Old Nov 17, 2012, 06:15 PM
ManTownMedia is offline
Find More Posts by ManTownMedia
Quad Squad
ManTownMedia's Avatar
United States, TX, Spring
Joined Apr 2011
Thanks guys. Nobody else was there - just me. So, I propped up my iPad to take the video - right on the ground. Most of the footage was not usable - I was flying 3 mistakes high so you are just seeing my takeoff (not that scale and right into the wind) and then the taxi back to the station. If I fly tomorrow, maybe I can get someone to video it.
This is a the Tricounty Barnstormers field near New Waverly, TX and the club put this black material that looks like a heavyweight version of the landscaping covering to block weeds. Before it was quite loose but I think they stretched it fairly well so it is smooth and painted with stripes like a real airfield.
Post flight, I noticed that I had to adjust the all metal E-Flite retracts and spent more time hardening the plywood and holes where the retracts are screwed in...Next mod is to use my shock absorbing struts that I bought for this bird - but it will will require more dremeling of the 5 mm struts to make it fit better than the stock coil type struts.
ManTownMedia is offline Find More Posts by ManTownMedia
Old Nov 18, 2012, 07:46 AM
britcardoc is offline
Find More Posts by britcardoc
Joined Jan 2007
Retract " SPECIAL" Y connector?
Just read in the instructions that a special y connector comes with the eflite retracts. ????
I bought a set off ebay used....what is special about the Y connector? Do I use one I have or will I need eflites? Is it a reverser in one leg? I have one of those.
Congrats on the first flight.
Introduction: BritCarDoc is a lifelong modeler, have the first freeflight trophy and original AMA number still from 1955. I've flown a little of everything. Kavan Jet Ranger when they were first out in the 70's, Quarter Midgets, Pattern, 1/2 A, fly SPA old timer pattern now but fly lots of eflite too. Ran a hobby shop for a while too.
Have always loved the B model Mustang and am really excited to be building this one.
So what is the deal with the special y harness?
britcardoc is offline Find More Posts by britcardoc
Old Nov 18, 2012, 07:48 AM
Tom Hunt is offline
Find More Posts by Tom Hunt
got any foam to bash?
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
Originally Posted by britcardoc View Post
Introduction: BritCarDoc is a lifelong modeler, have the first freeflight trophy So what is the deal with the special y harness?
I have not pulled one appart yet, but I suspect it is just a "choke" to prevent noise from the retract motors getting back to the Rx.
Tom Hunt is offline Find More Posts by Tom Hunt
Old Nov 18, 2012, 07:49 AM
pmmartin is offline
Find More Posts by pmmartin
Fly Every Day
pmmartin's Avatar
United States, FL, Sebastian
Joined Apr 2001
It is only special for tricycle landing gear setup. It is a three way "Y". For two wheels it is a normal "Y".
pmmartin is offline Find More Posts by pmmartin
Old Nov 18, 2012, 09:34 AM
skydve76 is offline
Find More Posts by skydve76
More jets than a carburetor
skydve76's Avatar
United States, NE, Omaha
Joined Sep 2008
Its a servo amplifier and I have had issues with several if those.
skydve76 is offline Find More Posts by skydve76
Old Nov 18, 2012, 09:44 AM
V2rider is offline
Find More Posts by V2rider
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
No idea what is special about the E-Flite y harness, but I know the retracts work fine with a regular y harness. I couldn't find the y for the retracts when I put my H9 Mustang together so I just used a regular 6" y harness. I have about 50 flights on it with no problems at all. I do run a seperate rx pack on that plane so there is always plenty of power for the servos and retracts.
V2rider is offline Find More Posts by V2rider
Old Nov 18, 2012, 04:33 PM
JLogan is offline
Find More Posts by JLogan
AMA#313760
JLogan's Avatar
United States, MI, Taylor
Joined May 2009
My guess as well
John
JLogan is offline Find More Posts by JLogan
Old Nov 18, 2012, 05:06 PM
danpos is offline
Find More Posts by danpos
danpos's Avatar
Canada, NB, Fredericton
Joined Dec 2011
Double post...sorry
danpos is offline Find More Posts by danpos
Old Nov 18, 2012, 05:22 PM
danpos is offline
danpos's Avatar
Joined Dec 2011
I have a spare Tacon 25 870kv motor and I'm thinking about putting it in my other Mustang.
According to ecalc it should work well on a 11x7x2 or an 11x8x2.
Has anyone done a direct comparison between a power 25 and a power 32 with this plane yet?
I spent four hours flying my P-51B on a G32 770kv with a 13x6.5x2 propeller today.
Most of my flying time was at 3/4 to full throttle.
I kept easing it back of full when I noticed I was there.
So I put the 13x8x2 TGS sport prop. back on.
It's there to stay this time.
Old Nov 18, 2012, 06:35 PM
LICobra is offline
Find More Posts by LICobra
Warbird Enthusiast
LICobra's Avatar
Long Island, NY
When I first flew the "B" with the stock recommended setup, I didn't like the performance of the 13X6.5. The 13X8 gave the speed I expected.
A 25 sized motor might fly get the "B" in the air, but I can't see it flying this 6lb airplane with any authority
LICobra is offline Find More Posts by LICobra
Old Nov 18, 2012, 08:55 PM
Quad Squad
Joined Apr 2011
Mine has the G32 from HobbyKing with a 4s and a 5s battery. My prop is a 13x8 and it worked fine. I have not used any special Y connectors - just the std ones that I already had from other planes for the retracts.
Old Nov 18, 2012, 09:14 PM
danpos is offline
danpos's Avatar
Joined Dec 2011
Yes I imagined flying this plane on a power 25 would be very underpowered.
I'm just exploring options where I have a second one ready to be completed.
Longer flight times is why I was curious about a power 25.
Has anyone tried a Eflite BL32 size 1010kv brushless out runner motor on this plane?
The other option is a Power46?
If I'm going to build another one I want it to be different power wise.
Old Nov 19, 2012, 09:50 AM
sbakr23 is offline
Find More Posts by sbakr23
sbakr23's Avatar
United States, MN, Maple Plain
Joined Jun 2012
I've been flying mine with the eflite power46 on 5 cells 4000mAh 40c with a 13x8 2 blade, and the performance is great. Am getting 52.6 amps on a fresh batt. but I dont fly this one wot much, I did limit the throttle to 85% to keep the amps from going over 45 I didnt want to stress the motor since there isnt any need for the extra power with this plane.
sbakr23 is offline Find More Posts by sbakr23
Old Nov 19, 2012, 12:20 PM
danpos is offline
danpos's Avatar
Joined Dec 2011
Did you try the Power46 on a 4 cell?
I didn't want to run this on a 5 cell, I have plenty of 4 S but only one 5S.
I finally applied the dull coat to my P51-B. Looks better even after the first coat.
Old Nov 20, 2012, 03:06 AM
SmokeDogg is offline
Find More Posts by SmokeDogg
"Fly Low, Fly Fast, Turn Left"
SmokeDogg's Avatar
United States, CA, Red Bluff
Joined Jul 2009
The power 46 has a sweet spot for 5s and a 13x8. Got a few planes with that setup and love it!
If you were to try 4s just run the p32 with a 13x8! Flys great with that setup. 5s on a p32 with a 12x8 picks up some speed...
SmokeDogg is offline Find More Posts by SmokeDogg
Latest blog entry: Miss Foxy Lady eBuild
Discussion E-Flight Platinum series P-51b nitro_star Scale Kit/Scratch Built 2 Aug 27, 2010 04:09 PM
Question E-flite p-51b RCDestroyer Electric Plane Talk 4 Aug 26, 2010 12:10 PM
Sold ESM P-51B Mustang - "Frank Tiano Series" mustang1971 Aircraft - Fuel - Airplanes (FS/W) 8 Jun 06, 2010 02:32 PM
For Sale Nib E-flite platinum series AT-6 Texan w/ optional accsry's lavochkin Aircraft - Electric - Airplanes (FS/W) 8 Mar 31, 2009 06:51 PM
For Sale NEW - Top Flite P-51B Mustang #RARE# JimJams Aircraft - Fuel - Airplanes (FS/W) 5 Apr 13, 2006 05:17 AM
