Old Aug 27, 2010, 10:53 PM
6literZ is offline
Find More Posts by 6literZ
USA, WI, Oshkosh
Joined Aug 2010
Light weight lipo battery choices.
I've been looking for a very light battery for the mini dlg.
I have a microstamp 4l, and will be running two micro servos.
The 4l says up to 8v. Can I run a 2s lipo without needing a regulator?
I see people use cr123 batteries and stuff, but I'd like something more plug and play noob friendly.
Are there any setups around 10g?
6literZ is offline Find More Posts by 6literZ
Old Aug 27, 2010, 11:41 PM
PLD is offline
PLD
Find More Posts by PLD
PLD
Magicsmoke maker
PLD's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
It really comes down to the servos in the end - as receivers all have their own built-in regulators which should cope with 8.4V no problems.
If you use 6V rated servos on 2S you'll likely burn them out fairly quickly.
( A miniature regulator with alarm (LEDs) is 2.9g, less if you remove the heatshrink and shorten the wires http://nqrc.com/?vp=PLD-BAC-MINI )
What size servos were you planning on using? 3g ~4g ?
PLD is offline Find More Posts by PLD
Old Aug 28, 2010, 03:14 AM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Well CR2s are way heavier than 10g, a two pack for around 6V is 24g.
The microstamp will work down to 3V I believe, so why not use servos that will work on a single Lipo, no need for a regulator then.
I have used the 3.3V version of the 2.5G Blue arrow servos in a small 2-3oz glider, and they worked well enough. Even the 5V version of the 2.5g servo worked, all from a single Lipo.
Plenty of small single cell Lipos available very cheap in eBay, they are popular for small helicopters I believe.
srnet is offline Find More Posts by srnet
Old Aug 28, 2010, 04:32 AM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Joined Apr 2010
these are single cell at 5 volts with chger http://www.hyperflight.co.uk/product...s+%26+Switches
http://www.xe.com/ucc/
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Aug 28, 2010, 04:45 PM
MarksRC is offline
Find More Posts by MarksRC
MarksRC's Avatar
Wellington, Florida
Joined Jun 2004
Dymond D47 servos have an operating range of 4.8 to 9.6 volts and I run two of them with a 300mah 2S 7.4v lipo pack. Pack weight is 19.7 grams. Electrifly P/N GPMP0700.
MarksRC is offline Find More Posts by MarksRC
Old Aug 28, 2010, 05:28 PM
RCPC is offline
Find More Posts by RCPC
Throw it like you hate it
RCPC's Avatar
United States, CA, Castro Valley
Joined Apr 2007
there are packs out there that are about 10gr but you will likely need to make them yourself. Its not hard, but you need to know how to solder and how Lipo handling procedures (i.e. just respect them and they will not blow up.)
I made a 2s pack for a mini DLG from the 300mAh cells and it worked great!
http://www.all-battery.com/li-polyersinglecells.aspx
Paul
RCPC is offline Find More Posts by RCPC
Old Aug 28, 2010, 10:17 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
It's a good thing that more and more servo makers are giving us units that can cope with 2S lipos directly. Soon we can do away with regulators and only need electronic switchjacks and low-voltage alarms.
Old Aug 30, 2010, 01:43 PM
David Forbes is online now
Find More Posts by David Forbes
David Forbes's Avatar
United States, FL, Gainesville
Joined Dec 2005
I've used various of these http://www.all-battery.com/polymerli...h461540-1.aspx just pick one with the right form factor, right now I'm using this one http://www.all-battery.com/polymerli...mah602025.aspx just be sure to not get the protection board, better to toast a $5 battery than your plane.
You don't need 2s for D-47 and a Berg 4L. I can fly for an hour with a 4L and 4 D-47s and put about 60mA back in the pack in my full house 40" DLG. Keep track of flight time on your transmitter.
Dave
David Forbes is online now Find More Posts by David Forbes
Old Aug 31, 2010, 07:17 AM
buildscapeinc is offline
Find More Posts by buildscapeinc
buildscapeinc's Avatar
Greenville, SC
Joined Nov 2004
I will second that, just fly a single cell lipo. With a Berg and 2 D47s you will have no problem doing so. I have had 3 dlgs now with this setup and it works great. Plenty of flying time and the set up could not be more simple.....no voltage or regulators to worry about and ridiculously light.
Good luck,
Brian
buildscapeinc is offline Find More Posts by buildscapeinc
Old Sep 04, 2010, 03:22 AM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Originally Posted by registerwing View Post
Well unless they do a version that allows you to use your own battery, those are not as useful as they seem.
If you always have a spare plane to hand, one flying and one charging then fine. But what do the majority of us do when do when the inevitable happens and you turn up at the field with your one plane and find your battery is flat ?
I do use one of the PLDs to charge my lipo (2S 350mahr) whilst its in the plane, but I also carry some spare and charged Lipos. These spares cost around 6, but a spare SmartLipo is around 5 times that sum.
Now if you could buy one SmartLipo device and plug your own batteries into it, that would be really really useful, especially as all you need to charge would be a 5-15v DC source. Such a device would be a real winner.
Old Sep 04, 2010, 03:29 AM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
On the subject of RXs that will work at voltages other than the standard 4 cell NiCd\NiMh pack or 5v from an ESC.
Does anyone know of full range receivers for 35Mhz that will work from either a single 1S Lipo or a 2S lipo pack ?
The Berg 4L appears to only available for 72Mhz.
Old Sep 04, 2010, 03:30 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
srnet,
Are you spying on my developments?
I've got onboard a 1S lipo boost regulator + integrated charge controller (though to be honest it's really more for a 5V input, not 5~15V, it's designed around being charged with a USB connection). What I've not finished deciding on yet is if I should enlarge it more and add a voltage-readout / audio-alarm to it... the trouble is as mentioned, is that the size increases along with weight and of course, the one thing we all hate, COST :\
Paul.
Old Sep 04, 2010, 05:32 AM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Well you could design the PCB as longish and thin, with the piezo, and possibly the resistors and parts associated with a Vref at one end, so that part of the PCB could be snapped off for those that want a smaller\cheaper\lighter unit.
But a LED in any case, SMT ones dont add much space and add to the feel good factor when they flash reassuringly at power up.
And of course keep it as light as possible, so the range of applications would depend mainly on the particular choice (and weight) of Lipo.
5v charging is OK, but 12v is better since most of us will have 12V handy in the form of the battery in the vehicle. Although I can see the attraction of 5V, less power dissipation to contend with, but on the other hand 5V USB power adapters to plug into a vehicles cigarette lighter socket are only 2 or so.
Good luck
Old Sep 10, 2010, 12:37 PM
captsteve is offline
Find More Posts by captsteve
captsteve's Avatar
Beaufort,SC
Joined Dec 2002
Do any of you guys have any experience or thoughts on these servos?
I want to make a gladiator as light weight as I can.
http://www.hobbypartz.com/exi-servo-s0820.html
Steve
captsteve is offline Find More Posts by captsteve
Old Sep 10, 2010, 01:05 PM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
I have tried quite a few of those generic type servos, they look similar to the so called 3.7g ones you see on ebay. All of them have been a gram or two heavier that the claimed weight. Not very smooth and they chatter to much for my liking.
I have fitted diamond D47s in both my Gamblers, they are 4.86g.
I use them in a pull string control and they are far better than the heavier HS45HBs they replace.
Discussion Saving weight - making custom battery, will this work? aaron_gx FPV Talk 13 Aug 17, 2010 11:14 AM
Discussion Light weight Lipo Uttam1 Batteries and Chargers 3 Feb 01, 2009 09:07 PM
Light Weight Tx Battery Pack John Gallagher Hand Launch 4 Sep 04, 2005 02:12 AM
Axi 2808/20 lipo battery choices Mac8 Power Systems 0 May 26, 2004 11:35 AM
Light weight battery for Speed 400 (Wingo/Soarstar) joemi Foamies (Kits) 3 Nov 03, 2001 07:24 PM
