This thread is privately moderated by chaosMurphy, who may elect to delete unwanted replies.
Old Aug 31, 2010, 09:39 AM
chaosMurphy is offline
Find More Posts by chaosMurphy
Registered HotGlue Addict
chaosMurphy's Avatar
Joined Dec 2006
On-the-wings-of-star
Triple-boomer…
On-the-wings-of-an-EasyStar
Note-adjustable;
CG
Incidence
Down-thrust
Note-size-of
Tail-plane
Payload-bay
The-EasyStar-boomer-setup-has-worked-out-so-well
I-have-on-order
Wings-of-a-Radian-(2-meter)
chaosMurphy is offline Find More Posts by chaosMurphy
Old Sep 02, 2010, 07:50 AM
Fen_flyer is offline
Find More Posts by Fen_flyer
Peter
Mildenhall, UK
Joined Aug 2004
Easy Star Body Mod
Hi Chris
I would be interested in a few more photo's and possibility measurements / plan
so i can try with my own easy star wings. (the only bit left after much use).
thanks
Peter
Fen_flyer is offline Find More Posts by Fen_flyer
Old Sep 02, 2010, 08:21 PM
Joined Dec 2006
Hello-Peter,
Three-hardwood-sticks-(spruce-or-white-pine)-40-inches-long-make-the-fuselage-and-15-inch-motor-mount-stick.
Hot-glue-foam-to-wood
Gorilla-glue-wood-to-wood
Bamboo-BBQ-sticks-for
cross-members-and-
motor-mount-pivot-with-soda-straw-spacers.
With-lite-wing-loading-five-degree-down-trust-works-best-for-me,
will-probably-want-more-with-a-full-payload?
I-have-about-ten-degrees-cranked-into-my-EasyStar-fuse-and
a-tad-too-much-with-an-over-size-motor-and-prop.
Ten-was-OK-on-the-lite-stock-motor.
That-blue-foam-rudder-extension-will-come-off-after-I-wire-up-ailerons
to-serve-three-functions…aileron-(70%-up/30%-down), flaps-and-spoilers.
I’ll-post-tailplane-diminutions-if-you-like.
John
Couple-other-triple-boomers
http://www.rcgroups.com/forums/showthread.php?t=1108085
Please-pardon-the-“dash”-myspacebarbitthedust-
Old Sep 03, 2010, 02:28 AM
Peter
Mildenhall, UK
Joined Aug 2004
Easy star
Thanks for that john
I will have to start building
Peter
Wanted Easy Star Wings EyeFlyPlanes Aircraft - Electric - Airplanes (FS/W) 1 Nov 18, 2009 03:39 PM
Found EZ Star wings EyeFlyPlanes Aircraft - Electric - Airplanes (FS/W) 7 Nov 07, 2009 06:10 PM
Wanted easy star wings steeg Aircraft - Electric - Airplanes (FS/W) 5 Oct 30, 2009 05:42 PM
Discussion Please suggest a design based on EZ STAR wings eran_k Foamies (Scratchbuilt) 5 Mar 18, 2009 07:12 AM
Question Easy Glider wings on an Easy Star? G_Loc Electric Plane Talk 4 Jan 14, 2008 09:41 AM
