Old Sep 03, 2010, 11:00 PM
Low Pass is offline
Find More Posts by Low Pass
Some epoxy & it flies again...
Low Pass's Avatar
Santa Cruz, California
Joined Sep 2008
Wow, a lot of nice details. I don't build airliners, but i like your flaps and ailerons.
How do you make the hole pattern?
Low Pass is offline Find More Posts by Low Pass
Old Sep 03, 2010, 11:05 PM
SilentHunter is offline
Find More Posts by SilentHunter
SilentHunter's Avatar
United States, Death Valley
Joined Aug 2003
Oh the "rivets"? I use a simple tool made from a 1" diameter toothed gear. I'll show picts of it soon.
I weighed one wing panel with flaps etc, so far is .2 lbs, or ~4 oz. not bad!
SilentHunter is offline Find More Posts by SilentHunter
Old Sep 04, 2010, 12:26 PM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nřtterřy, NORWAY
Joined Mar 2006
Very nice!
kimhey is offline Find More Posts by kimhey
Old Sep 04, 2010, 08:28 PM
Joined Aug 2003
Spoilers
Figured out the spoilers today. Figuring it out was the hard part. The first wing panel took 4 hours,The 2nd wing panel took 30 minutes All this info will be on the plans and instructions.
Pretty easy to do and good working mechanisim. Made form servo horns, and music wire and some screws. The horns come with HXT-900 servos, so they are the preferred servo for this plane! There is a tiny monofilament fishing line that attaches to the spoilers and the horn, this keeps them closed tight. So the arm itself opens them, and the line closes them tight.
Also the spoilers staggered, so the outboard opens first, then the inboard. This allows the outboards to be used to augment roll control like the big boys.
The spoilers themselves are made form 1/16 balsa, with semi-gloss posterpaper covering bonded with medium CA. The CA gets spread on the wood in a uniform film, then you mist accellerator on the dull side of the poster paper, and bond. Then cut out the spoiler panels from this laminant
Video of spoilers:
http://www.youtube.com/watch?v=xseo-lg26gE
Old Sep 04, 2010, 08:39 PM
Joined Aug 2003
Also I have modded the plans, the inboard flaps will be longer by about 35mm towards the fuselage. Im leaving prototype as is though.
Old Sep 04, 2010, 11:14 PM
Flexserve is offline
Find More Posts by Flexserve
Avoid The Ground!
Flexserve's Avatar
United States, FL, Tampa
Joined Sep 2008
Holy cow! Very Nice!
Flexserve is offline Find More Posts by Flexserve
Old Sep 05, 2010, 02:50 AM
Joined Aug 2003
Wingtips and aileron covers
Aileron covers made from posterboard. Wingtips just depron. I ran wires to the wingtips for nav, landing and logo lights that shine on the tail Airliner gotta have it!
Old Sep 05, 2010, 03:30 AM
Joined Aug 2003
Flap interconnect
Well thats what I call the trim piece between the two flaps Wonder what its real name is.
Posterboard covered with aluminum tape, and bonded to the outboard flap. "Gluing" is when you slather goop on something and stick it in place. Bonding is when you sand, clean and prep the two surfaces and apply adhesive
Old Sep 05, 2010, 04:16 AM
Joined Aug 2003
Here is what will be revised to the wing in the plans. The wing tip chord is ~10mm wider than scale as shown. Yep thats me cheating in wing area lol. If you think I should change the plans to 100% scale let me know your opinion.
Old Sep 05, 2010, 04:45 PM
BK 1125 is offline
Find More Posts by BK 1125
just a modeler
BK 1125's Avatar
LA
Joined May 2008
Nice Rick!
BK 1125 is offline Find More Posts by BK 1125
Old Sep 06, 2010, 12:31 AM
Rudi is offline
Find More Posts by Rudi
Rudi's Avatar
Österreich, Oberösterreich, Laakirchen
Joined Jan 2001
Very nice. Follow your build very close !
Rudi
Rudi is offline Find More Posts by Rudi
Old Sep 06, 2010, 06:26 PM
Avoid The Ground!
Flexserve's Avatar
Joined Sep 2008
I don't think the extra area on flaps and spoilers is going to help much more. However, a bigger wing chord tip could be benificial seeing the MD-80 has some skinny wings as is.
Old Sep 06, 2010, 09:11 PM
Joined Aug 2003
Yeah true, its mostly a scale thing with the flap and spoiler extension.
Painted the wing tops with water based polyurethane a few coats sanding in between. Sprayed on the finish colors, light grey and aluminum. Later on more detail can be added.
Fairings for the flap hinges
Old Sep 07, 2010, 03:14 AM
PANTHERFLYR is offline
Find More Posts by PANTHERFLYR
Retired C-5 Flight Engineer
PANTHERFLYR's Avatar
United States, CA, Fairfield
Joined May 2005
Dude, you truly have some skills! Awesome build! When will the kit be available??
PANTHERFLYR is offline Find More Posts by PANTHERFLYR
Old Sep 07, 2010, 01:07 PM
Joined Aug 2003
Thanks, but actually this is pretty easy building wise. Anyone with some experience will have no probs.
The "kit" will be plans, templates instructions and some parts like the nose, tail and engine nacelles and some other special parts that i will make. So its a short kit really.
As for when, it'll be done when its done
Question CMPro 83" Cessna Skylane Availability WINDSHEAR II Nitro Planes 1 Aug 11, 2010 04:22 PM
Sold Ready to Fly Sukhoi 26M in original box w Tx charger and battery 83.00 shipped or BNF blueindian Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Aug 07, 2010 08:44 PM
EDF-40 MD-83 Airliner Hawker Electric Ducted Fan Jet Talk 22 Mar 21, 2004 06:27 PM
