Old Feb 04, 2013, 11:20 AM
mike early is offline
Find More Posts by mike early
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
I think downthrust is more important that right-thrust. Does it climb with increased throttle? Does everyone dial in throttle-elevator mix in an attempt to rectify the issue? How much downthrust can I add and still get an acceptable cowl-to-spinner interface?
Dang.
Alas.
mike early is offline Find More Posts by mike early
Old Feb 04, 2013, 11:32 AM
danpos is online now
Find More Posts by danpos
danpos's Avatar
Canada, NB, Fredericton
Joined Dec 2011
Dang.
Alas.
I left mine as is without any throttle-elevator mixes.
As long as it's balanced right it doesn't climb bad at all.
There is a very slight climb at full throttle, but no more climb than any of my other planes.
It's really a non issue.
The cowl and spinner align good as is too.
danpos is online now Find More Posts by danpos
Old Feb 04, 2013, 11:40 AM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
Ok. Thanks. I will see how it goes.
Old Feb 04, 2013, 11:50 AM
Pjuran is offline
Find More Posts by Pjuran
United States, NJ
Joined Oct 2011
Hobby King Oleos
Anyone use these with the Eflite 85 degree retracts?
http://www.hobbyking.com/hobbyking/s...dProduct=23883
Pjuran is offline Find More Posts by Pjuran
Old Feb 04, 2013, 02:59 PM
capteasy is offline
Find More Posts by capteasy
capteasy's Avatar
USA, Texas Hill Country
Joined May 2008
Pitch + Power
I'd like to add a word on some of the pitch and power concerns here. Assuming all balance issues are within specs, if an aircraft is trimmed for desired pitch performance, then any change in power will result in a change of pitch attitude or performance. Straight and level cruise would ideally require neutral trim @ that desired desired attitude. Any addition or reduction in power during that pitch attitude will change the performance requiring trim adjustment. To maintain a desired pitch attitude in trim, whether level, climbing or gliding the power needs to maintain a constant setting otherwise additional elevator change or trim is required.
I hope I didn't overstate the issue.... Pitch +/- Power = Performance
ce
capteasy is offline Find More Posts by capteasy
Old Feb 04, 2013, 03:52 PM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
ce
It cannot be overstated as far as I am concerned. It's my pet peeve. I buy Ernst thrust plates and adjust the thrust line till I get it perfect. I like WOT low LOW passes and I also like very slow low passes. Constant accurate trim is important to me. Why the hell does anyone put UPthrust in a plane?
Old Feb 04, 2013, 03:58 PM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
Maybe I can work the cowl so it angles down a bit...
Old Feb 04, 2013, 04:48 PM
Tom Hunt is offline
Find More Posts by Tom Hunt
got any foam to bash?
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
Full scale BF-109E was the only warbird I know that had up-thrust. many had none... few had down. but NONE, NOT ONE had right thrust!
Tom Hunt is offline Find More Posts by Tom Hunt
Old Feb 04, 2013, 05:37 PM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
I am only familiar with toy planes, and the apparent universal importance of down thrust...
Old Feb 04, 2013, 07:57 PM
payne9999 is offline
Find More Posts by payne9999
Balsa&Tissue
payne9999's Avatar
United States, OR, Beaverton
Joined Jan 2011
I have some factory drawings that show down thrust on the full scale P51.
full scale planes are supposed to climb at full throttle and we would trim slightly at cruise and expect the plane to descend when throttle was reduced below cruise. The only way to get level flight at multiple throttle settings would be to program the elevator to track with throttle or manually trim every time you change throttle settings.
To make a full speed low pass you either need to manually trim or feed some down into the elevator as you go.
Dave
payne9999 is offline Find More Posts by payne9999
Old Feb 04, 2013, 08:15 PM
capteasy is offline
capteasy's Avatar
Joined May 2008
I'm not sure about all full scale US single engine warbirds but most were probably built with vert stabs slightly offset left to help compensate for the left turning forces. Some models may use the same feature as well.
Old Feb 04, 2013, 08:47 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
I believe the P51 manual specifies right rudder trim for the takeoff roll which is very similar to the model which requires quite a bit of rudder correction on takeoff roll.
Old Feb 04, 2013, 08:50 PM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
Vertical stabilizers are usually off-set a bit on full scale, to my understanding.
The cowl on this particular toy plane make it too difficult to pursue any downthrust. So, I'll dial in some throttle-elevator mix and hope for the best. Biggest drawback on that is when I hammer the throttle during a low speed pass, it noses down when I am already as low as I can fly. So...I will try to remember to avoid that on this plane...
Old Feb 04, 2013, 09:28 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
This is an interesting subject but the E-Flite designer said that the thrust line is supposed to be zero degrees with a couple degrees of right thrust.
The full scale P-51 manual does specify 5 degrees of right trim on the rudder for takeoff roll and that sounds right. 5 degrees is actually a lot but this is to help the pilot hold a straighter line without getting into a big ground loop situation while applying all that power.
Section VII -- Operating Instructions for the P-51
PRELIMINARY CHECK
Obtain flight clearance.
Check outside of airplane carefully. Remove pitot cover.
Check service of ship and status of it on Form 1A carefully.
Make sure chocks are in place.
ENTER COCKPIT
Adjust seat and rudders for height and length.
Check ignition switch OFF.
Set parking brake.
Check bomb and gun safety switches are OFF.
See that landing gear control handle is in the DOWN position. On the P-51D, there is NO ARENS control to prevent accidental raising of gear on the ground.
Unlock controls and check for freedom of movement. Control lock is located at the base and just forward of the stick. Pull the plunger on the left side of the lock to unlock controls.
Fasten safety belt and shoulder straps.
Set altimeter to correct barometric pressure.
Oil and coolant shutters to full OPEN position as soon as batter cart is plugged in.
Set trim tabs. Rudder 5° Right, Elevator 2° to 3° Nose UP (with 25 gallons or less in fuselage tank). Elevator 1° to 3° Nose DOWN (fuselage tank full). Aileron 0° for Take-Off.
Release hydraulic pressure with wing flaps and flap handle to UP position.
Close canopy
The fact that some of these planes have what appears to be a degree or so of upthrust is likely a result of tolerances. After all this is a hand built wood assembly and even with laser cutting one could not assume that the thrust line would be perfect on every plane. My estimate would be that holding a plus/minus 1 degree tolerance would be difficult. Shimming in 1 degree or so of down should not screw up the cowl fit much. I have two of these planes and I did adjust the thrust line slightly on one. Mine has some right thrust built in from the factory and it looks like the front face of the cowl is slightly canted to the right.
I wouldn't call this plane a toy though. I find mine to be quite intimidating at full throttle and commands a lot of respect. Overall it is a great airplane at a great price. However, I have always believed it should be flown with 2-3 degrees of aileron reflex. That is just my personal opinion though.
Old Feb 04, 2013, 09:41 PM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
2-3 degrees of aileron reflex?
Spoilerons, so to speak? Have the ailerons up a couple of degrees on both sides at neutral?
Are most people living with the color mis-match between the hatch, flarings, and the fuesleage?
Discussion E-Flight Platinum series P-51b nitro_star Scale Kit/Scratch Built 2 Aug 27, 2010 04:09 PM
Question E-flite p-51b RCDestroyer Electric Plane Talk 4 Aug 26, 2010 12:10 PM
Sold ESM P-51B Mustang - "Frank Tiano Series" mustang1971 Aircraft - Fuel - Airplanes (FS/W) 8 Jun 06, 2010 02:32 PM
For Sale Nib E-flite platinum series AT-6 Texan w/ optional accsry's lavochkin Aircraft - Electric - Airplanes (FS/W) 8 Mar 31, 2009 06:51 PM
For Sale NEW - Top Flite P-51B Mustang #RARE# JimJams Aircraft - Fuel - Airplanes (FS/W) 5 Apr 13, 2006 05:17 AM
