Old Aug 29, 2010, 04:34 PM
xraydoc is offline
Find More Posts by xraydoc
xraydoc's Avatar
Little Rock, AR
Joined Apr 2009
Question
Reduced brightness when running led through brushed esc - why?
I have about 5 strips of hobbyking led lights on my plane.
When I connect directly to the battery they draw 2.2A and are really bright
I am trying to use a brushed esc as a regulator so I can reduce the brightness when I am in close hovering but want full brightness when it's far away.
I got an old gws 8a brushed esc and got it hooked up.
I tied it to the gear channel on my Spektrum 6200 receiver then assigned that to the 3 way aux2 switch on my JR x-9303.
Everything works as planned - I have off, medium, and high brightness but the full on setting is reduced quite a bit drawing only 1.3A vs 2.2 when the leds are connected directly to the battery.
I can use the sub-trim and travel adjust on the radio to change the amp draw and thus the brightness but can't ever get it to go full on.
This may be inherent in using a brushed esc as it is sending pulses rather than a continious stream of electricity to the led's but wanted to see if anyone else had this problem and if there is a work around.
If you are not having this problem what kind of esc are you using?
Thanks in advance.
xraydoc is offline Find More Posts by xraydoc
Old Aug 30, 2010, 03:01 AM
rkopka is offline
Find More Posts by rkopka
Electric only
rkopka's Avatar
Graz - Austria
Joined Nov 2002
It must use pulses, otherwise the ESC would get much too hot.
But you seem to have no full throttle form your switch, as the ESC would go to a continuous on at full throttle. Try to hook up a servo to the switch (or better a tester which will tell you the ms) so you can see if it really goes to max. Maybe you need to learn the ESC to the switch.
RK
rkopka is offline Find More Posts by rkopka
Old Aug 30, 2010, 04:27 AM
Bilbobaker is offline
Find More Posts by Bilbobaker
Bilbobaker's Avatar
United States, UT, Salina
Joined Apr 2003
They are resistered for twelve volts input.
an dimming them is quite easy with a brushed esc.
I pull a lot less amps with five strips than you do.
I recall in my tests only pulling 1.2 amps with five strips on a three cell lipo.
Bilbobaker is offline Find More Posts by Bilbobaker
Old Aug 30, 2010, 04:29 AM
Bilbobaker's Avatar
Joined Apr 2003
I also am using a gws brushed control with the red wire connected, when I disconnect it they no longer work.
Discussion Using a brushed esc as a dimmer for led xraydoc Night Flying 6 Feb 17, 2011 04:40 PM
Sold !!!REDUCED!!! Brushless motors, CC TB ESC, IPS Stuff Three-Wire Aircraft - Electric - Power Systems (FS/W) 14 Dec 23, 2010 05:00 PM
Discussion LED brightness vs. viewing angle dswitkin Night Flying 4 Jun 08, 2008 07:32 PM
Help! Why is my motor so hot when running without load, and other questions ? HAL1 Power Systems 13 Jun 26, 2006 07:16 AM
This is what happens when you run too many amps through your ESC... thomer Power Systems 23 Aug 26, 2003 09:51 AM
