Old Oct 13, 2012, 07:47 PM
sbakr23 is offline
Find More Posts by sbakr23
sbakr23's Avatar
United States, MN, Maple Plain
Joined Jun 2012
Originally Posted by brianos007 View Post
Is this normal so much uptrust in the motormount
On all my other planes there is downtrust.
Grtz Ed
Looks like too much up thrust to me. Mine mounts up pretty square to the center line of the plane. I have seen down and right built into a design, but have never seen up thrust built in.
sbakr23 is offline Find More Posts by sbakr23
Old Oct 14, 2012, 12:50 PM
JLogan is online now
Find More Posts by JLogan
AMA#313760
JLogan's Avatar
United States, MI, Taylor
Joined May 2009
I used washers to get 1/2 deg. right and 1 deg. down. You can't see it at the gap between the spinner and cowl unless your really looking for it. (The Eye's don't see it)
John
JLogan is online now Find More Posts by JLogan
Old Oct 14, 2012, 05:46 PM
srt8madness is offline
Find More Posts by srt8madness
whiirrrrrr
srt8madness's Avatar
United States, TX, Houston
Joined Nov 2011
Can someone direct me to a "how-to" for the retractable tailwheel? I bought the robart 122, but the linkages are kind of confusing
srt8madness is offline Find More Posts by srt8madness
Old Oct 14, 2012, 06:02 PM
AMA#313760
JLogan's Avatar
Joined May 2009
(Can someone direct me to a "how-to" for the retractable tailwheel? I bought the robart 122, but the linkages are kind of confusing)
I installed that Robart 122, while it works very well to retract, it does not hold when you turn the plastic arm and pin bend and will not hold rudder center when turnning. . You also need to make a new longer folk just to clear and keep your rudder off the ground E-Flite R&D failed here(Big Time). I removed my Robart 122 from the mustang. mine is in the hanger for struts and tail wheel mods.
John
Old Oct 14, 2012, 08:36 PM
capteasy is offline
Find More Posts by capteasy
capteasy's Avatar
USA, Texas Hill Country
Joined May 2008
"Can someone direct me to a "how-to" for the retractable tailwheel? I bought the robart 122, but the linkages are kind of confusing..."
"All American" has tailwheel mod that works perfectly and rotates in the correct direction- forward.
Do a search on this thread and you should be able to get fixed up. It's not difficult or expensive and it works.
Good luck,
ce
capteasy is offline Find More Posts by capteasy
Old Oct 15, 2012, 09:40 AM
whiirrrrrr
Joined Nov 2011
Gracias! You can quote my post now
Old Oct 15, 2012, 11:49 AM
whiirrrrrr
Joined Nov 2011
Just a small tidbit. I'm a speed guy, and while I like the stock performance, I wish it was a bit faster. I maidened and have been flying on a power 32 w 13x8apc prop. Recently I went to a nice, large Hobbyshop, with an awesome selection of props. They even have the old 4 blade apc props in the 12"-15" range. I picked up a 13x10 in hopes of increasing pitch speed. I only got one flight on it so far. It seems like there is a little extra "umph" to it. Not a ton faster than the 13x8, but I believe noticeable. When I get my lg setup worked out I'll take both props out and do some more testing. While subjective I still feel Ill be able to determine if this upgrade worth it. I need to solder ec5 adapters for my watt meter and then I'll have some objective data to post.
Old Oct 15, 2012, 11:50 AM
whiirrrrrr
Joined Nov 2011
If that still isnt enough, a power 46 upgrade is next.
Old Oct 15, 2012, 01:19 PM
Manu Simon is offline
Find More Posts by Manu Simon
Manu Simon's Avatar
Belgium
Joined Aug 2008
I tested mine on 5S ( 2650 mah 45C) this last week-end and that gave me the extra boost I was looking for .... The vertical is now amazing... The Turnigy G32 and Trust 70A ESC seem to cope without problems. Prop is a TGS 13x8.
Manu Simon is offline Find More Posts by Manu Simon
Old Oct 15, 2012, 01:27 PM
danpos is offline
Find More Posts by danpos
danpos's Avatar
Canada, NB, Fredericton
Joined Dec 2011
5S! I would like to see a video of that.
I followed your advice on the G32 with a 13x8 TGS prop. and I thought that was much faster than the APC 13x6.5 prop.
In fact I thought it was very fast on the 4S 13x8 TGS propeller.
Did you measure the amp draw?
danpos is offline Find More Posts by danpos
Old Oct 15, 2012, 04:55 PM
Manu Simon's Avatar
Belgium
Joined Aug 2008
One of the reason I did the test on 5S is that my 4S packs are now getting old and don't supply the amps they used to when younger. So instead of buying new packs I figured out I could try my newer 5S packs used in my HK vampire and Eflite Shoestring.
Haven't check the amps on 5S yet but will do.... I did two flights on 5S with throttle around 2/3 most of the time and got similar fly time compared to my 4S packs . When I fly her on 4S, throttle is around 4/5 and full.
Old Oct 15, 2012, 05:21 PM
LICobra is offline
Find More Posts by LICobra
Warbird Enthusiast
LICobra's Avatar
Long Island, NY
I agree that All American's tail wheel conversion with an 18g retract worked out perfectly. The plastic 122 assembly is just not strong enough for a 6lb airframe, but works very well on my Parkzone P-47 and P-51 retractable tail wheel conversions.
Just a small tidbit. I'm a speed guy, and while I like the stock performance, I wish it was a bit faster. I maidened and have been flying on a power 32 w 13x8apc prop. Recently I went to a nice, large Hobbyshop, with an awesome selection of props. They even have the old 4 blade apc props in the 12"-15" range. I picked up a 13x10 in hopes of increasing pitch speed. I only got one flight on it so far. It seems like there is a little extra "umph" to it. Not a ton faster than the 13x8, but I believe noticeable. .
Comparing a 13X8 2 blade to a 13X10 4 blade, It seems to me you'll have a combo that way overamps your motor and gives extremely short flight times with the possibily of a few more mph in pitch speed and increased thrust....let us know how that works out.
MS...with a 770kv motor and 13X8 prop on 5S.....whats your amp draw and prop rpm's ???
LICobra is offline Find More Posts by LICobra
Old Oct 15, 2012, 07:24 PM
whiirrrrrr
Joined Nov 2011
It seems I worded my post wrong on referencing the 4 blade props. I picked up a 13x10 2 blade prop. Sorry for the confusion.
Old Oct 15, 2012, 07:29 PM
jzanutto is online now
Find More Posts by jzanutto
AMA 73386
jzanutto's Avatar
Fresno, CA
Joined May 2005
I like it
jzanutto is online now Find More Posts by jzanutto
Old Oct 15, 2012, 07:59 PM
Cr@sh is offline
Find More Posts by Cr@sh
"Free crash instruction"
Cr@sh's Avatar
long island N.Y.
Joined Jan 2004
I like it too!....... But she won't let me have seconds I snuck one in anyway.......of course a second P-51 that is
Cr@sh is offline Find More Posts by Cr@sh
Discussion E-Flight Platinum series P-51b nitro_star Scale Kit/Scratch Built 2 Aug 27, 2010 04:09 PM
Question E-flite p-51b RCDestroyer Electric Plane Talk 4 Aug 26, 2010 12:10 PM
Sold ESM P-51B Mustang - "Frank Tiano Series" mustang1971 Aircraft - Fuel - Airplanes (FS/W) 8 Jun 06, 2010 02:32 PM
For Sale Nib E-flite platinum series AT-6 Texan w/ optional accsry's lavochkin Aircraft - Electric - Airplanes (FS/W) 8 Mar 31, 2009 06:51 PM
For Sale NEW - Top Flite P-51B Mustang #RARE# JimJams Aircraft - Fuel - Airplanes (FS/W) 5 Apr 13, 2006 05:17 AM
