Old Oct 16, 2012, 09:22 AM
Manu Simon is offline
Find More Posts by Manu Simon
Manu Simon's Avatar
Belgium
Joined Aug 2008
So I put the meter on the "B" and got the following (G32 770 kV Trust 70A ESC 13x8 TGS) :
4S 3000 mah Flightmax 40C: 52,7A -14,8V - 787,3 Watt
5S 2650 mah Flightmax 45C: 69,05 A - 17,34V - 1217,3 Watt
Those are max values recorded static at the very beginning of the discharge.
Both packs were fully charged but a bit on the cold side (16°C).
Trust ESC is up to the task IMO. The G32 is rated 55A max for 15sec... so I would not recommend running this setup WOT for more than a few seconds, but cruising along at 2/3 thottle should be fine with a few burst at WOT for giant loops or high speed passes.
Manu Simon is offline Find More Posts by Manu Simon
Old Oct 17, 2012, 08:23 AM
srt8madness is offline
Find More Posts by srt8madness
whiirrrrrr
srt8madness's Avatar
United States, TX, Houston
Joined Nov 2011
Ugh, I hated my trust 55a esc, couln't program it for crap, the brake was always on, even though in the program it was "off"
srt8madness is offline Find More Posts by srt8madness
Old Oct 25, 2012, 12:15 PM
danpos is offline
Find More Posts by danpos
danpos's Avatar
Canada, NB, Fredericton
Joined Dec 2011
I finally had a chance to fly my newly repaired P-51B after the ridiculous series of careless errors I made causing my P-51B to hit a pc of rebar and smash the wing into small pcs of balsa.
When it was over it looked like a bear bit a huge chunk of balsa out of the wing, chewed it and spit it out. Even the cowling was ripped clean off.
It took many hours to rebuild all the little panels and framing I built, then recover with ultracoat.
After all that I was amazed that it didn't need any trimming other than one click of left rudder.
Even though I took carfeful measuremants rebuilding it I expected it to be a disaster.
It flew great!
Also today was the first time I used full flaps to land.
After reading about all of the trouble there has been with stalling I have been landing without flaps most of the time. I have had some very high speed landings.
I did my final turn quite high and going fast (5/8 throttle). Slowed down gradually (1/2 throttle) and went full flaps.
It didn't balloon at all. I reduced the throttle down to about 1/3 now.
Still getting lower and slower. It does look very cool coming in with full flaps
It was about 2' off the runway. I kept waiting for it to drop on it's own, but it floated right on by me going very slow?
I have to say if that was over 20mph I'm a very bad judge of speed.
Since the airfield was frozen and I had to avoid patches of ice I'm going to start the second Mustang P-51B. Or I should say RAF Mustang MKIII.
Instead of painting the P-51 I might use ultracoat instead. I don't mind the occasional ironing.
Has anyone tried applying ultracoat over the canopies that Park Flyer Plastics sell?
I expect to use a low heat setting and keep the iron moving so I don't melt the canopy.
Any thoughts on this?
danpos is offline Find More Posts by danpos
Old Oct 25, 2012, 05:35 PM
LICobra is offline
Find More Posts by LICobra
Warbird Enthusiast
LICobra's Avatar
Long Island, NY
As I do have the Park Flyer Plastics canopy, I never thought of that.......although since im not that good at applying ultra coat...... I will probably paint the canopy and the rest of the top side of the P-51 all the same color.
LICobra is offline Find More Posts by LICobra
Old Oct 29, 2012, 06:22 PM
nioa is offline
Find More Posts by nioa
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
If you're going to re-cover, why not consider a flat covering like MonoKote Flat Olive Drab?
nioa is offline Find More Posts by nioa
Old Oct 29, 2012, 09:03 PM
danpos is offline
danpos's Avatar
Joined Dec 2011
The Monokote feels thin in comparison to me.
But I do like the look of the Monokote on my Hyperion L-4.
Funny, my wife likes the P-51B shiny and thinks I'll ruin the look of it if I dullcoat it.
Old Oct 29, 2012, 09:13 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Ultracote is better quality stuff. It has better shrinkage qualities.
TripleW is offline Find More Posts by TripleW
Old Oct 30, 2012, 12:29 AM
JudahBenHur is offline
Find More Posts by JudahBenHur
JudahBenHur's Avatar
Joined Sep 2012
Originally Posted by capteasy View Post
I hope you'll post some photos of it as it progresses...sounds interesting.
ce
Here are a few crappy phone pictures. My digital camera is still in hiding.
I'm not sure which "Red Tail" plane this will turn out to be. Something along the lines of the last one pictured but without the red and yellow on the nose. Still waiting on main retracts and a pilot. The fuselage is painted silver now but the phone's email is afraid of the hurricane for the time being.
JudahBenHur is offline Find More Posts by JudahBenHur
Old Oct 30, 2012, 09:22 AM
whiirrrrrr
Joined Nov 2011
I crashed
I took off, and got halfway through a circle and my TX started beeing due to low batts(I didn't remember them being low last time I glanced at it). I immediatly went around to approach and land. I lined up, hit the flaps, and that was it. NO signal. She went in from 70-80'(approx). Destroyed the former where the wing mounts, ripped the wings out, stripped 3 servos. A few other wood parts cracked. Went down in a soft mud area, so there was solid mud 2"+ in the cowl, and everywhere else.
Thankfully I have another wing set. I'll have to work on fixing a warped flap, but it's doable. The worst part is all the weathering and detail that I'll have to redo to match the fuse.
I've had pretty bad luck flying lately. I wanted to keep this plane nice and pristine, and for the most part I had. The worst is that something as stupid and tx batts caused it. You would think the dx6i would start beeping more than 5 seconds before it stops signal(literally 5 seconds).
Old Nov 01, 2012, 05:08 PM
Joined Sep 2012
Here are a couple more of the E-Flite P51B Mustang currently being built. The little pilot still needs replacing.
Never mind all the junk in the background.
Old Nov 03, 2012, 10:17 PM
britcardoc is offline
Find More Posts by britcardoc
Joined Jan 2007
Just got my first Eflite P51B..... sticker shock on the retracts. Almost as much as the airframe.
Is there a good alternative to the Eflite $130 set?
Or...does someone have a used set?
And what does the "18g" mean on the American tail wheel post?
britcardoc is offline Find More Posts by britcardoc
Old Nov 04, 2012, 02:51 AM
Manu Simon's Avatar
Belgium
Joined Aug 2008
See my post above...
Turnigy G32 and Turnigy Trust 70A ESC make a good & cheap power plant.
I used HXT900 on flaps and ailerons (also I would now recommend to use metal gear 9 gr for the flaps) and HXT D MG16 for rudder and elevator.
I use mine as a belly lander so no retracts at all
Have a look here:
E-flite P-51B Mustang 32e Platinum Series (2 min 39 sec)
Old Nov 04, 2012, 12:15 PM
Joined Jan 2007
I already ordered the turnigy power setup. Ihave the battery, servos and all but I stll need retracts.
Someone must have a set.....or a Hong Kong replacement.
Now what is the hot set up for the tail wheel?
Old Nov 07, 2012, 10:14 PM
Joined Jan 2007
Is anyone out there?
I know I,m late to this party.
Old Nov 08, 2012, 07:20 AM
V2rider is offline
Find More Posts by V2rider
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
As far as mains go I think most are using the E-Flites, couldn't tell you what others will fit. For the tailwheel this link should take you to ALL AMERICANS mod thread in his blog. http://www.rcgroups.com/forums/showthread.php?t=1471800
V2rider is offline Find More Posts by V2rider
Discussion E-Flight Platinum series P-51b nitro_star Scale Kit/Scratch Built 2 Aug 27, 2010 04:09 PM
Question E-flite p-51b RCDestroyer Electric Plane Talk 4 Aug 26, 2010 12:10 PM
Sold ESM P-51B Mustang - "Frank Tiano Series" mustang1971 Aircraft - Fuel - Airplanes (FS/W) 8 Jun 06, 2010 02:32 PM
For Sale Nib E-flite platinum series AT-6 Texan w/ optional accsry's lavochkin Aircraft - Electric - Airplanes (FS/W) 8 Mar 31, 2009 06:51 PM
For Sale NEW - Top Flite P-51B Mustang #RARE# JimJams Aircraft - Fuel - Airplanes (FS/W) 5 Apr 13, 2006 05:17 AM
