Old Feb 05, 2011, 05:11 PM
F-86FLIER4LIFE is offline
Find More Posts by F-86FLIER4LIFE
Landin' On The Canopy BAD
F-86FLIER4LIFE's Avatar
Lee's Summit, MO
i agree with snivilous, the thrust vectoring has been taken to far, for those planes that actually do have it in full scale, then by god put it on there, but putting it on f 16's and things like that is just stupid. IMHO any jet like an f 16 or f 18 doing a flat spin like these do just looks stupid
F-86FLIER4LIFE is offline Find More Posts by F-86FLIER4LIFE
Old Feb 06, 2011, 03:19 AM
firehawkzach is offline
Find More Posts by firehawkzach
firehawkzach's Avatar
United States, TX, Fort Worth
Joined Jan 2011
Eh, thats the beauty of it we can all have our opinions and modify our planes accordingly lol.
I just like innovation of aircraft in general and tend to think that an aircraft with thurst vectoring technology would have an advantage in air-to-air operations. I think the high alpha capability of an F-18 after a catapult malfunction would be superb. The weight would be an issue for sure!
As luck would have it I am having issues with my TV system right now lol.
firehawkzach is offline Find More Posts by firehawkzach
Old Feb 07, 2011, 10:58 AM
ZEROSKIN76 is offline
Find More Posts by ZEROSKIN76
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
thats one sweet jet
ZEROSKIN76 is offline Find More Posts by ZEROSKIN76
Old Feb 07, 2011, 03:40 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Originally Posted by snivilous View Post
...huge draw back with vectored thrust. You need to add tons of weight for the actuators to move around 14,000-22,000 pounds of thrust....
This actually isn't true. The Eurofighter team as well as many other Designers have found via the join X31 project, there are advantages to having TV on any jet. Its more economics, cost overruns and deadlines that often remove TV from many programs.
The Eurofighter has a solution to be added awaiting several cash poor governments approval that proved that TV wasn't heavier, as most already have the actuators needed to vary the nozzle geometry, and that in all manueovers and landings it actually reduces the fuel cost/load and gear maintenance over the life time of the vehicle.
It came up in the F-35A and C design also but as we know that is knee deep in fly aways costs so it gets nixed not because of it having some disadvantages; its the development needed to integrate it into an already well over due multi Billion dollar program in a bad economy.
But as for scale preferrence; totally agree; though I remember seeing FS F-16 put into flat spins at a few airshows without TV. I think its whats stopping them from developing other models that totally don't fit the use of TV, e.g. A-10, F-5, SU-39 or anything in a 90mm straight tail.
For these models, the TV makes up for the lack of rudder. As Mike mentioned you can simply lock it in place with one or two screws, put a thrust tube to bypass it and add a cover for the gap between the fuse and the nozzle.
Removing it may be harder now as they have become very generous with glue in that area that you will likely rip the tail apart trying to get it out. It was easy to remove on the earlier SU34 and F-35 but later they added more glue.
I took one off my Euro and put it in my LX F-35.
As for the landing gear and grass. If you angle drill a hole for a thicker axle an reinforce the mounts it'll handle it. Mike again correctly points out they use a thinner bent wire to connect the wheel to the strut at the proper angle which causes the weak point.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Feb 10, 2011, 01:20 PM
cmd is online now
cmd
Find More Posts by cmd
cmd
cmd's Avatar
Niceville, FL
Bec?
Is there a separate system for powering the 8 servos plus three electrric retract gear other than the ESC in the aircraft? I didn't see anything in the parts lists or review that indicates a separate power source. It seems to me most ESCs wouldn't be able to provide more than an amp or two to the servos and I would think that would be insufficient for this model.
cmd is online now Find More Posts by cmd
Old Feb 10, 2011, 02:34 PM
Lee's Summit, MO
its called a BEC man u can power everything with a seperate BEC and battery if desired.
Old Feb 10, 2011, 04:48 PM
cmd is online now
cmd
cmd
cmd's Avatar
Niceville, FL
Thankyou. I'm well aware of what a BEC does. The question is - is there one in the kit? If not, as there has been no mention of one, how many amps are available to power the servos, landing gear, and receiver from the ESC when running a 6S LiPo?
Old Feb 10, 2011, 05:06 PM
snivilous is offline
Find More Posts by snivilous
High Altitude Specialist
snivilous's Avatar
Joined Jan 2010
"...and an 85 amp ESC with switch mode BEC..."
snivilous is offline Find More Posts by snivilous
Old Feb 10, 2011, 06:44 PM
Lee's Summit, MO
i do not know a whole lot about the plane as i just got it not to long ago, but i know that the esc has a built in BEC that runs the rest of the stuff well on a 6S system.
Old Feb 10, 2011, 11:36 PM
fredmdbud is online now
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
The ESC has an integrated 5A SBEC:
http://www.hobby-lobby.com/fa_18e_su...12449_prd1.htm
fredmdbud is online now Find More Posts by fredmdbud
Old Feb 11, 2011, 12:01 AM
Bajora is online now
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
I did list the kit as having an ESC and BEC, near the top of the review in the right hand column with the "snapshot" of other specifications. I did not mention the current rating of it however.
Hobby Lobby's item description of the F/A-18 on their web site mentions this in re to the ESC: ..."and an 85 amp ESC with switch mode BEC".
One of the closeup photos, included in my review above, of the product box lists the specifications and includes a bullet saying the 85 amp ESC has a 5 amp switch mode BEC. The cover of the assembly manual (lined in my review) also lists that same exact specification.
Bajora is online now Find More Posts by Bajora
Old Feb 11, 2011, 06:55 AM
cmd is online now
cmd
cmd
cmd's Avatar
Niceville, FL
OK, you are flying the airplane and it appears to work, but 5 amps seems low when you are dropping the gear (three motors) with the flaps deployed (loading on two servos), while moving the controls, two aileron servos, plus elevator.
Old Feb 11, 2011, 07:08 AM
Lee's Summit, MO
do you have flaperon set up on yours? if so then how did you fish the freaking extension through the fuselage without damaging anything?
Old Feb 11, 2011, 07:50 AM
AA6JB
Bajora's Avatar
Joined Sep 2004
Lots of folks, including myself, are flying the stock configuration with the stock BEC. I have hhad no problems. 5 amps worth of BEC does not seem low to me. Even with the electric retracts. Remember, these servos are all 9 gram class servos, not standard or digital servos.
Old Feb 11, 2011, 10:33 AM
ColoradoHeliNut is offline
Find More Posts by ColoradoHeliNut
United States, CO, Lakewood
Joined Mar 2007
The BEC's don't bother me as the ESC ltself does. I've seen at least 3 do melt downs. One on the F/A-18 & a friend has had 2 go bad in two diff. Euros. The first one burned up in the air. It started a fire at our feild & if it wasn't for me & my quick legs & a fire extinguisher we would have had a fire that wouldd have made the nightly news. As it was it still burned up a good 20' across circle. If the winds were any higher it would have been bad.
I kind remember a few posts on the old Euro thread too.
His second Euro the ESC started acting like it was hitting LVC in flight after only the second flight. Got it back down & the ESC was super hot about ready to melt. The forst one did the samething right before it started leaving a nice smoke trail.
He has since put in a CC ESC. Flys great now.
The F/A-18 was Warderseeker's on Youtube. He has a new year in photos vid & one pic is of his burned up F/A-18. He said HL was taking care of it but still.
So far mine has been OK but it scares me now to think at anytime it might burn up.
ColoradoHeliNut is offline Find More Posts by ColoradoHeliNut
Article Hacker Model Production Super Zoom XL ARF Review DismayingObservation 3D Foamies 22 Feb 22, 2015 04:56 PM
Article Hacker Model Production Super Zoom 2 ARF Review DismayingObservation 3D Foamies 14 Nov 17, 2012 11:59 AM
Article Hobby Lobby eRC Eurofighter 360 Thrust Vector 90mm EDF ARF Bajora Foamy EDFs 61 Jan 19, 2012 09:37 PM
