View Poll Results: What Motors do you use?
Axi 9 8.26%
Scorpion 10 9.17%
Pulso 4 3.67%
Emax 14 12.84%
RCTimer 23 21.10%
HXT 7 6.42%
Turnigy 44 40.37%
TowerPro 5 4.59%
KDA 30 27.52%
Multiple Choice Poll. Voters: 109. You may not vote on this poll
Old Aug 29, 2010, 07:38 PM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
Poll
What Motors do you use on your tri/quad/hexa/octal etc? Multiples Allowed :)
as title/poll asks...What Motors do you use on your tri/quad/hexa/octal etc?
tia,
bob
bob4432 is offline Find More Posts by bob4432
Old Aug 29, 2010, 09:38 PM
Fulg is offline
Find More Posts by Fulg
Fulg's Avatar
Montreal, Canada
Joined Sep 2008
I use four Turnigy 2213/22 924Kv motors. Very quiet motors, not much vibrations...
If you decide to get those, make sure to order the accessory pack too. Sometimes there are parts missing (bullet connectors) or badly made (bell prop adapter), and it sucks having to delay a build for such a silly reason.
The shaft is not reversible on that motor unless you can make your own groove for the c-clip. It comes with a 5mm prop adapter that screws onto the bell side for reverse mounting; this is how I use them in my quad.
Fulg is offline Find More Posts by Fulg
Old Aug 29, 2010, 10:48 PM
vinlee is offline
Find More Posts by vinlee
Strictly DIY
1.139749,103.96218
Joined Jul 2010
I use Turnigy 2830-1000.
Do not use these motors, bought four, two are unbalance and vibrate a lot. Magnets inside the bells are misaligned. Also this motor is top mounting only.
Vince
vinlee is offline Find More Posts by vinlee
Old Aug 30, 2010, 01:25 AM
UndCon is online now
Find More Posts by UndCon
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
I use TR 35-30C 1100kv Brushless Outrunner (Eq AXi 2808)
Capable of payload about 1.5Kg with my Tricopter
all 3 motors works very well and all my friends are impressed of how quiet it is.
I even compared it with a GAUI-quad and mine is far better
UndCon is online now Find More Posts by UndCon
Old Aug 30, 2010, 02:59 AM
Tommygunn is online now
Find More Posts by Tommygunn
My name is Tom
Tommygunn's Avatar
Italy, Emilia-Romagna, Misano Adriatico
Joined Aug 2009
I'm currently use KDA 20-22L's (924kv). A good motor for a sporty Quad in combination with APC 10x4.7's.
Mind you, two out of my five motors burnt out for unknown reasons.
Come's with a fantastic accessory kit and my favourite type of prop adaptor.
However, I will be switching to to RC Timer 2836's (750kv) for my heavy-lifter Coax Octocopter.
Tom.
Tommygunn is online now Find More Posts by Tommygunn
Old Aug 30, 2010, 11:05 AM
jonnyc67 is offline
Find More Posts by jonnyc67
jonnyc67's Avatar
I use these motors
http://www.123-rc.com/shop/index.php...3a9eb99f311293
on my KKtricopter with 10x4.7 apc sf cw/ccw props, emax 18a esc. 1kg auw 55cm motor to centre. Off the ground at just over 1/2 throttle. Plenty of punch for fast climb outs & the motors & esc's come down barely warm after a full 2800mah battery on an average flight.
You can ignore the quoted thrust to amps ratio from the seller, it's overstated! These come without mounts or prop adapters. I use collet shaft adapters on mine. They are pretty smooth out of the box, but the shafts are quite delicate & have a tendency to bend on fairly gentle impact I'm going to have a go at mounting the other way up, with motor bell fixed prop adapters to get round the weak shafts...
jonnyc67 is offline Find More Posts by jonnyc67
Old Sep 01, 2010, 06:04 PM
BobRCnut is offline
Find More Posts by BobRCnut
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
Two scratch-built quads: #1 is 14" shaft to shaft and uses Hyperion Z2205-46 motors turning either APC 8 x 3.8 SF props or GWS 8 x 4 3-bladers. #2 is 34" across motor shafts and uses Hyperion ZS2209-30 motors (930Kv) turning (for now) APC 10 x 3.8's. Both are 3S setups.
BobRCnut is offline Find More Posts by BobRCnut
Old Sep 02, 2010, 06:45 AM
QS-27 is offline
Find More Posts by QS-27
QS-27's Avatar
Girona, Spain
Joined Dec 2007
I use on my KK tricopter https://www.unitedhobbies.com/UNITED...idProduct=6549 with ESC https://www.unitedhobbies.com/UNITED...idProduct=6460 and propeller GWS 10x3.8.
In flight doesn't get hot. It is a good engine but shaft is very long and weak, bends easily.
QS-27 is offline Find More Posts by QS-27
Old Sep 03, 2010, 05:14 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
I have succesfully used AXN800, DT750, HXT 24g 1300kv and KDA 20-22l
Stay away from turnigy Aerodrive XP 28-30 750KV, its a crap motor.
Will try the RCtimer 750KV to replace DT750....
Have also used TP bell motors but balancing is poor and there is lots of vibration, but good for a cheap "trasher"
I use Turnigy Plush and Mystery Blue ESCīs
JussiH is offline Find More Posts by JussiH
Old Nov 24, 2010, 09:22 AM
Rei913 is offline
Find More Posts by Rei913
Joined Nov 2009
I use on my mikrokopter this one :
http://www.hobbycity.com/hobbycity/s...idProduct=2112
And prop 10*5 eprop gws.
Rei913 is offline Find More Posts by Rei913
Old Nov 24, 2010, 09:53 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Those RCTimer motors are much better than Hobby King motors. I use to run Turnigy and KDA but now I run all RCTimer. Those BC2836-11 motors blow away all the others. I also rum BC2836-8 on my small airplanes and they all work perfectly and I have not had any bearing problems.
RC Man is offline Find More Posts by RC Man
Poll What Motors do you use on your tri/quad/hexa/octal etc? bob4432 Multirotor Talk 4 Aug 29, 2010 08:10 PM
Question What forms do you use (i.e. invoices etc) Zirt57 Aerial Photography 0 Aug 27, 2010 02:16 PM
Poll what prop do you use on the micro site? bolibruch1 Scratchbuilt Indoor and Micro Models 0 Aug 09, 2010 12:50 PM
Discussion What software do you use to edit your videos? TheNiceGuy FPV Talk 19 Aug 04, 2010 08:34 PM
Question Tri/hexa-copter or Quad/Octa-copter and Spartan AP2000i or Helicommand Arthur P. VTOLs 2 May 20, 2007 04:02 PM
