Old Aug 28, 2010, 10:20 PM
xraydoc is offline
Find More Posts by xraydoc
xraydoc's Avatar
Little Rock, AR
Joined Apr 2009
Using a brushed esc as a dimmer for led
I am trying to figure how to hook up a brushed esc to control the brightness of the HK led strips.
I am currently using the on\off switch from HK but wanted to be able to dim them when I come in for a little hovering otherwise I get blinded
Wanted to see if those that have successfully done this could give a quick explanation how to wire it and if I need to do anything to the connection to the receiver so that the receiver does not get feedback from both the brushed and brushless esc.
any tips\tricks appreciated - I'm kind of a novice at the electrical stuff and didn't want to fry anything
xraydoc is offline Find More Posts by xraydoc
Old Aug 29, 2010, 12:35 AM
Bilbobaker is offline
Find More Posts by Bilbobaker
Bilbobaker's Avatar
United States, UT, Salina
Joined Apr 2003
You may find some information here.
It's really pretty easy to do.
http://www.rcgroups.com/forums/showthread.php?t=1253472
Bilbobaker is offline Find More Posts by Bilbobaker
Old Aug 29, 2010, 07:23 AM
xraydoc is offline
xraydoc's Avatar
Little Rock, AR
Joined Apr 2009
thanks
from what I have read so far seems I need to cut the + lead from the receiver to the brushed speed control and set the lvc on the brushed speed control as low as I can.
I had planned to put it on a 3 way switch on my JR X-9303 and have low\med\high brightness
Anything else I need to be thinking about?
Old Aug 29, 2010, 09:38 PM
xraydoc is offline
xraydoc's Avatar
Little Rock, AR
Joined Apr 2009
came across this which had LOTS of good information
http://www.hoverandsmile.com/nightflying
Old Sep 03, 2010, 08:02 AM
erkrystof is offline
Find More Posts by erkrystof
Joined Apr 2009
Thanks for the plug
Hope you got your ESC issue figured out, did you go with a higher rated ESC? The simple one I used gave me the 12 volts, but I also was only using 400 milliamps or so total power.
Cutting down by half is surprising though. Did you test the ESC output with nothing but a voltmeter?
erkrystof is offline Find More Posts by erkrystof
Old Sep 03, 2010, 08:09 AM
xraydoc is offline
xraydoc's Avatar
Little Rock, AR
Joined Apr 2009
Originally Posted by erkrystof View Post
Thanks for the plug
I was measuring the draw with a wattmeter so don't know how accurate it is as that low of a current. Got it working though.
Old Feb 17, 2011, 04:40 PM
futura65 is offline
Find More Posts by futura65
Joined Feb 2011
Hi there...so i really wanted to try out controlling the dimming of lights with the RC controller. Found this thread and it's been very helpful....so I went to the web site listed and saw what they were doing with the ESC. I wanted to just make an LED go from 0 to full brightness so plugged it into channel 1....and wired the LED to the motor side. When I hit the throttle the LED would go to full brightness for a moment then off even though I continued to squeeze the trigger. So I hooked up a volt meter. As I squeezed the trigger almost the moment I start the meter runs up to 100% but then just starts to drop back off even though I continue to squeeze the throttle up more. Then when I release the trigger, as it returns to center, it crosses that same point where it seems to run the voltage back up to 100% and then back down....just enough to make a blink. Not sure what's going on.....if anyone has any thoughts please let me know
thanks in advance.
futura65 is offline Find More Posts by futura65
Question Using a brushed esc for dimming control over leds. Bilbobaker Night Flying 30 Feb 17, 2011 04:34 PM
Discussion Using ESC's BEC as well as Dedicated UBEC I_Con Power Systems 1 Apr 03, 2010 02:31 AM
Discussion Using Vtail mixer and 2 ESC's, brushed Butch777 Coaxial Helicopters 4 Nov 27, 2009 05:29 PM
Discussion Simple single LED beacon and micro dimmer knob. bamm DIY Electronics 49 Oct 27, 2009 03:43 PM
Question With generic ESC BEC's, is using too few servos as bad as too many? Accu157 Power Systems 4 Mar 25, 2007 10:22 PM
