Old Aug 30, 2010, 11:53 AM
flywmoi is offline
Find More Posts by flywmoi
United States, CA, Palm Springs
Joined Aug 2010
Insulfoam from Home Depot in CA???
Has anyone ever used this type of Foam before? I bought a sheet from our local home depot in CA, it is 1/2" thick = 12.7MM I think? Can it be used to make a F-22 Raptor?
Thoughts and Ideas are welcomed please.....
Here is the actual website for the Insulfoam:
http://www.insulfoam.com/
flywmoi is offline Find More Posts by flywmoi
Old Aug 31, 2010, 09:17 AM
djacob7 is offline
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
Really worth looking into. Thanks for the tip.
djacob7 is offline Find More Posts by djacob7
Old Aug 31, 2010, 10:16 AM
OutcastZeroOne is online now
Find More Posts by OutcastZeroOne
"Fly, yes... Land, No"
OutcastZeroOne's Avatar
United States, CA, Santa Cruz
Joined May 2005
Yup, I use that stuff all the time. Its just normal Expanded Polystyrene (EPS) The only thing is that you will need to skin it with something like thin depron or even some of the coating skin materials.
The foam has that plastic coating on it but its realy easy to peel off. A hot wire works best to cut the stuff cleanly.
One more thing you may want to look into is the "Readi-Board" you get from dollar tree. I use that stuff a lot too. Its a foam bard type material but instead of having poster board backings on it, it has kraft paper and can easily be removed with rubbing alchohal. Dont use the elmers stuff or anything with the poster board backing. That stuff is very difficult to remove and the foam itself is too stiff to realy be of any use.
OutcastZeroOne is online now Find More Posts by OutcastZeroOne
Old Aug 31, 2010, 10:40 AM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
I second the redi-board from $Tree
RogueTitan is offline Find More Posts by RogueTitan
Mini-HowTo Sailplane Stand made from a Home Depot Ridgid Flip Top Work Support Miami Mike Sailplane Talk 17 Feb 02, 2012 11:27 AM
Discussion Pink FFF foam from home depot, alternate glue to hot glue? GreenAce92 Foamies (Scratchbuilt) 13 Dec 24, 2009 06:57 PM
Help! insulfoam from home depot ant141110 Foamies (Scratchbuilt) 1 Feb 22, 2009 08:28 PM
Discussion next noob ? - which foam to buy from lowes/home depot pairadocs Foamies (Scratchbuilt) 11 Sep 12, 2007 07:28 AM
