Old Aug 31, 2010, 04:12 AM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
Question
3mm vs 5mm LED - if you are not size constrained, any benefit to one or the other?
just out of curiosity, if size is not an issue and you could use either size - 3mm or 5mm LED, is 1 beneficial over the other?
tia,
bob
bob4432 is offline Find More Posts by bob4432
Old Aug 31, 2010, 06:48 AM
big5824 is offline
Find More Posts by big5824
Joined Apr 2010
not really....im guessing 5mm may use more power, youd just have to check the datasheets
big5824 is offline Find More Posts by big5824
Old Aug 31, 2010, 10:45 PM
dmccormick001 is offline
Find More Posts by dmccormick001
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
If weight is important, go with the 3mm. If visability is more important, go with 5mm. They generally put out more light.
dmccormick001 is offline Find More Posts by dmccormick001
Old Sep 01, 2010, 05:38 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Just packaging (the plastic part) is bigger, no difference inside.
..a
Old Sep 01, 2010, 03:10 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
thanks all - weight - not a big deal and from all the datasheets i have read the power requirements look the same. you guys are right on the money
tia,
bob
Old Sep 04, 2010, 06:48 PM
warlockg is offline
Find More Posts by warlockg
Joined Apr 2004
If you need the light to enter a clear plate edge or a gap with lowest losses you focus it and play with the distance, angle, and position(s) to get an acceptable affect.
3 & 5 mm is the diameter that PRIMARLY affects the front diameter of the round, defuse, or convex that is the lens. The 3mm does have better cooling around the emitter if you drive it on its high voltage operating range which heat shortens its life. If you look directly into the emitter the 5mm is less harsh for comparable power emitters.
You can search large catalogs of led designs from Stanley, Osram, or Reseller distributor CML Chicago Miniature Lighting to get a production grade effect, dispersion, and color options. LEDs have many aspects that are bin able or designed in. A good electronics store makes most of these options and the binning rejects available to the consumer in small quantities, as we require.
As the simulation software SPEOS is cost prohibitive for simple objectives and requires solid data models. Usually mockup if the objective pieces works for me. I choose the real world results over developing modeling for basic optics up to 6 target fields for a single emitter in consumer products. I mock if representations are available even with the software and modeling capability at hand.
warlockg is offline Find More Posts by warlockg
Discussion stepper motor controller size only 42.3mm*42.3mm*13.5mm robotdigg Electric Motor Design and Construction 0 May 05, 2010 03:59 AM
Discussion If you fly 3D with one eye closed - are you really flying 2D? AllBread 3D Flying 53 Jan 17, 2010 03:38 PM
For Sale RC SWITCH, for LED kits, smoke generators, pumps or any other electrical device. hshaukat Aircraft - General - Radio Equipment (FS/W) 0 Dec 06, 2009 03:36 PM
