find More Posts by Flexserve
Old Sep 14, 2010, 06:58 PM
Avoid The Ground!
Flexserve's Avatar
Joined Sep 2008
He's been Silent for awhile (no pun intended). This could be a really good sign!
Old Sep 14, 2010, 10:22 PM
SilentHunter is offline
Find More Posts by SilentHunter
SilentHunter's Avatar
United States, Death Valley
Joined Aug 2003
Unfortunately I have to work on other models for customers...felt like crap yesterday so was slow
But i did manage to fix the flaps, and join the two wing halves I also made the trailing edge of the flaps with the posterpaper, now have to do the ailerons and the outboard of the wing. Also i removed the clear tape covering from the flaps top surface. When it heats up in the sun it looks like crap, the tape expands and make wrinkles. So i just cover them with aluminum tape.
The ca works fine with that board, it soakes in but only a little FYI. It has been coated with something, one side is kinda glossy, like photo paper. Put that side out.
I still have to tweak the plans, so bear with me James.
SilentHunter is offline Find More Posts by SilentHunter
Old Sep 14, 2010, 10:48 PM
Joined Aug 2003
Stuck it together to take a look
Old Sep 14, 2010, 10:59 PM
Avoid The Ground!
Flexserve's Avatar
Joined Sep 2008
Take your time, I am in no rush.
Looks great so far!
Old Sep 15, 2010, 04:52 AM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
Ahh... Eyecandy
I love that wing..
kimhey is offline Find More Posts by kimhey
Old Sep 15, 2010, 02:53 PM
teryn1 is offline
Find More Posts by teryn1
teryn1's Avatar
Tucson, AZ
Joined Aug 2004
where are the slats
teryn1 is offline Find More Posts by teryn1
Old Sep 15, 2010, 10:28 PM
teryn1 is offline
teryn1's Avatar
Tucson, AZ
Joined Aug 2004
Old Sep 17, 2010, 03:25 AM
Joined Aug 2003
Slats are a thought. But to do correctly they need to be planned for while building the wing.
Im not convinced they will add anything to the flight performance with this clark-Y airfoil deal, but a cool factor and some weight...
It however would be easy enough to mount some fixed slats on this plane and see how they work later on. If they have a real flight benefit then yes I think they would be a good addition to the design! but they have to pull their weight, or support their weight I should say.
Old Sep 17, 2010, 08:48 PM
Joined Aug 2003
Engines
Made the nacelle. This will just be duplicated for both sides, no need for a left and right. I cant wait to work on the thrust reversers, will be fun.
I'm designing for the WM400 fan and will look awesome with the intake bullet.
The JT8D-200/wm400
Old Sep 17, 2010, 09:01 PM
Joined Aug 2003
Oh and the rolled fiberglass fuselage sections are a go. Im convinced it will look 1k times better, match the nose and tail much nicer, and be easier to deal with in general. I will layup white pre painted sheets to roll into tubes.
AND, it possible with this setup to have the polished aluminum look like the AA planes if thats what you want.
Old Sep 18, 2010, 07:27 AM
frank40 is offline
Find More Posts by frank40
frank40's Avatar
Denmark
Joined Sep 2005
Realy nice work. like the quality of your work. wow
frank40 is offline Find More Posts by frank40
Old Sep 20, 2010, 08:54 PM
Joined Aug 2003
Just been massaging the fiberglass plugs when I can, the normal GRP model drudgery
Mold parting line on the nose
I scribed in most of the larger detail in the glass parts.
The molds themselves will get polished more, its much easier than polishing the part in this case.
Old Sep 20, 2010, 09:27 PM
kelloggair is offline
Find More Posts by kelloggair
kelloggair's Avatar
centennial/aurora colorado
Joined Mar 2008
wow cant wait to see this finished
kelloggair is offline Find More Posts by kelloggair
Old Sep 23, 2010, 08:55 PM
Joined Aug 2003
So i made a first layup of 1oz cloth and 5.7 oz cloth for the test fuselage tube. Its too heavy... the layup was as dry as possible and its just too much IMO.
The main issue is that i can make the layup lighter, but it would then need carbon uni to not be totally flimsy and the short story is it would just get too exotic and expensive for me to make. In my time and whoever whats to build this planes money.
So the next test is to just use the depron 2mm fuselage like i built, and cover with Econokote. I have an idea to make the Econokote into a tube, then sliding it over the fuselage and shrinking into place.... You know like a big piece of heat shrink tubing...
But we'll see, the best laid plans of...
Im also making the molds right now for the nose, tail and engines
Question CMPro 83" Cessna Skylane Availability WINDSHEAR II Nitro Planes 1 Aug 11, 2010 05:22 PM
Sold Ready to Fly Sukhoi 26M in original box w Tx charger and battery 83.00 shipped or BNF blueindian Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Aug 07, 2010 09:44 PM
EDF-40 MD-83 Airliner Hawker Electric Ducted Fan Jet Talk 22 Mar 21, 2004 07:27 PM
