Old Aug 31, 2010, 12:34 AM
G Norsworthy is online now
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, AZ, Tempe
Joined Sep 2008
Whoops!
Caracho-Pike Perfect repair double header
I came over to poach a thermal, thought I was higher, entered to circle in the same direction, and the unthinkable still happened. No rain of parts but both took it pretty hard. The Caracho is definitely repairable, the PP is a toss-up between repair and replace. I have both parties sitting here but will start with the Caracho since it needs to get back in the owner's hands ASAP.
Spent 2 days reading up on the repair threads. The small LE dent is no problem, no worse than the Parker dent in my Opus. The other side has a broken bottom spar and lots of skin delam. There seem to be two general strategies to skin repair, Bob McGowan's pick and CA, and the square cut and replace method. We will probably use a combination of both here.
G Norsworthy is online now Find More Posts by G Norsworthy
Old Aug 31, 2010, 12:49 AM
Master of the Wind
Joined Sep 2008
There is always a need to see some progress. Started with the fuse wrinkle. Alternated between CA and wet permagrit grind and found a glass/kevlar layup underneath. Cut down to but not through the kevlar and took the paint back a bit. Made a bandage of uni carbon followed by 1.5 oz glass, wrapped it in Accuply release film then blenderm tape, tight but not tight enough to collapse the boom. Should be ready to fill and sand tomorrow.
Moved on to pick and fill on the small dent. Pulled up the skin and used CA to attach any delams. Filled in the missing area with balsa. General strategy was to end up slightly low so that the affected area can be feather sanded then back filled with carbon/glass cloth and filled back up to the airfoil shape without cutting any more fibers than necessary out of the patch.
Spent a little time picking and CAing on the bad side where things go back together nicely. Fortunately the center mount and joiner boxes were not damaged. Took out some of the shear web and ground (with vacuum) the spar out where it was broken, as the wrinkled fibers were preventing fitting things back together straight.
Tomorrow will pick up a few more clamps and prepare to glue the spars back to the shear webs. Still pondering how to match that salmon color...
Old Aug 31, 2010, 01:00 AM
Tuomo is offline
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
All parts, also center panel look repailable. Spar is ok, but damage like that is almost impossible fix to like new condition.
Here are some pics from my Aspire center panel. Just to inspire you... the plane was damaged in Turkey WC 2008, and repaired in 1 hours time using just CA, x-acto knife and Vladimir Ava d-box material. The result was perfectly flyable and plane is still in use (although I sold it). Small irregulalities in airfoil do not affect performance in thermal flying. They might hurt distance performance, though.
Just make the repairs strong and beware warps
Later I laminated some carbon to wing underside, to make it stiffer torsionally and in landings.
Tuomo is offline Find More Posts by Tuomo
Old Aug 31, 2010, 01:26 AM
skyboyken is offline
Find More Posts by skyboyken
I do this for fun!
Sunshine Coast, Australia
Joined Sep 2004
I've repaired a lot worse than that on a Caracho and a Shooter and had them fly as well after as before. I'm sure you'll do a better job than me
Ken.
skyboyken is offline Find More Posts by skyboyken
Old Aug 31, 2010, 02:23 AM
Tuomo is offline
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Ken.
Yes, the pics in mail #2 look like perfect repair job. Perfect will become "perfect" again
Old Aug 31, 2010, 12:36 PM
mrfski is online now
Find More Posts by mrfski
Martin
USA, CA, Piedmont
Joined May 2005
Repairs
AirCraft Spruce has a great two part light weight filler that works perfectly for the finishing work on these repairs. It is easy to apply, dries very quickly and sands mooth.
Mart
mrfski is online now Find More Posts by mrfski
Old Aug 31, 2010, 02:12 PM
Master of the Wind
Joined Sep 2008
Thanks for the encouragement. Nice graft, Tuomo. Mart, I will look into that filler as there will be some filling. Couldn't resist and unwrapped the fuse on the way out this morning. Came out really nice with the skin faired down under the patch. If I knew how to paint I think I could hide it.
Old Sep 01, 2010, 12:44 AM
Master of the Wind
Joined Sep 2008
Scored some foam and assorted syringe parts dumpster diving, and picked up two more clamps on the way home. Also a turkey baster to go with one of the tips, but that was not needed yet.
Fixed the skin and hinge line behind the spar with CA. A little ripply but it will have to be patched with cloth and filled anyway. The big job was to glue the spar back to the shear web. First I picked and cut out as much of the splooge fillet as I could get to. Then a dry fit with the clamps. Looked pretty good. Then I used the plastic tip on the syringe to inject epoxy as far back as possible into the shear web and spar joint, which is pretty wide. Put in a little extra for good measure. Clamped it down and went after the other side top with 3 oz carbon and 1.5 oz glass with release film, foam rubber, and books. The LE and TE sight straight. Next will be to feather the bottom spar and replace it with tow, then sister it with graphlite and epoxy/chopped carbon in place of the splooge.
This repair is going better than I thought, but then I haven't started trying to restore the airfoil yet. Looking at the PP maybe isn't as bad as I thought but still worse than this one and gives me a stomach ache.
Old Sep 02, 2010, 12:03 AM
blewis01 is online now
Find More Posts by blewis01
that's gonna hurt...
USA, CA, San Jose
Joined May 2005
Greg - good of you to help out Ken this way. I know he'll apreciate getting back in the air.
Bruce
blewis01 is online now Find More Posts by blewis01
Old Sep 02, 2010, 12:12 AM
Master of the Wind
Joined Sep 2008
Did the spar tonight. Feathered it down with a dremel sanding drum and vacuum. Not sure how wide is necessary but it is about 2.5" total. Next inserted the missing piece of shear web with splooge. Then back filled the missing spar area with tow, above the skin level. Will somehow need to cut that back down but will think about that when the times comes. Finally added 3 pieces of graphlite to sister the top spar just in case buried in splooge, and 3 pieces of graphlite to bridge the LE, which will be much stronger than pure splooge. No pics since I can't work and shoot at the same time, and it got warm again so I have to work fast.
Started sanding and filling the fuse bandage. This part looks pretty good.
Old Sep 03, 2010, 12:31 AM
Master of the Wind
Joined Sep 2008
Cut a window in the newly repaired skin behind the spar so I could access the top skin and glue it back together without so much distortion. Found that the rear of the shear web was not well clamped like the front, leaving a small bump at the rear of the spar that I will have to sand out of the skin. Not too bad but annoying. Back filled it with splooge. Spent some time fixing the remainder of the attached skin. Filled the dent on the other side, should be ready for block sand tomorrow. The filler is good stuff.
Got the fuse sanded and ready to paint. Can put this away for now.
PP is another story. Looks like the spar is broken on top but not on the bottom. However like the Caracho it is detached from the shear web. This one has less crunch in it and goes back together very cleanly. Any opinions whether I could clamp this together and then run CA down the interior to soak the joint between the spar and shear web? The alternative is to inject epoxy again but there is much less access as the cutout is smaller and it looks like the split runs pretty far toward the center section. Another idea is to CA as far as I can go and feel the heat when it kicks. Beyond that drill micro holes just in front and behind the spar and get more CA in where it did not reach.
The other problem is that unlike the Caracho even with the crunched part of the LE skin cut out the LE's do not line up straight. That means there is twist or distortion somewhere in the wing. The top skin behind the spar is wrinkled so I am thinking of cutting a window right from the start to get access to the bottom skin, which is much less wrinkled. The foam used in the PP is much harder to piece back together than the balsa in the Caracho.
Think I will sleep on this one and take another look after I cut away the crunched spar tomorrow.
Old Sep 03, 2010, 11:34 AM
F3X is offline
F3X
Find More Posts by F3X
F3X
F3X's Avatar
Joined Jun 2001
When you splice the spar do the outside repair as you described and try and taper it 10:1 .10 thick cap so 1.0inch scarf each side of the break.
Also since you have access take out the shear web under the scarf and add uni to the inside spar and then add back a shear web of vert balsa and glass the sides.
F3X is offline Find More Posts by F3X
Old Sep 04, 2010, 12:24 AM
Master of the Wind
Joined Sep 2008
Good idea. Looks like the spars are under control.
The SuperFil is good stuff. One round on the pole dent and I can see this repair will disappear with a little paint. The other side, well we will see how good I am, or how much patience I have. Put balsa tabs on the skin and replaced the triangular patch on top. Then added tabs to the cutout for the new skin. Had a great idea put together from ideas here to curve a piece of balsa with water using an intact section of wing. It came out good but it appears that the skin is not 1/16" balsa. Need to go out tomorrow and pick up some 1/32". It might actually be 1/20 but a little thinner with 3 oz carbon skin and filler should bring it back pretty close to original.
Cut a window behind the spar on the PP. Ground out the buckle on the top spar and now it does not look so bad. Peeled it up and did the syringe trick again to glue back the shear web. That part is really clean. Unfortunately the foam core transmits shock pretty far from the impact point and does not go back like balsa. Getting the skin back where it belongs is going to be a challenge, since some of the spongy part goes all the way to the tip.
Old Sep 05, 2010, 12:26 AM
Master of the Wind
Joined Sep 2008
Got the Caracho buttoned back up. Will need some filling and sanding, and the repair area may be slightly thicker than the rest of the wing, but we will see what we can do. Used the dremel drum and vacuum to feather the skin over all the seams. Laid in 3 oz carbon cloth in front and 2 layers of 1.5 glass behind the spar. Let that cure with release film, foam, and books on top. It followed the contours pretty well. After that the first layer of filler. Tomorow the top.
PP got the spar feathered back the 10:1 plus a little. Went deeper right over the break. Cut 3 different lengths of carbon tow to fill the gap. Wet it out, not dry at all, and let it cure with books on top. Actually looks pretty good. May not even be much over.
Spent the rest of the time picking and glueing skin. The foam is very porous and CA does not kick very fast in it like it does in balsa. Don't quite understand why it bonds skin in seconds and airplane in minutes even if you rub it. I will have to live with wrinkles in the skin. No way I am cutting that all out and replacing it. Probably would not be any better anyway.
Old Sep 05, 2010, 01:57 AM
Kai@UCSB is offline
Find More Posts by Kai@UCSB
Kai@UCSB's Avatar
United States, CA, Fremont
Joined Nov 2003
Looking good my friend. Hope to see this (PP) back to air soon.
-Kai
Kai@UCSB is offline Find More Posts by Kai@UCSB
Wanted Pike Perfect, Caracho center sections G Norsworthy Aircraft - Sailplanes (FS/W) 1 Aug 29, 2010 07:57 PM
Discussion Pike Perfect elevator pushrod repair options dbeach Sailplane Talk 14 Jun 30, 2010 10:35 AM
For Sale for sale: Pike (not so) Perfect, Pike SL, Espada Price Prop baum58 Aircraft - Sailplanes (FS/W) 3 Mar 28, 2010 01:33 PM
Help! Repair the center section of a Pike Perfect JimMacL Thermal 9 Oct 10, 2008 06:26 AM
Discussion Pike Perfect fuselage repair question. SOAR-Steve Sailplane Talk 0 Jul 23, 2008 09:02 AM
